Old 01-26-2020, 11:46 AM   #101
lukeembry
Re: 85 C10 LT/6L80 Frame off build
Originally Posted by SCOTI View Post
I looked @ your build thread on LS1.com. Kind of figured you were going bigger than the L83 since you already had a 6.0.
I highly recommend swapping out your rag-joint set-up for a Cherokee XJ shaft swap. I chimed in on pg.2: http://67-72chevytrucks.com/vboard/s...=505196&page=3
Here’s a pic of the steering shaft I built. stainless 3/4”DD and powder coated 1”DD shafts. Used Borgenson stainless u-joints with the lower having the rubber dampener
lukeembry is offline   Reply With Quote
Old 01-26-2020, 11:21 PM   #102
SCOTI
SCOTI's Avatar
Looks clean. Hard to beat a clean satin black/SS combo.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-31-2020, 09:45 PM   #103
marcoman
Such beautiful work and so inspiring. Also, what kind of lighting do you have, because it looks color-balanced, which helps when viewing things "correctly?"
marcoman is offline   Reply With Quote
Old 01-31-2020, 11:57 PM   #104
mongocanfly
Post Whore
mongocanfly's Avatar
Really nice build...oh so clean...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-02-2020, 11:01 PM   #105
lukeembry
Thanks! Nothing special, I’m just getting lucky with lighting I guess. I have a really bright garage with LED ceiling lights and grey walls and floor.
Old 02-02-2020, 11:02 PM   #106
lukeembry
Thanks! Keep in touch
Old 02-02-2020, 11:36 PM   #107
lukeembry
Lots of updates in the next few pics, finally got around to getting it painted. I used Tamco basecoat and clear, pretty happy with the results, it had been about 4 years since I had sprayed a vehicle. I remember why I quit! once painted I let it rest in the heat for about 3 days and then started sanding the clear. I used 800,1000,1500,2000,3000,5000,8000 water paper and when finished I had a nice semi-gloss finish that was fairly easy to buff out to a great shine.
Old 02-02-2020, 11:48 PM   #108
lukeembry
vintage air going in and that awesome looking Dewitts radiator
Old 02-03-2020, 09:40 PM   #109
MikeB
MikeB's Avatar
Smile Re: 85 C10 LT/6L80 Frame off build
Beautiful truck, before and after. Probably more money there in brakes, tires, and wheels than I have in my entire truck! More power to you.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-04-2020, 10:40 AM   #110
rodstored-72
chevy truck fan
rodstored-72's Avatar
luke,
Nice progress and a great eye for the little things. I was wondering if you have any pics of the firewall after the V.A. install? I would be interested in how the lines look going through the firewall? also how smooth did the install for the unit go for you?
rodstored-72 is offline   Reply With Quote
Old 02-04-2020, 09:15 PM   #111
lukeembry
Old 02-04-2020, 09:29 PM   #112
lukeembry
Originally Posted by rodstored-72 View Post
luke,
its a pretty easy install, if you have a friend to help hold the inside box it helps. its a nice upgrade to get rid of the cables and huge duct work under the dash, it allowed me to mount my ecm and other controls behind the dash and still have room. the variable speed fan motor is nice but they do create alittle more noise due to the fan motor being inside the cab but its not bad.
Old 02-04-2020, 09:37 PM   #113
lukeembry
inside of bedsides and wheel tubs cut and buffed, I doubt ill cut and buff the floor. starting to look like a truck, cleaning all the buffing compound out of every crack before installing trim and bodyside molding. got the fuel tank vents installed with some simple brackets I made hidden up in the bedsides.
Old 02-05-2020, 04:02 PM   #114
rodstored-72
chevy truck fan
luke,
THANK YOU!! exactly what I was wanting to see. My install looks very close to yours , but not near as clean. I know what you mean about a pair of hands. my nieghbor came over to lend a hand to hold the lines while I installed the hoses (wife tried)-but I was too strong for her... Curious: did you use the plate on the firewall due to factory wall "thinness"? The pics also confirmed my heater line connections, I was not sure which lines connected to the LS motor?. lastly what "vent" are you using for the gas tank(s)? If willing to share? I might try to copy the idea as well??
Thanks!!
Old 02-05-2020, 10:22 PM   #115
lukeembry
luke,
Thanks!!
since this truck was a factory air truck there is a big hole behind the plate, so id rather use the supplied plate than weld the firewall up.
the fuel tank vent is sold by Holley part #19-174 I made a bracket and used one on each fuel tank.
Old 02-05-2020, 10:30 PM   #116
lukeembry
Earls Ultra-Pro trans cooler installed along with a power steering cooler.
Time for some interior work, I picked up carpet and lower door carpet from ACC, they have the OE colors and an excellent fitting product.
Old 02-05-2020, 10:37 PM   #117
lukeembry
one thing I knew I wanted was a nice modern sound system that fits like factory and no sub box behind the seat. I went full Memphis for factory size speakers with a 200 watt amp for highs and a 10" powered Memphis sub for under the seat.
Old 02-06-2020, 01:33 PM   #118
Mattchu60
Your Truck looks extremely good - this is a top quality build!
2 questions - on the paint lines for the 2 tone cab roof - I'd be curious if you could show some pictures of where you made the tape line (I'm thinking of a white roof and don't have any examples of where the paint dividing line should be).
2nd question - those front dash speakers look nice - have you tried fitting the dash yet? I'd be interested if they fit without hitting the dash pad. I put some aftermarket ones in (different brand) and they were too tall.
Mattchu60 is offline   Reply With Quote
Old 02-07-2020, 10:05 PM   #119
lukeembry
Thanks! I will get you some pics of the 2-tone
I did have issues with the speakers, I had forgotten until you asked. I ended up buying another set of Memphis 3.5” that the center didn’t stick out on.
Old 02-10-2020, 08:38 PM   #120
MHarvey
Looks great Luke! Keep up the good work!
MHarvey is offline   Reply With Quote
Old 02-11-2020, 10:28 AM   #121
rodstored-72
chevy truck fan
Luke,
Enjoying the updates... was wondering if you have a pic or two of the area around the power steering connections? I am in the process of trying to run the pwr steering lines along the brake lines & not sure "the order" that the lines go in? IE: the brake lines over/under the power steering lines.... if too much trouble or time, no worries.....
a really beautiful truck!!!!
Old 02-15-2020, 05:08 PM   #122
lukeembry
Luke,
Thanks man, here’s a pic how I did mine. I do have a ps cooler mounted out front.
Old 02-15-2020, 05:15 PM   #123
lukeembry
Here’s a couple pics. I really only have one paint lance since all the others are under the rear cab trim and drip rails.
Old 02-15-2020, 05:53 PM   #124
SCOTI
SCOTI's Avatar
So.... What happened to drive the fan/shroud switch-a-roo?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2020, 10:12 PM   #125
lukeembry
The last pic is the fan/shroud that Dewitts uses. It works fine as I’ve used that combo before. I wanted the shroud to cover the entire radiator and some super powerful fans in case I ever need them. I also wanted a shroud that would bolt onto the OE radiator top plate.
