Old 05-14-2018, 03:34 PM   #101
knomadd
knomadd's Avatar
Re: Grandpa's 72 restoration
Originally Posted by Snake72 View Post
Can anyone tell me what the yellow, blue, green, and purple wires on the engine harness attach to? I know the pink is HEI power.
Originally Posted by Joesjunk View Post
Green is temperature sending unit
Yellow and purple are starter
Don't remember what the blue one is
Joe is right, Green is water temp sender, purple to the starter, and blue is for the oil pressure sender for an electric gauge.
I'm not looking at a factory wiring diagram, but rather an American Auto Wire diagram (attached), which is supposed to be similar to the factory colors, so take this lightly, as it might not be what you need. That diagram shows a white wire going to the coil negative (TACH side of HEI unit). If you have points and a ballast resistor, the white would go to the negative side of coil & pink to ballast resistor. A wire would be connected from coil positive to other side of ballast resistor and yellow from same terminal to the R terminal of the starter. The yellow wire isn't used in the AAW harness if you have HEI.
Again, be careful as this isn't for a factory harness, so the colors may not be exactly the same.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-14-2018, 06:12 PM   #102
Snake72
Snake72's Avatar
Thanks guys, appreciate the diagram. I'll have to dig up the factory diagram as well. One more solid weekend of work and should be ready to turn the key for the first time
Snake72 is offline   Reply With Quote
Old 08-06-2018, 10:43 AM   #103
Snake72
Snake72's Avatar
Finally had a free weekend to tinker, finished up running exhaust, finished wiring and new grounds. Also decided to get the dash pad installed. What a horrible job...I hope to never do another one. The color matches my OG interior paint very well though. I painted the metal dash flat black, and hate it. I'll have to mask and spray flat blue, just doesn't look right black. The whole interior is ready to go back in, restored the instrument cluster and looks great. The original medium blue interior paint was cleaned and buffed and came out fantastic.
Old 08-06-2018, 02:00 PM   #104
68Gold/white
Hope you didn't have to dodge any of those 'tornader's that were going on up there in last month or so....
68Gold/white is offline   Reply With Quote
Old 08-06-2018, 04:26 PM   #105
Snake72
Snake72's Avatar
Nope, all the "tornaders" were west of us. Had some pretty bad ones
Old 08-06-2018, 08:01 PM   #106
rustytruck50
rustytruck50's Avatar
Man, you do nice work!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-06-2018, 10:13 PM   #107
cornerstone
cornerstone's Avatar
Just read the whole thread. Hats off to you staying stock. I considered doing the same with the truck that I am building, but honestly the original color (ochre) is my least favorite of ALL options. If my uncle had chosen any other color I probably would have went the same direction you did. I've gone the other way, with long to short conversion, air ride, L83 direct injected 5.3 and 6 speed auto, and blue and white like yours. I'm really looking forward to seeing you fire this truck back to life. Your work is inspiring and I think your F.I.L. is proud!!
cornerstone is offline   Reply With Quote
Old 08-07-2018, 09:49 AM   #108
Snake72
Snake72's Avatar
Thanks guys! I'm happy I went the stock route as well, couldn't bring myself to chop it up, but I came close! Had the sawzall in hand and a crazy look in my eyes... Just need to clean and install the fuel tank and gonna try to turn the key and hope I didn't mess something up too bad. Looking forward to getting back to painting and finishing body work.
Old 08-09-2018, 04:33 PM   #109
landarts
landarts
Snake72 - very nice work on the truck. I like the fact that you stayed in the original lane. Also sorry to hear about your father in law. Maybe you could get his initials on a custom classic license plate for the truck if they do those there in Iowa. Every time some one ask what does the plate stand for you have a life story to tell, which will help keeping his memory alive.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-10-2018, 10:23 AM   #110
Snake72
Snake72's Avatar
Landarts I have thought about license plates with initials and his old race car number, but I just found a mint set of 1972 Iowa plates that I really want to run but I'll have to check with DOT first to see if I can use them.
Also finished my cluster refurb. $35 from rock auto. Tried using "chrome paint" on the original but it looked like satin silver, not good enough. The clear plastic gauge covers were polished with flitz, came out great and very happy with it.
FYI rock auto has the cheapest ACC carpet I could find, I think it was $160 with mass backing upgrade, should be delivered today.
Old 09-04-2018, 04:08 PM   #111
Snake72
Snake72's Avatar
Made some good forward progress this weekend. Redid my plug wire routing, I used Delco 75 corvette wires that routed WAY better than my previous wires that were for a 78 C10...was able to tuck them away nice and clean. Ran some more ground wires/straps, went through the wiring again and ran a temporary exhaust using stainless downpipes to cheapo turbo mufflers, will have a good system put on after the truck is running.
I threw the ACC carpet in quick but is not in permanently yet, just wanted to let the carpet rest. It fits well but was quite wrinkled which I should be able to work out pretty easy. Cut and buffed the original interior paint and cleaned up awesome. The steering wheel will be cleaned but not repaired or painted. Took many miles of my grand parents hands to get it looking like a beat up chore boot.
