Old 01-05-2017, 11:14 PM   #101
JacobSchni
JacobSchni's Avatar
Re: Schni's Blue 1983 K10
valve covers machined and put on, along with water pump and pulleys
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz
680hp/720ftlbs of NA fun
JacobSchni is offline   Reply With Quote
Old 01-05-2017, 11:49 PM   #102
77BBGMC
77BBGMC's Avatar
Nice numbers on the dyno!
77BBGMC is offline   Reply With Quote
Old 01-10-2017, 12:35 AM   #103
JacobSchni
JacobSchni's Avatar
carb for the 496. holley 850
Old 01-10-2017, 12:50 AM   #104
JacobSchni
JacobSchni's Avatar
gotta a ton of work done this weekend. Gotta thank my friend Neil for all the help. wire wheeled and wire brushed the frame. used kbs coating products. used the degreaser 50/50 mixed with hot water. scrubbed it on frame with scotchbrite pads, then rinsed and let dry. then used metal etcher with scotchbrite. Painted. Right now its 24hrs dry. Tried kbs instead of por15. Not a big fan. Won't be buying it again. Seems to hold up well, but the finish is awful. Can't tell from pics. No problems with por15 before, and I even prepped better with this stuff than i ever did with por. By the way this was the satin black can, as you can see it turns out glossy. Still have to finish scuffing and top coating. Then I'm onto fixing the firewall and heater core that i manhandled and broke the fitting off.
Old 01-10-2017, 12:50 AM   #105
JacobSchni
JacobSchni's Avatar
Old 01-10-2017, 12:51 AM   #106
JacobSchni
JacobSchni's Avatar
Old 01-10-2017, 12:52 AM   #107
JacobSchni
JacobSchni's Avatar
Old 01-10-2017, 12:52 AM   #108
JacobSchni
JacobSchni's Avatar
Old 01-10-2017, 12:53 AM   #109
JacobSchni
JacobSchni's Avatar
Old 01-10-2017, 01:38 PM   #110
Matt Man
Matt Man's Avatar
Dammm thats one hell of a motor for that truck, I would be tempted to throw it in a muscle car haha. Should scoot pretty good with that.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-10-2017, 01:55 PM   #111
JacobSchni
JacobSchni's Avatar
Yea, id like to build a nova. Maybe later I'll swap it over. A high revving 427 yenko clone would be pretty sweet though
Old 01-10-2017, 10:53 PM   #112
JacobSchni
JacobSchni's Avatar
scuffed the kbs and top coated with vht chassis and rollbar paint. satin black. still need to dry a bit. the pics are 10 min after last coat. itll "dull" a hair more
Old 01-11-2017, 11:45 PM   #113
JacobSchni
JacobSchni's Avatar
headers came in. since no one could help much with header selection, I went with the set one guy was running currently. they are hooker 2455 / 2455-1 / 2455-1HKR . They dont look to be kinda artwork, the finish seems a bit "halfass". Nonetheless if they work fine for such a cheap price i dont care. They have 2" primaries and 3.5" collectors
Old 01-12-2017, 10:24 PM   #114
JacobSchni
JacobSchni's Avatar
heres how it turned out after the paint dried. looks great in my opinion. love this vht paint.
Old 01-19-2017, 02:28 AM   #115
LT7A
Originally Posted by JacobSchni View Post
i dont have any hydroboost setup, and im taking out the ac. Going to only keep my heat. If you have pictures of alternator thatd be awsome.
Sorry man, I didn't check back in for a bit so I missed your request. Here're 3 pics of my alternator on the 454 swapped in place of a 6.2D. Tried to give you a coupla angles. Lemme know if you need more.
Old 01-29-2017, 11:42 PM   #116
JacobSchni
JacobSchni's Avatar
painted the firewall, finished the ac delete. New heatercore, blower motor and heater box. Dropped in the engine and trans this weekend. Bought the cu-70013 griffin radiator and tci shifter.
Old 01-29-2017, 11:43 PM   #117
JacobSchni
JacobSchni's Avatar
Old 01-29-2017, 11:44 PM   #118
JacobSchni
JacobSchni's Avatar
Name:  Dropping off to shop1.jpg
Old 01-29-2017, 11:45 PM   #119
JacobSchni
JacobSchni's Avatar
Old 01-30-2017, 01:15 AM   #120
deejaaa1
looking good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 02-06-2017, 10:42 PM   #121
JacobSchni
JacobSchni's Avatar
Mounted my gauges and plumped them. Cleaning up wiring and running wires to roughy where they will be going. Got my headers pushed up to block, still need to mount them. Also found a couple more pics from when i dropped in the engine.
Old 02-06-2017, 10:43 PM   #122
JacobSchni
JacobSchni's Avatar
Headers seem like they are going to fit with very minor adjustments. They are hookers 2455 headers. 2" primary and 3.5" collector. HKR2455
Old 02-07-2017, 10:45 PM   #123
LF_MN_71GMC
LF_MN_71GMC's Avatar
Yep. Awesome.
1971 GMC 4x4 half ton np 205
1969 chevrolet camaro
1984 K10; 4" lift; sbc;
Build link
http://67-72chevytrucks.com/vboard/s...d.php?t=647172
LF_MN_71GMC is offline   Reply With Quote
Old 03-29-2018, 10:31 PM   #124
JacobSchni
JacobSchni's Avatar
Been a while. finished my dana 60. just need to swap it over. motor went in last winter. had to change headers from the hookers due to fitment. they were very tight if i wanted to run any kind of exhaust. I ordered fenderwell headers from maddog headers and had them ceramic coated. They fit great and look awesome.
Old 03-29-2018, 10:32 PM   #125
JacobSchni
JacobSchni's Avatar
motor in truck
