11-23-2015, 04:49 PM | #101 |
Re: Hemi's 70 Blazer build
I'll be covering the floor with sound deadener (Peel&Seal), then carpet without the jute backing. I made my own roll bar and had it mandrel bent.
11-23-2015, 05:20 PM | #102 |
I have read about peel and seal somewhere. Perhaps in one of your posts. Where do you get it?
11-23-2015, 07:32 PM | #103 |
11-27-2015, 05:51 PM | #104 |
Engine bay is starting to fill up. So far I've had zero clearance issues, and it looks like it belongs there.
11-27-2015, 06:28 PM | #105 |
that looks great!
11-29-2015, 12:43 PM | #106 |
Good progress.Looks great.
I like the paint too. What color interior where you thinking ?
Tom 71 K2500 71 K5 Jimmy |
11-29-2015, 11:19 PM | #107 |
12-09-2015, 10:46 AM | #108 |
Boosted Member
OUTSTANDING work! Very awesome.
I am interested in building a plasma table like that...can you point me in the right direction?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-13-2015, 11:17 AM | #109 | |
for the electronics. The table will have to be built with whatever you can afford or scrounge. The most expensive part will the the linear bearings. Try to find some used ones. Another way of getting the table is to purchase an old one with outdated electronics and rebuild it. |
12-17-2015, 04:33 PM | #110 |
Doesn't look like much progress, but I haven't stopped working on the Blazer. Finally got all the wiring done which took forever. I hate wiring !! Got the Dakota Digital dash installed too.
Fender and doors were temporarily installed so that the body mounts could be shimmed and tightened. I'm real happy with the door fits.The new grille was also fitted. It's real thin compared to the original. Go my rad core this morning from Howe racing, so will be fabbing the tanks hopefully this weekend. Once it's installed, I'll be able to fire up the engine. |
12-17-2015, 06:53 PM | #111 |
I can see the end soon!
12-17-2015, 07:06 PM | #112 |
12-18-2015, 08:09 AM | #113 |
Looks great, nice progress. Where did you get the steering wheel mounting hub. Mine is a very old design, and the horn button keeps falling off
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-23-2015, 11:05 AM | #114 | |
I got the rad done and installed. I plasma cut the tanks and they fit perfect. I only have about $200 in total to build the rad so it was worth a bit of time and effort considering buying a comparable unit would be almost $500. I also got the AC lines installed. I haven't put the 134a in yet just in case things have to come apart. I did however evacuate the system and seems to hold a steady vacuum. Hopefully will get it fired up next week. Wishing all of you a Merry Christmas and a Happy New Year !! Dan |
12-23-2015, 12:35 PM | #115 |
I'm trying....
Just outstanding workmanship Dan. Continuing to look great. Getting excited with you. Good luck on the key-turn....love that 70 grille!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
12-24-2015, 09:09 AM | #116 |
Maybe I missed it. Who did your harness and is it new or a reworked stock harness
12-24-2015, 11:27 AM | #117 | |
Having a wiring schematic of the donor vehicle is a must also especially if you want to run all the emission components. |
12-24-2015, 01:25 PM | #118 |
Do you have any specs for the roll bar that you built?
12-24-2015, 02:49 PM | #119 |
I have a couple .DXF drawings of it. You may want to wait till I get the driver's seat installed before copying it. I designed it to fit under the Softopper, but am concerned about having the seat belt mounting point too close to my head. Time will tell if I have to modify it or move it back a bit.
It was made from 2 1/2 dia 1/8 wall tubing with a CLR of 5". Dan |
12-26-2015, 04:12 PM | #120 |
Blazer Fanatic
Man, Super cool build you got going on. i wish i was there with ya to learn from your skills. Ive only seen one 70 blazer in med. gold and thats mine. You found the twin!
1970 Chevy blazer |
12-27-2015, 09:38 AM | #121 |
It's alive !!
https://youtu.be/BcFMoWSBBdk |
12-29-2015, 07:09 PM | #122 |
12-30-2015, 01:00 AM | #123 |
Carpe manana
Nice!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-30-2015, 03:03 PM | #124 |
I'm trying....
Big step...sounds sweet. Congrats.
12-30-2015, 04:42 PM | #125 |
Thanks Guys !! Definitely a huge hurdle overcome. Getting kinda burned out working on it and looking forward to the end.
