Old 07-11-2015, 08:08 PM   #101
SPEEDYS GARAGE
SPEEDYS GARAGE's Avatar
Re: My 54 3100 pickup build
Moving on to the next important job, the manifold. Removing the bunch of bananas and fitting the Holley 300-137 EFI manifold, its operating RPM starts at 2500, for the price nothing else has a lower power starting point.
And as this is a run what ya brung budget build, LOL. I will be adapting the Drive by wire throttle body from the motor, In Australia the Last 5.7 LS1 in our 2004 VZ Monaro got DBW throttle, with its own unique plug. (LS2 got same plug as all 2005 onwards)
Here is the throttle body adapter construction pics... Took a whole day of messing about.
Have to blend the round hole to the 4150 square hole, counter bore the bolts, o-ring the adaptor plate to throttle body surface. The fun never stops.
"There are two types of people in this world: those who like Chevy pickups, and those who don't."
SPEEDYS GARAGE is offline   Reply With Quote
Old 07-11-2015, 08:13 PM   #102
SPEEDYS GARAGE
The factory throttle body flows around 750cfm and will suit my street truck needs, not going to bother with a cam change or any other mods except headers and a tune. The adapter plate is 16mm thick, the spacer plate in this picture is for hole placement only.
Old 07-11-2015, 08:17 PM   #103
SPEEDYS GARAGE
After some redkneck math, I chose a 36deg angle for the cutter, fixed the plate onto my rotary table and started making a mess.
Old 07-11-2015, 08:21 PM   #104
SPEEDYS GARAGE
Jumping forward a little, It was easier just to had blend the round to square hole, too many multiple angles for a manual mill. . Came out great.
Old 07-11-2015, 08:22 PM   #105
SPEEDYS GARAGE
Holley manifold in place.
Old 07-11-2015, 08:23 PM   #106
SPEEDYS GARAGE
Adapter bolted up perfect. O-ring groove is good enough, may look for a fibre 4150 insulator spacer block just to keep the heat away from the throttle body motor and internal electronics
Old 07-11-2015, 08:30 PM   #107
SPEEDYS GARAGE
Tadah ... Love it when a plan comes together.
Old 07-11-2015, 08:33 PM   #108
SPEEDYS GARAGE
Thats all for this posting , Motor is sitting in place, will be making mounts for that and the rear transmission. Looks like I will have to chop up some headers to get what I want.
Old 07-11-2015, 08:47 PM   #109
SPEEDYS GARAGE
Now that the motor and trans are in place for the first time, I can see that it would help to raise an inch and move rearward two inches, so going to make a pocket in the firewall for the right rear valve cover clearance, and chop a larger hole in the cab floor.
Old 07-11-2015, 10:12 PM   #110
Advanced Design
Advanced Design's Avatar
Very nice machine work!
Advanced Design is offline   Reply With Quote
Old 07-11-2015, 10:30 PM   #111
ghettoluxury
ghettoluxury's Avatar
I'm sure glad someone is testing my theory with a factory throttle body on one of the EFI intakes. Are you planning on using a Mass Air sensor? Please let us know how this works out!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-12-2015, 04:45 AM   #112
iowaboynca
iowaboynca's Avatar
Wow...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 07-17-2015, 09:19 AM   #113
SPEEDYS GARAGE
Here is the chassis to engine mounts. Fabbed out of heavy wall 1.1/2" curved tube. With 5mm plate gusset. Still have one more brace to fit.
Old 07-17-2015, 09:23 AM   #114
SPEEDYS GARAGE
Rear transmission mount out of same heavy wall 1.1/2" pipe.
Old 07-17-2015, 09:46 AM   #115
SPEEDYS GARAGE
Underside shot.
Old 07-17-2015, 09:48 AM   #116
SPEEDYS GARAGE
Motor in place, Headers next.
1/2 ton, 1954 chevy, 3100
