01-12-2021, 01:45 PM | #101 |
Almost Satisfied
Re: 1972 Chevy Crew Cab “Denali”
I love this truck! Have I said that before?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-12-2021, 08:38 PM | #102 |
Awesome work on the passenger seat tracks man. Whoever gets the privilege of sitting in that seat better put that thing to use a whole bunch.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-12-2021, 08:44 PM | #103 |
01-18-2021, 08:10 AM | #104 |
Nothing exciting really to update the build with... got the rest of the crossmembers installed into the frame where I thought necessary. I mounted a 2wd automatic trans crossmember upside down after my double trans crossmember with skid plate. I flipped it upside down for driveshaft clearance. Next I tried to copy the crossmember between the rear spring hangers. Super happy with how that came out.. I bolted that in just about between the rear cab mounts. Trying to keep the underside looking factory. Coming out decent..
Posted via Mobile Device |
01-18-2021, 12:12 PM | #105 |
Very impressive fabrication!
71 C10 72 K20 72 K10 Super Kirk |
01-24-2021, 06:48 PM | #106 |
You have some mad fab skills, and a great shop space. I'm jelly!
Cheers, D.
'72 K-20 Frankentruck '68 Beaumont Wagon '05 Chevy G2500 Camper "Tiki Van" '22 Honda CB500X Island-Hopper |
01-24-2021, 07:46 PM | #107 |
Moved up to the motor compartment to tackle some things up front. First step was switching from a long water pump to a short water pump so I can use all the factory 1972 brackets. Took me a bit to figure out all the AC compressor brackets but I got everything bolted up and looking right. Still have to change the power steering pulley as this one is bent. I got one on the way. Nest step is to get some headers to fit up and hopefully clear my 4 speed Z bar linkage.
01-24-2021, 07:56 PM | #108 |
Had some BB headers laying around but they hit the frame everywhere so I spent about 2 hours online looking for some and reading others build threads about what they used. I settled for some hookers (520-2463) from jegs. First step was getting the pivot ball and Z bar working. Had to make a bracket to bolt onto the block and then tap a hole 2” back and thread the pivot ball into... headers came in this week so I was excited after work to bolt them on. Passenger side fell on. No dents in the pipes or grinding on the frame. Drivers side cleared the frame well but of course they hit the Z bar. So I guess I’m modifying the rear primary tube to clear it. After a couple hours and a piece of tubing from pep boys I got them clearing the linkage. Touched them up with some high temp paint for now but I thinking about wrapping them when the time for final instal comes.. I did grind the frame about a 1/4” at one spot simply to make final install easier..
01-24-2021, 08:02 PM | #109 |
Bolted up the new rad support and got my OEM fenders bolted on for mock up. Had to shim the cab up front to get the gaps tighter. Dropped in a used 4 core and a BB shroud to check clearances. Have to do some trimming on the shroud so it drops down about a 1/4”. The fan clears but I’d like some more gap on the bottom side. My trim order from Mar-k came in this week as well. Was super excited to get that stuff. Quality seems top notch and was packaged very well!
01-24-2021, 08:04 PM | #110 | |
01-24-2021, 08:05 PM | #111 |
01-28-2021, 06:36 PM | #112 |
Dig out the old sidewinder winch I picked up last year and started to fab up some mounts. Rear frame mount and rear winch mount were still attached to the winch so I started there. I moved the winch as far back as possible to hopefully keep the bumper trimming at a minimum. Started with a 2.5” angle iron for the front. After some cutting and welding we have a front winch mount. Got a bumper out of the scrap pile to practice on the notch. After a few hours I got a notch I was happy with.. Now I can say 3 hooks are better than 2 😎
01-29-2021, 11:19 AM | #113 |
Very nice.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-08-2021, 11:54 AM | #114 |
Started playing with some trim this past weekend! Been waiting a few years for mocking up some trim on a shortbed crew cab. Love the look so far!
02-08-2021, 12:38 PM | #115 |
Almost Satisfied
I like the trim, but look at those new shoes!!
02-08-2021, 12:42 PM | #116 |
02-08-2021, 03:31 PM | #117 |
You are just scooting right along. It is coming together nicely.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-15-2021, 12:46 PM | #118 |
Got both the upper and lower trim shortened up for the third and fourth doors over the weekend..
02-15-2021, 05:34 PM | #119 |
Looking real nice.
02-23-2021, 08:07 AM | #120 |
Got all the trim holes drilled on the passenger side. Dry fit upper and lower trim and rolled the truck outside to stand back and see how straight the trim was... it was nice to take advantage of that white background as well. One pic is the factory 3rd door with my shortened trim installed. Pleased with its outcome. Onto the drivers side.
02-23-2021, 08:18 AM | #121 |
Looks awesome. I really like this!
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
02-23-2021, 10:07 AM | #122 |
Almost Satisfied
You are clearly in over your head here. I think you need to stop while you are ahead and just sell me this project so I can then be in waaaay over my head! LOL This build is so cool and going to be amazing. Love the trim work. Keep it up and please post a pic every day or so
02-23-2021, 10:19 AM | #123 | |
02-23-2021, 09:18 PM | #124 |
Looks amazing Clayton! What a difference a little buffing makes on that old paint
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
02-23-2021, 09:31 PM | #125 |
That thing is awesome. I love diesel power but I'm glad to see a BBC in it.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
