03-14-2016, 10:44 AM | #101 |
Re: Project Two - '74 Sierra Grande
03-17-2016, 02:18 PM | #102 |
Following - Loving this
65 C20 292 4spd 4:56 Eaton HO52 |
04-04-2016, 01:18 PM | #103 |
I'm going to follow this one. I love the cannonball, so this one should be cool as well.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
05-05-2016, 09:30 PM | #104 |
Cool build man.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-05-2016, 08:59 PM | #105 |
. Any updates on this amazing build? . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
06-06-2016, 10:23 AM | #106 |
We finally got onto the next phase of finishing the Cannonball project, which meant that the cab for this truck got freed up again. So we are back to two separate trucks If you want to see the progress on the pro-touring truck aka Cannonball then you'll need to go back to its build thread.
Since we had everything off the original chassis already we decided to pull the 350/Turbo 350 combo and drop in the original LS3 I had for the Cannonball project. We found another TR6060 transmission to bolt up, which works out well as the cab tunnel is all setup for this transmission. Here's a bunch of photos from the deconstruction/reconstruction: Last edited by mikentosh; 06-06-2016 at 10:37 AM. |
06-06-2016, 10:27 AM | #107 |
And now its sitting in my garage where I've been tinkering away at the somewhat long list of things to get this back up and functional. Well its down to just waiting on a driveshaft, and getting the brake lines in and bled before this thing is back cruising.
Since there was some time to kill I dropped in an ASA cam and upgraded springs for the LS3. We used the headers and 3" downpipes from the other truck and connected in some nice Borla mufflers so this thing sounds really good now. |
06-06-2016, 11:13 AM | #108 |
see you restored the license plate, looks out of place now. lol
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
06-06-2016, 11:15 AM | #109 |
very cool! my dream shop truck!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
06-06-2016, 11:16 AM | #110 |
06-06-2016, 12:33 PM | #111 |
Great build and I will be following along on both!
06-06-2016, 12:34 PM | #112 |
I almost dig this one more. Old and new, without all of the "exclusive" parts.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
06-06-2016, 12:35 PM | #113 |
It should be entertaining to drive. It has a non-posi 12 bolt in the back right now with a damaged shock on one side and missing the shock on the other. Definitely a blend of old and new hahahaha
06-19-2016, 10:00 PM | #114 |
this truck is amazing!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-26-2016, 11:25 PM | #115 |
Any Updates on this one ???
11-08-2016, 11:37 PM | #116 |
I love the way you continued the floor ridges up and over the notch. Do you have any pictures of the process? Did you cut bed floor patches on an angle to close the gaps?
Evan B. |
11-09-2016, 02:10 PM | #117 | |
11-09-2016, 02:16 PM | #118 |
Wow. That's amazing work. Give that guy a pat on the back.
Evan B. |
11-12-2016, 09:12 AM | #119 |
It looks ulike you have sanded to let more of the original paint shine thru. Your other truck is over the top but I really dig this rig too!
11-16-2016, 10:52 AM | #120 | |
Evan B. |
11-17-2016, 02:56 AM | #121 |
11-17-2016, 04:11 PM | #122 |
Cool. Thanks!
Evan B. |
11-17-2016, 06:48 PM | #123 | |
12-11-2016, 05:58 PM | #124 |
I was reading over this build and fell back in love with this truck. I had a 74 with the same blue on white. Loved the look of that truck. It was a fully loaded C10 for that year, lol. I should have kept it but sold it to a friend some parts live on though. Killer truck.
12-12-2016, 10:29 AM | #125 |
Small update on the blue truck. It's currently parked at the side of the shop waiting for some love. We finally got tired of bottoming out with the stock crossmember and the rear end was borderline dangerous with a potential cracked spring and no shocks. Wes is trying to decide which way to go on the rear end...4 link with a solid axle, or some kind of Corvette derived IRS. Front will get a custom crossmember. It may be a few months before this thing sees the road again.
