Old 07-15-2016, 07:34 PM   #101
SKT
SKT's Avatar
Re: 1978 Russet Metallic 4x4
Awesome job w/ this one - looks really sharp!
Think your Dad will drive it a lot again, or will it see limited use?
SKT is offline   Reply With Quote
Old 07-15-2016, 07:36 PM   #102
buffydores
buffydores's Avatar
Not sure, but if he doesn't, this guy will.
Old 07-15-2016, 07:55 PM   #103
SKT
SKT's Avatar
That interior and front end accessories look great!
Old 07-16-2016, 11:10 AM   #104
buffydores
buffydores's Avatar
Thanks. It hits the right notes.
Old 07-28-2016, 01:10 PM   #105
buffydores
buffydores's Avatar
Dad had only one complaint. The sloppy steering from the original rag joint. So Tuesday I installed a Borgeson unit with u-joints at both ends. Nice upgrade. Ended up sawing the original in half to get it out. I had to cut 8" off the Borgeson unit to get it to fit right. And it was damn hot outside.
Here are me and the boys heading to a car show a couple weeks back. We're not very cool.
Old 07-28-2016, 01:17 PM   #106
buffydores
buffydores's Avatar
Originally Posted by aggie91 View Post
Outstanding work on the Blazer! Hopefully since I'm in the same part of Texas, I can see it some day in the future.
Where did you get the rubber you cut for the floor mats?
American Floor Mats. It was stupid expensive, but I couldn't find anything else that looked good and matched the interior.
http://www.americanfloormats.com/pyramid-rubber-mats/
Old 07-29-2016, 07:11 PM   #107
phillipm
That's a great picture!
Old 07-29-2016, 07:13 PM   #108
phillipm
The driver side mirror won't stay put at highway speeds. Gonna fix that next. I think the rubber grommet does more holding than it first appears.
Did you get the mirror to stay? Mine do the same thing at highway speed. I was thinking of taking it apart and wrapping a motorcycle rim strip around the post and putting the locking plate back on. But wasn't sure.
Old 07-30-2016, 08:28 PM   #109
buffydores
buffydores's Avatar
I installed a new one. The answer is no. Once you hit 70, they start to creep. I tried adding rubber to the post. Didn't work. I'm sure something would work, but I didn't figure it out.
Old 07-30-2016, 10:06 PM   #110
68Timber
I know the pieces fit
68Timber's Avatar
The rubber grommet is just to seal the housing where the post goes into the base. There should be a friction sleeve wrapped around the mirror post where it clamps into the base. I'll see if I can find a picture from when I rebuilt and painted mine.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-31-2016, 09:05 AM   #111
buffydores
buffydores's Avatar
John: I know, that's what we're talking about. There just doesn't seem to be enough friction at those surfaces to matter, even tightened. I added several layers of rubber and it would still rotate.
Old 07-31-2016, 12:41 PM   #112
68Timber
68Timber's Avatar
10-4. Mine did the same thing, they were original to the truck though. When I had them apart to paint them, I soaked the base gaskets, grommets and sleeves in hot water and Dawn dish soap then cleaned them. They stay put now. If yours are new, dirt probably isn't the issue - maybe take the sleeves off and tape some skateboard tape in place instead? That should grip good.
John
74 Honda Z50 build
Old 08-02-2016, 03:50 PM   #113
buffydores
buffydores's Avatar
Here's the Borgeson shaft:
Packing stuff out at the lake:
Old 08-02-2016, 10:37 PM   #114
TKCR
TKCR's Avatar
Had that same issue.
You can remove the screw at the bottom of the cover over the base of the mirror, and slide the cover up over the rod closer to the mirror head and there are 2 bolts you can access under the cover the gently tighten down on those, test the mirror head to make sure you can still move it. Then just slide the cover back down over the mounting hardware and replace the screw.
Old 08-02-2016, 10:48 PM   #115
buffydores
buffydores's Avatar
Lol. Folks, even when you tighten, they still creep. I drive this thing at 80 on interstate. Those big Dumbo's move.
Old 08-02-2016, 11:15 PM   #116
TKCR
TKCR's Avatar
LOL, well they shouldn't move. Maybe you need to slow Dumbo down, so his ears aren't blowing so hard.
BTW, that is THE nicest Blazer I think I have ever seen!! Great job! I just LOVE that interior, sweet!
Old 08-02-2016, 11:30 PM   #117
buffydores
buffydores's Avatar
Thanks amigo. It drives so well. It's super fun to drive.
Old 08-03-2016, 12:26 PM   #118
phillipm
Okay I fixed my aftermarket (LMC) mirrors. Now this may not work for everyone because I used parts from the original GM mirrors.
What I did was take mine apart, and then transfer the GM rubber, and the GM base plate over to my LMC mirrors. They now work fantastic and do not move at all on their own! I will post a few pictures over in my blazer thread, but I couldn't be happier with the results. It seemed like the rubber that GM used was a completely different product. It was also about 1/2 the size of the LMC rubber which was surprising. The GM base plates also fit the shaft much better and have more of a "wrap" on the mirror stem.
Phillip
Old 08-03-2016, 06:39 PM   #119
68Timber
68Timber's Avatar
Glad you got it figured out.
John
74 Honda Z50 build
Old 08-10-2016, 12:35 AM   #120
Fishermen0105
Are you running r12 or r134a?
Fishermen0105 is offline   Reply With Quote
Old 08-11-2016, 05:54 AM   #121
buffydores
buffydores's Avatar
I'm not sure.
Old 08-15-2016, 04:17 PM   #122
Jonboy
Slots go on anything!
If you are driving a Blazer that nice, you are definitely cool. Truck is outstanding!
1974 Jimmy- 5.3/4L80e/NP241
Old 12-04-2016, 07:27 PM   #123
buffydores
buffydores's Avatar
Just being awesome.
Old 12-05-2016, 11:13 AM   #124
aggie91
I'm just glad to be here!
aggie91's Avatar
Love this blazer. I hope to see it around town one day...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-05-2016, 11:40 AM   #125
buffydores
buffydores's Avatar
I make semi-weekly visits to Jordan Jackson's Bodacious on Mobberly for fatty brisket bliss in this rig. Mmmmm.
