04-13-2015, 04:33 PM | #101 |
Re: 64 c10 build
Nice work on the cab repair. And great find on the hubcaps.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-19-2015, 09:04 PM | #102 |
Re: 64 c10 build
What kind of rims did you use for the build......nice job
04-19-2015, 09:30 PM | #103 |
Re: 64 c10 build
Thank you
22" steel wheels... thanks!
You can find me on Instagram @neveno_cten |
05-19-2015, 03:25 PM | #104 |
Re: 64 c10 build
I finish fixing rust and I find more.. I had some rot/damage under the gas filler hole and rot under the drip rail on the driver side. I’m replacing the door skins now that the door bottoms are done. We wet blasted and wire wheeled the inside of the doors and primed ... Now I can put Hushmat the inside of the doors before installing the skins.
05-19-2015, 04:04 PM | #105 |
Re: 64 c10 build
More Pictures!! Oh and had to patched the speaker hole in the doors.
05-19-2015, 04:55 PM | #106 |
Re: 64 c10 build
Where did you end up putting your pcm and everything, i couldn't really see in the picture
05-19-2015, 08:28 PM | #107 |
Re: 64 c10 build
do you have a link to theirs?
05-19-2015, 08:50 PM | #108 |
Re: 64 c10 build
I did order my evap block-off plug from them.. The guy I spoke with was real cool.
https://www.novak-adapt.com/catalog/..._ecm_mount.htm
05-21-2015, 01:09 PM | #109 |
Re: 64 c10 build
Who made your instrument cluster? Are you running any wheel adapters on front or rear? Reason I ask is mine will be on bags and I'm wondering how close it'll be to the fenders on front and rear. Looked close in the pic you posted on page 2 (I think it was page 2).
05-21-2015, 09:40 PM | #110 | |
Re: 64 c10 build
My cluster is a Dakota Digital! I'm not running wheels spacers on the front and it measures about 1 1/2 from the tire to the inside lip of the fender. The rear has to have a small spacer because of the center bore. After everything I've decided to not use the 1 1/2 spacer in that pic.. I was gonna use a 1 1/4 spacer but I think the tire will hit the inner lip of the bed where the inner fender mounts. I'll have to measure it again when I get the bed back from paint but I think a 1/4" spacer will be best.
05-22-2015, 07:38 AM | #111 |
Re: 64 c10 build
I have heard of some using a 1/4" spacer with longer studs and others opening the center bore up using a CNC machine to open the bore some. Not sure which route I'll go yet. When you say using 1 1/4" spacer the tire may hit where bed and inner fender mount you mean towards the outside of the tire or inside of the tire? I'm not sure about using a spacer on an already heavy wheels. Probably try to find a machine shop to open it up...???
Thanks, Wade |
05-24-2015, 02:33 PM | #112 |
PROJECT 7DEUCE
Re: 64 c10 build
Truck is really coming along..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-28-2015, 09:53 AM | #113 |
Re: 64 c10 build
Nice build thread, glad I got to check it out in person last week!
09-05-2015, 09:00 AM | #114 |
Re: 64 c10 build
please explain what you did! I read that you used the letters, what gauge metal did you use to fill the rest of the gate? I like that a lot an might have to steal that idea for a future project, but put it on the other side, I got two extra gates to cut up
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
09-05-2015, 12:48 PM | #115 |
Re: 64 c10 build
Tailgate Mod is Very Nicely done!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
09-05-2015, 12:53 PM | #116 |
Re: 64 c10 build
Missed your build until this morning... Just went through t all... Smokin' progress!
Clemdaddy's get-together in October is a must attend if possible... See post #131 http://67-72chevytrucks.com/vboard/s....php?p=7251046
09-05-2015, 12:57 PM | #117 |
Re: 64 c10 build
Thank you very much guys!! I just went to the metal store with a piece of the gate to get the proper gage. The C and the O were easy the 1 was the L and the H put together.
09-05-2015, 01:16 PM | #118 |
Re: 64 c10 build
where at in Oklahoma are you at? yes clem's get-together will be awesome this yr. with guys coming from England and west coast!
09-05-2015, 01:17 PM | #119 | |
Re: 64 c10 build
09-05-2015, 01:21 PM | #120 |
Re: 64 c10 build
Im in Ada, about 2 hrs from Tulsa
09-27-2015, 12:22 PM | #121 |
Re: 64 c10 build
Not much progress on my build. I took some time off to build a 64 c10 bed for my 13 year old daughters birthday, that's what the custom c10 tailgate was for. I got my Vintage Air A/C unit and didn't like the under dash vents so I decided to go with the factory looking vent and cut my dash even though I guess my truck being a 64 wouldn't of had that option. I also got the Dakota Digital Climate Controller to match my dash cluster and got the dash vent and side vents from Jim!
You can find me on Instagram @neveno_cten Last edited by NevEno; 09-27-2015 at 01:58 PM. |
09-27-2015, 12:25 PM | #122 |
Re: 64 c10 build
Another pic! The center vent is bada$$!! Thanks Jim
09-27-2015, 12:47 PM | #123 |
Re: 64 c10 build
And... I got another c10 introducing the "BEATER". It's just a shop truck for now. It's fun to drive around. We drove it last weekend in the local Bluemoon hot rod cruise.
You can find me on Instagram @neveno_cten Last edited by NevEno; 10-22-2015 at 06:18 PM. |
09-27-2015, 02:08 PM | #124 |
Re: 64 c10 build
Nothing better than adding to the collection
09-27-2015, 02:16 PM | #125 |
Re: 64 c10 build
nice find, that looks like a 9 footer and in pretty good shape
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
