Old 10-05-2016, 12:24 AM   #101
lower50's
lower50's's Avatar
Re: 87 Chevy Crew Cab 4x4 Converion/Cummins swap
Wow just read your build you did a great job. I totaly agree with the built not bought. I love the mechanical diesels, very little to go wrong. I have plans to put a 4bt in my '87 jimmy some day.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-05-2016, 12:19 PM   #102
DieselRat
We used to comment on each others builds in the 47-54 section. Maybe you saw my post that I sold that truck and brought you here! Thanks for the comments. Now if I had put this 6BT in my 54 GMC, I'd probably still have it!!!
54 GMC OM617 diesel swap
http://67-72chevytrucks.com/vboard/s...d.php?t=588827
87 Chevy Crew Cab Cummins
http://67-72chevytrucks.com/vboard/s...d.php?t=711157
DieselRat is offline   Reply With Quote
Old 10-05-2016, 02:32 PM   #103
DieselRat
Got tied up and didn't get out to a good photo spot to show off the truck, so I got some cleaned up driveway shots instead. Picked up a bunch of pieces to put together a proper intake this morning, and new gasket for the MC because suddenly the paint on my frame started to shrivel up from brake fluid splashing out of the reservoir!
eventually that big loom on the firewall will disappear, didnt't want to hack anything up until I knew I didn't need it!
my driveway has been through hell from this build!
Old 10-05-2016, 04:32 PM   #104
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man, that is one clean truck. You did a great job on the 4wd swap and the cummins install. Great work.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-05-2016, 05:45 PM   #105
NastyBuzzard
NastyBuzzard's Avatar
It looks awesome!
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 10-05-2016, 07:34 PM   #106
Eyegore
What Hump?
Eyegore's Avatar
I agree your truck looks great!!!
As far as the driveway just look at it as your truck sweating
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 10-05-2016, 11:04 PM   #107
lower50's
lower50's's Avatar
Yes I saw you sold it and saw that you where building this. Looks real nice.
1951 MG TD
Old 10-06-2016, 03:30 PM   #108
DieselRat
So sounds like I've got a bearing squeeling or something going on around the clutch area. Only seems to happen when I get some speed up, seems to come in around 45mph or so. Doesn't really go away with the clutch in or out, in gear or not. I'm thinking in the clutch release bearing, but no idea. I think tonight the TC and trans are coming out before something creates more damage than it needs to!
Old 10-06-2016, 04:53 PM   #109
AnotherWs6
AnotherWs6's Avatar
That thing is beefy. You did some good work there.
Whispering........tuuuuuuurbo
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 10-07-2016, 08:36 AM   #110
DieselRat
Thanks! More I drive it the more I like it. Its different going from a 24v with a built auto and an edge box that RIPS, to shifting a 12v, but equally cool in each respect.
I may have jumped the gun on my trans noise, I'm NOT planning to yank the tranny YET. Did some cruising around last night, and the noise is a constant, it doesn't build or get louder as driveline speed increases, and its actually more below to behind the shifter, not in the bellhousing area. I need to find someone else to drive so I can stick my ear closer and see whats what.
I did pull the AFC housing last night to do a little investigating and sure enough it already has a fuel pin in it but the star wheel was backed out almost all the way and the 'smoke screw' was played with, so that sort of explains why I get a jump in low end power and some hazing, then dies out on top end. I didn't mess with it too much for now, but glad to know that saved me $100 on buying a new pin!
Old 10-07-2016, 09:35 AM   #111
NastyBuzzard
Making me wish more and more I could afford a cummins.
Old 10-07-2016, 03:32 PM   #112
DieselRat
Deals are out there, but all in all if I was to do it again I would look for a rotten 4x4 truck to use as a donor and get all the pieces in one shot! It was just easier to do a little here and a little there, but the numbers were all the same in the end.
Old 10-07-2016, 03:38 PM   #113
Chevy3+3
Is it an NV4500? Were you hearing the noise more in 5th gear or any gear?
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 10-08-2016, 08:07 AM   #114
DieselRat
Mostly 4th and 5th. I'm aware of the 5th gear problem, which is the curse is trying to find OTHER problems because thats the go to problem with these trans. It had the 5th gear nut fixed.
Old 10-08-2016, 09:59 AM   #115
Chevy3+3
I swapped an NV4500 into my truck. It hadn't been ran in a while because the truck was wrecked but had about 10K on a rebuild. I bought it from the guy who decided to part out his truck. It made a little noise but anything with gears is noisier usually anyway.
I decided to change the oil in it. They recommend filling them 1 qt over the fill plug. The last quart will need to be added thru the shift tower. You can't use just any gear oil. Most everyone says use GM or Dodge oil. It is worth the price of gold at about $30/qt. I actually used Amsoil MTG. It is specifically formulated for the NV4500 transmission and I got mine bought for around $12-13/qt. I have not had any problems with it and my transmission has gotten quitter and shifts smoother. I believe that Redline oil makes an oil specifically for the NV4500 also.