Cleaned the nasty gas out of the old tank and now looks brand new. There was a solid layer of varnish crud on the bottom but after draining the tank my Dad and I dropped a log chain in there with fresh gas and tilted back and forth, flushed, and repeated. Worked great. I wire wheeled some minor surface rust from the bottom outside of the tank and sprayed acid etch primer and painted silver.
Reinstalled the instrument cluster, glove box, radio, and glove box door. While doing this I noticed the heater control plate was loose, all 4 rivets were broken. So I pulled that assembly out and tore it apart. Already drilled out the rivets and will just use stainless button head bolts through the face plate. I dont really care if there are bolt heads visible, just want a solid assembly. I ordered new steel heater selector levers from GMC Pauls that are supposed to be unbreakable and will lube the cables when I re install.
One question however, I used an engine and fwd lamp harness from M&H that were already set up for HEI and internally regulated alternator, my original harness had another small harness from a separate hole in firewall (see firewall pic below, large black grommet covering this hole next to speedo cable) that connected to a small dark brown wire and then a larger gauge red wire ran to the front of the carb I think? Idle stop solenoid? (see carb pic, front left solenoid on carb) What is that and do I need it? Also another connection that ran possibly to trans? TCS wiring? Do I need these or can I discard? I don't think they're necessary but confused on what this harness controlled. What is the small brown wire coming from the engine harness plug? Any help would be great.
Old 09-04-2018, 06:57 PM   #112
72 tigger
72 tigger's Avatar
Making nice progress! Looks like you have a great shop to work in
72 tigger is offline   Reply With Quote
Old 09-05-2018, 10:15 AM   #113
Snake72
Snake72's Avatar
Thanks Tigger, the shop was my father in laws, every tool and piece of equipment you could ask for. I really need to clean up the parts boxes..
After doing some research, my mystery wiring harness that went into the firewall by speedo is the TCS harness. The wiring connected the idle stop solenoid on carb, TCS switch on trans, passenger side water temp sender to a relay inside cab and the fuse box/ign on plug. I'm tossing this whole system, not needed for my set up. Sounds like most TCS were unplugged soon after the trucks were bought anyway
Old 10-09-2018, 06:10 PM   #114
Snake72
Snake72's Avatar
Just a few small updates, repainted the dash with a blue that closely resembled the original darker blue dash, its gloss not matte but oh well.
Used the GMC Pauls heater control repair kit, worked awesome, well made product. My heater control panel backing plate rivets had all broken and the unit was loose so I drilled out the rivets and counter sunk some stainless allen head bolts. Put the new decals over top and looks great. Very solid and controls work smoothly.
Got the gas tank installed. Used a filler neck grommet from GMC Pauls, way better quality than the one from Brothers I previously bought. Grommet went on pretty well, lots of cuss words and some blunt push tools helped.
Installed new fuel sending unit, need a few hose connections and ready to add fuel and turn the key...then wait for whatever starts on fire...
Old 10-09-2018, 06:53 PM   #115
NewType72
NewType72's Avatar
Amazing attention to detail and I love the feedback on parts and what companies they were bought from. Excellent work my friend
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-10-2018, 09:20 AM   #116
RedRider
RedRider's Avatar
Can't wait to see this thing fire up, great progress.
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 10-10-2018, 08:55 PM   #117
cericd
cericd's Avatar
Looks great! Great progress!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 10-12-2018, 10:03 AM   #118
redneckgames
Looks great. Enjoyed catching up on the build. Keep it up.
redneckgames is offline   Reply With Quote
Old 10-12-2018, 02:41 PM   #119
cebra
Looking good, I love original restorations.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 10-12-2018, 03:11 PM   #120
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm loving it. Keep up the good work
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-15-2018, 09:01 AM   #121
Snake72
Snake72's Avatar
Thanks guys!
Old 10-18-2018, 08:07 AM   #122
35boulder
35boulder's Avatar
Just read thru your thread. Nice job and I too thank you for the reviews on your venders and their products.
35boulder is offline   Reply With Quote
Old 10-18-2018, 03:55 PM   #123
silvertonguedevil
silvertonguedevil's Avatar
Very cool build!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 12-10-2018, 10:40 AM   #124
Snake72
Snake72's Avatar
Made a little progress this weekend, only had a couple hours to work. Hooked up the battery and tested all lights and electrical. Everything works! Lights, turn signals, brake lights, tail lights, fan, dash lights etc. I went with LED dash lights and they are the perfect brightness. Have full 12 volts to starter, should turn over just fine. Need to add break in oil and antifreeze...and try to start!
This is the first sign of life the truck has shown in nearly 4 years, was great to see
Old 12-10-2018, 11:00 AM   #125
knomadd
knomadd's Avatar
That's awesome! Such a big milestone complete, I'm sure you feel quite a relief. Keep it up!
-Duane
