Old 04-29-2017, 05:20 PM   #101
pwrbrkpadguy
pwrbrkpadguy's Avatar
Re: What did you do to your truck today part IV
Picked up 2 6 lug 15x7 rallies from UNCLE on the 67-72 site. Just a short ride from work. These will tuck in real nice on the front and look better than the 8" rallies I put on after the disc brake upgrade I completed last month.
pwrbrkpadguy is offline   Reply With Quote
Old 04-29-2017, 08:21 PM   #102
Johns 66
Johns 66's Avatar
Performed surgery on mine....left me with a lot of questions....I posted a bunch in my build thread but here are some pictures
Johns 66 is offline   Reply With Quote
Old 04-29-2017, 09:18 PM   #103
rvrfoot
Installed my upper and lower arms. Drop spindles coil tie rods.Name:  DSCN0820.jpg
rvrfoot is offline   Reply With Quote
Old 04-30-2017, 05:40 PM   #104
Northwest Outlaw
Northwest Outlaw's Avatar
Got some free plywood that basically matched my "patina" look so i made a temporary bed until my papa and I can rebuild it the right way
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 04-30-2017, 08:13 PM   #105
jayoldschool
Moderator
Your upper ball joint hardware is in upside down. The bolts go in from the bottom, nuts on top.
Originally Posted by rvrfoot View Post
Installed my upper and lower arms. Drop spindles coil tie rods.Attachment 1647317
Attachment 1647318
jayoldschool is offline   Reply With Quote
Old 04-30-2017, 08:44 PM   #106
rvrfoot
Cool cpp installed them thay where ready too go in the box.
Old 05-02-2017, 05:31 PM   #107
verdell
verdell's Avatar
Installed a new tilt floor shift column. Ordered an led flasher for the turn signals that should arrive tomorrow..
verdell is offline   Reply With Quote
Old 05-07-2017, 09:42 PM   #108
Blue666(2)
Shrank my tank to fit the frame area between the rear axle & the hitch. Started with big square Suburban tank. Cut or 7 inches & rewelded the end cap back on. I'll clean with acid & use Caswell tank sealer to complete.
The new tank measures 26 x 20 x 11, and accepts a TBI fuel pump, should be about 22 gallons. It's 11 inches from the tank to the ground.
Blue666(2) is offline   Reply With Quote
Old 05-08-2017, 07:55 AM   #109
jbgroby
jbgroby's Avatar
Mounted the a new wiper motor in by Newport, it's 2 speed wiper and will be a much needed improvement. Straight in application, still need to run the wires.
jbgroby is offline   Reply With Quote
Old 05-10-2017, 03:16 AM   #110
Cooper197
Cooper197's Avatar
I installed the CPP front sway bar on my '66. Boy was that ever worth the money! Truck handles awesome!
Cooper197 is offline   Reply With Quote
Old 05-10-2017, 06:12 AM   #111
wolfsden
wolfsden's Avatar
Is your truck lowered?
1963 Chevrolet C-10
wolfsden is offline   Reply With Quote
Old 05-10-2017, 08:11 AM   #112
wolfsden
wolfsden's Avatar
Painted the white stripe and added the molding trim with 3M double sided tape.
I did not want to drill holes in my truck and the tape works great.
1963 Chevrolet C-10
Old 05-10-2017, 08:53 AM   #113
jbgroby
jbgroby's Avatar
Good idea on the tape, but I would be a little hesitant. Because when you drive 88 MPH, things happen......
Old 05-10-2017, 10:45 AM   #114
wolfsden
wolfsden's Avatar
I got the idea from a thread on this forum. Some of the members have had the trim installed with this tape for over 5 years with no issues even going through car washes.
I had to remove a piece that I installed wrong and had to use a heat gun to heat it up then I used a fishing line to pull between the truck and tape to remove that piece of trim and it took a lot of force.
Hopefully I won't lose any pieces of trim 😂
1963 Chevrolet C-10
Old 05-10-2017, 11:26 AM   #115
forestb
forestb's Avatar
88 MPH! That's faster than a speeding ticket. Or are you just trying to travel through time
forestb is offline   Reply With Quote
Old 05-10-2017, 11:42 AM   #116
Cooper197
Cooper197's Avatar
It is. 2.5" Drop spindles in the front and 3" springs in the back.
Everything clears just fine and the bar sits up high enough that my control arms are still the lowest point on the truck.
Old 05-10-2017, 12:12 PM   #117
jbgroby
jbgroby's Avatar
Time travel
Old 05-10-2017, 01:01 PM   #118
wolfsden
wolfsden's Avatar
I would like to install those sway bars on my truck as well I have 2 1/2 inch drop spindles in front and bagged it's about a little over 7 inch drop from stock do you think they would work for me?
1963 Chevrolet C-10
Old 05-10-2017, 10:41 PM   #119
rvrfoot
I just installed my sway bar.Name:  DSCN0830.jpg
Old 05-11-2017, 02:20 PM   #120
Northwest Outlaw
Started building a radiator shroud for my '61 with a 3 core Champion Radiator and mechanical fan on 350 small block. Using galvanized steel roof flashing and aluminum rivets.
Old 05-11-2017, 02:25 PM   #121
The Rocknrod
Moderator
The Rocknrod's Avatar
Good work outlaw. It amazes me that no one makes actual shrouds, just block off plates with fans on them.
Old 05-11-2017, 04:17 PM   #122
forestb
forestb's Avatar
I don't have a photo right now but the fan shroud that I got from US Radiator is more than a block off plate. It is an actual shroud.
Old 05-13-2017, 04:51 PM   #123
bpmcgee
bpmcgee's Avatar
I installed the rebuilt fuel sender, got the tank back in place, and installed the new fuel pump and rebuilt carb.
And I took a video of it running! Video link
bpmcgee is offline   Reply With Quote
Old 05-14-2017, 05:04 PM   #124
DPowers
DPowers's Avatar
Had installed my mirrors last week. Finished cleaning it up.
DPowers is offline   Reply With Quote
Old 05-14-2017, 06:58 PM   #125
allchevy58
allchevy58's Avatar
Scraped off the grease and dirt and pressure washed engine compartment.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
