Old 10-05-2015, 08:04 AM   #101
dwcardfan
dwcardfan's Avatar
Re: The Snortin' bull
Nice and clean!!!!
dwcardfan is offline   Reply With Quote
Old 10-05-2015, 03:43 PM   #102
namloc
namloc's Avatar
Originally Posted by dwcardfan View Post
Nice and clean!!!!
Thank you, trying to keep it sano. a bit.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 10-05-2015, 08:18 PM   #103
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Gettin close.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 10-05-2015, 10:53 PM   #104
namloc
namloc's Avatar
Originally Posted by CHIZZLER View Post
Gettin close.
Thank's again Chizzler. Ya close though still some wiring.Exhaust mock up and build and install. Trans lines. Mount rear shock's. Still got to pull my rear axles and redrill for 5 on 5 and some rear brake work in the drums.
The Snortin' Bull
Old 10-08-2015, 10:36 PM   #105
namloc
namloc's Avatar
Got a couple things done at night during week. Shock lower rear brackets ready to get tacked on. Battery cable terminal ends done. Been busy at work so not to much time at night.
The Snortin' Bull
Old 10-10-2015, 09:57 PM   #106
namloc
namloc's Avatar
finished the tailshaft of transmission .Speedo all hooked up.
The Snortin' Bull
Old 10-10-2015, 10:03 PM   #107
namloc
namloc's Avatar
The batterie's are all wired in now.Finishing up harness of truck.Got interior wired,Back lighting wired in for guage packs,Exterior lighting wired.Alternator wired.
The Snortin' Bull
Old 10-11-2015, 10:05 PM   #108
namloc
namloc's Avatar
Working on the rear lighting harness.This truck had a handful of hole's in dash and everywhere.I filled them various period style switches instead of filling them.Keepin' the theme.
The Snortin' Bull
Old 10-11-2015, 10:10 PM   #109
namloc
namloc's Avatar
Diggin in part's boxe's I had an old school fill neck. From a 30"s Studebaker. For now it'll work.Set in the wood in the bed to mock up fill neck.
The Snortin' Bull
Old 10-11-2015, 10:12 PM   #110
namloc
namloc's Avatar
Nice and clean!!!!
Thank's tryin' to keep it simple and clean.
The Snortin' Bull
Old 10-17-2015, 11:08 PM   #111
namloc
namloc's Avatar
Through out this project rust is in the way as it for most of us.This stuff is the fashnizz. Aerokroil none better work's like a champ.
The Snortin' Bull
Old 10-17-2015, 11:11 PM   #112
namloc
namloc's Avatar
Even though this truck will look like a road side left over little detail's like ugly windshield squirter's bugged me..Found some original style on a parting out truck in the paper.The little round head one's are now on the hood.
The Snortin' Bull
Old 10-17-2015, 11:16 PM   #113
namloc
namloc's Avatar
Turn signal lever I modded. This might mess with some folk's . Back in the fiftie's rodder's would flip the shifter to left of the column.
The Snortin' Bull
Old 10-17-2015, 11:19 PM   #114
namloc
namloc's Avatar
A license frame from the sixtie's in Seattle . The gmc in red matched the lettering on the tailgate of the truck.
The Snortin' Bull
Old 10-17-2015, 11:24 PM   #115
namloc
namloc's Avatar
The red positive battery cable stood out.Used some old school asphalt loom to blend it in under the hood.The loom is cool stuff.Using it in other area's also.
The Snortin' Bull
Old 10-21-2015, 10:28 PM   #116
namloc
namloc's Avatar
Got my seat belt's and anchor plate's from Juliano's today. Started to install. There will be belt's also for a center passenger.Sorry about the grainy pic's.
The Snortin' Bull
Old 10-22-2015, 10:18 AM   #117
dwcardfan
dwcardfan's Avatar
Looks good.
Old 10-22-2015, 11:34 AM   #118
namloc
namloc's Avatar
Looks good.
Thank you., Appreciate the comment.
The Snortin' Bull
Old 10-22-2015, 10:23 PM   #119
namloc
namloc's Avatar
Got my gas cap and fill neck today from BAM Manufact..Look's and fit's better than my temporary set up.
The Snortin' Bull
Old 10-22-2015, 11:06 PM   #120
CHIZZLER
CHIZZLER's Avatar
Good progress. like that gas cap setup. Clean
61-crew cab D-max
Old 10-22-2015, 11:44 PM   #121
namloc
namloc's Avatar
Thanks Chizzler,I thought the same.not to plain not to fancy.
The Snortin' Bull
Old 10-23-2015, 11:48 PM   #122
namloc
namloc's Avatar
These seat belt anchor plate's from Juliano's are a must.I have seen a lot of pulled thru washer's people have used on the floor of vehicle's..
The Snortin' Bull
Old 10-23-2015, 11:52 PM   #123
namloc
namloc's Avatar
Belt's are in.
The Snortin' Bull
Old 10-25-2015, 10:00 PM   #124
namloc
namloc's Avatar
1960 GMC dash from the backside.It is need of some help .Had to make a jumper for 12 volt as the Circuit board has deteriated over time. Really only need it for backlighting the speedo.
The Snortin' Bull
Old 10-27-2015, 11:21 PM   #125
namloc
namloc's Avatar
After some clever rewiring and mating to American Autowire harness and the correct style bulb sockets (pc) style we have lighting for the gauges and hi beam indicator also working. Gas guage also. Mounted actual lh and rh signal lamps in dash. Installed an under dash courtesy light with a switch on the passanger side.
The Snortin' Bull