Old 10-08-2016, 10:04 AM   #116
Chevy3+3
Could you do me a favor and get me the measurement from your front wheel well opening to the ground? I am just curious to see how high it sits with the springs you used compared to mine. Thanks
Old 10-10-2016, 07:52 PM   #117
Dieselwrencher
He hit it on the head. I'd replace the fluid and see how it sounds. Over fill it a quart like mentioned. Midwest trans in Minnesota has the fluid and it is affordable too. The 5th gear synchro can get noisy on these things. I've had some be noisy for ever and ever.
Ryan
Old 10-11-2016, 08:53 AM   #118
DieselRat
I'm already with you guys. Got Amsoil MTG in the trans and it was filled about 1 qt over. I may try changing out the fluid just to see how it looks and for the hell of it.
Aside from that I put some miles on it, runs and drives nice! Wife and kids are very happy with all the room. Started to put my HX35 on it last night but it got wicked chilly and just didn't get to finish.
I will get measurements for you tonight on the height of it. So far it has settled a tiny bit in the rear but hardly at all in the front which is opposite of how I thought it would go!
Old 10-11-2016, 12:35 PM   #119
Chevy3+3
Good deal. My wife didn't care my my CC at first. She just wasn't brought up driving older trucks. That's all I grew up with was riding in squarebodies. Since she's rode in it now for a couple of years she is starting to like the truck more and more because of all the extra room the CC has. Although she's still amazed how my almost 30 yr old trucks turns more heads and gets more compliments than brand new trucks on the rode, lol.
I love the way your truck looks now. This body style and the fact that its a dually lets you get away with running a slightly smaller tire and still have the extra lift look good. I like the way it looks. You did a great job on the conversion.
Old 10-11-2016, 02:29 PM   #120
DieselRat
Thanks a lot! I was just blessed to have my wifes support through the whole project. Not many guys get away with 'hun, I'm gonna buy a 1987 truck, and tear the whole thing apart, swap the engine yada yada and its gonna be out 'new' replacement truck'....say whaaa!
But really, I've had my 00 cummins for about 5 years now and its been a great truck, but with 2 growing kids, hauling us and all our crap in an ext cab short bed just doesn't fit comfortably. Plus I'm trying to become debt free, not in debt more and certainly not for a vehicle. After selling my 00 I will only have a couple grand more into this chevy than my proceeds from that sale. Plus like you said, the cool factor went way up!
Oh and I pulled the cap off to haul in a new couch the otherday, I will update with some cap-less pics tomorrow.
Old 10-14-2016, 08:57 AM   #121
DieselRat
Haven't driven the truck all week. Decided I was going to try and get this HX35 put on and plumb up the charge cooler setup. Figured I would start on the turbo side since there was a little more going on there than intake side. Got the turbo on and clocked, a little massaging of the passenger inner fender and it was good. Put the intake ram on the other side and wouldn't ya know it hits my brake master. Scoured the web looking at pics of other conversions and I guess just my luck with engine placement theres no room and no way to make it work. Went down to the cummins shop near me and scoured through their misc pieces trying to find a different elbow and just wasn't coming up with anything. So I got a hold of a piece of 3" J bend stainless pipe and made up my own! Its not welded to the flange yet in this pic but heres what I came up with.
Hopefully finish that up tonight, planning monday to go back down to the shop and check my timing and some other things and get it running better.
Old 10-14-2016, 03:43 PM   #122
Dieselwrencher
Do you have a pulse adapter to hook to a timing light to check your timing?
Ryan
Old 10-15-2016, 08:01 AM   #123
DieselRat
I don't, I'm taking it down to a shop near me to do a couple things including timing on monday.
Old 10-18-2016, 09:27 AM   #124
DieselRat
Just a little update.
Put the stock turbo back on and took it down to the shop. Timing was off a bit so we adjusted that. Then played with the pump some. Definately woke it up a little. Didn't want to go to crazy until I get a set of gauges, so theres definately more to be had once I get that all sorted out.
Also figured out I am definitely going to need to get a drop pitman arm. My steering rod ends are a little out of their comfort zone. Hauled a crapload of firewood this weekend, gotta love a 1 ton. Didn't matter whether I had 1 piece of wood or an overflowing bed full, it didn't seem to notice a difference either way.
So now that I am broke, I'm going to order a new pitman arm, then just drive this thing for a while and save up for some gauges. Then the short long term plans are, gauges, injectors, finalize the turbo upgrade and finish my exhaust up right, carpet and more sound proofing. oh the list goes on...
Old 10-18-2016, 09:32 AM   #125
Chevy3+3
Sounds like you've nailed down a plan. I wouldn't have thought you would need a drop pitman arm. Do you have a picture showing the angle of the steering arm? I'm thinking about bumping my lift another 1 1/2" but I hate to change out pitman arms, lol
