Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-31-2020, 12:52 AM   #101
First c10
First c10's Avatar
Re: Creamsicle: My 70 K10 SWB is about to get sweeter
Hey Dan. It’s the little things that most people won’t see that set it off. Looks good.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-05-2020, 08:33 PM   #102
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Finally started working on my wiring. I put it off, and put it off, but finally realized that it won't get done by itself. My harness wiring is completed, but I needed to get started on my fuse panel wiring. I'm using the AAW Classic Update kit. I labeled all wires with marker and painter's tape, so I knew where everything was going. Then I started removing the wires that I didn't think I'd need. I also re-pinned a lot of wires and relocated them where I wanted them in the harness. I hope this works out!
AAW harness layout
Re-pinning the harness
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-05-2020, 08:34 PM   #103
rsavage
rsavage's Avatar
Nice work as usual Dan.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-11-2020, 09:06 PM   #104
derotoreut
derotoreut's Avatar
More work on the wiring. Got the AAW fuse box installed. Now it's time to make all the connections.
~ Dan
Old 04-11-2020, 09:44 PM   #105
derotoreut
derotoreut's Avatar
I'm installing Dakota Digital RTX gauges, so I need to mount the main module. I'm also putting in a GPS module and OBDII interface (BIM-01-2). Instead of just shoving them under the dash I wanted to mount them neatly. My plan was to use the ABS firewall insulator from Quiet Ride Solutions as a mounting surface. The ABS is really sturdy, so it'll make a great mounting surface. I decided to use rivet nuts in the firewall insulator to mount the modules.
I started with the OBDII interface module by testing where I wanted it.
I then taped the firewall insulator in order to mark my holes for the rivet nuts. I couldn't see any pencil marks on the black firewall, so the painter's tape works great.
This is one of my rivet nut tools. This one is smaller and fits under the dash great.
First rivet nut is installed.
Both rivet nuts are in place and the BIM OBDII module installed. Stainless button heads used of course. Lol Now I need to install the other modules.
~ Dan
Old 04-13-2020, 07:45 PM   #106
derotoreut
derotoreut's Avatar
More Dakota Digital module mounting:
Put in a couple more rivet nuts to install the main control module.
More rivet nuts for the GPS module.
Installed the GPS-50-2 interface module.
Both interface modules installed.
~ Dan
Old 04-19-2020, 10:20 PM   #107
derotoreut
derotoreut's Avatar
More wiring: So I bought a power distribution block on Amazon to use as a ground block. When it arrived, I didn't realize it was so big. I should have paid more attention to the size before I made the purchase.
Name:  Terminal Strip.jpg
In order to use it I decided to cut it in half. I replaced the top bolt with a stud that I drilled and tapped into a raised section of the firewall, so it's thoroughly grounded. I confirmed the continuity with an ohm meter.
Connected all wire grounds to the bus bar.
Finished product. It worked out pretty well.
~ Dan
Old 04-22-2020, 01:16 PM   #108
DWilbur
Your just a head of me with wiring I'm finish up some work under the hood then start on wiring I will be fallowing your thread. where did you get the rivet nuts.
DWilbur is offline   Reply With Quote
Old 04-22-2020, 08:53 PM   #109
derotoreut
derotoreut's Avatar
I have both the Astro Pneumatic 1442 and 1443B tool kits. Both sets come with some rivet nuts. I also ordered some stainless rivet nuts off of Amazon. You can find them on Ebay too. They are great tools. I set rivet nuts for my seats, transmission cooler mount, Dakota Digital modules and more.
~ Dan
Old 05-04-2020, 10:03 AM   #110
MDPotter
MDPotter's Avatar
I just read through your build, very impressive. I can tell you've put a lot of thought and planning into it and it shows!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-04-2020, 12:39 PM   #111
derotoreut
derotoreut's Avatar
Thank you. I appreciate it very much. I'd also like to thank you for your input and help outside of this build thread concerning LS swaps and wiring. You've been a great help.
~ Dan
Old 05-05-2020, 09:44 PM   #112
derotoreut
derotoreut's Avatar
With the COVID-19 stay-at-home orders I've been pretty busy with the truck. I made up some lines to go between the Vintage Air evaporator and the bulkhead fittings located down inside the fresh air vent.
~ Dan
Old 05-05-2020, 09:50 PM   #113
derotoreut
derotoreut's Avatar
More wiring updates: Instead of hard wiring my VA trinary switch, I decided to install a 4-way weather pack connector.
First weather pack pin installed.
Finished connector. Just in case I have to remove the trinary switch for some reason.
~ Dan
Old 05-05-2020, 09:58 PM   #114
derotoreut
derotoreut's Avatar
I made up a couple of fuel lines for the supply and return from the Corvette style filter/regulator. I used PTFE tubing and the proper fittings. Not so sure I like how these fittings connect to the filter/regulator. I may change my mind on this.
This is the Wix 33100 filter/regulator.
Made a supply and return line for connection at my Walbro pump inside the Rick's tank.
I don't really care for all these connections on the filter/regulator.
~ Dan
Old 05-06-2020, 07:03 AM   #115
rsavage
rsavage's Avatar
You are doing really nice work Dan. Super clean.
1961 C1 Corvette
2021 Durango RT 5.7
Old 05-06-2020, 09:24 AM   #116
MDPotter
MDPotter's Avatar
Nice work on that weatherpak connector. On the fuel line fittings, there is a type of fitting that is supposed to be more secure than the the plastic clips - it's like a c-clip that keeps the fitting secured. I'm running the plastic clips and haven't had an issue though. If you're interested, Earl's (Holley) makes them: https://www.holley.com/products/plum...arts/751166ERL
Old 05-06-2020, 09:45 AM   #117
derotoreut
derotoreut's Avatar
Thanks Rick. That means a lot coming from the May 2020 ToTM winner. Congrats!
~ Dan
Old 05-06-2020, 09:52 AM   #118
derotoreut
derotoreut's Avatar
The fittings I'm currently using are the C-clip type. I think they would be OK, but I think I'm going to go with this filter/regulator from Speedway. It has 6AN fittings already installed, which will minimize the potential for leaks.
https://www.speedwaymotors.com/Speed...SI,375656.html
Name:  Speedway LS filter regulator.jpg
~ Dan
Old 05-06-2020, 11:37 AM   #119
MDPotter
MDPotter's Avatar
I didn't know those existed, that's pretty cool. I'll have to remember that when I replace mine someday.
Old 05-10-2020, 10:29 PM   #120
derotoreut
derotoreut's Avatar
Worked on my upper radiator hose. I've been trying to find an off-the-shelf hose. I've tried a number of hoses, but have been unable to find anything that fits with my LS radiator. I ended up buying a 1-1/2" 45-degree hose piece and a 1-1/2" to 1-1/4" 45-degree piece. I put the one piece on the radiator and the other on the engine. With tape around each section, I marked the mating points. I then cut a 6" long piece of 1-1/2" diameter stainless steel tubing and put these together. I then used a Gates Power Grip, shrink clamp to hold the pieces together. Worked out pretty good.
Both hose sections were installed and the mating points were match-marked with tape and marker
I installed a 6" piece of 1-1/2" stainless steel tubing inside the hoses, keeping the match marks in line.
I used a Gates Power Grip shrink clamp to hold the two sections together. The shrink clamp part number is 32948. It fits 1-3/4" to 2" diameter.
Make sure that if you don't want to see the markings on the clamp that you clean them off before you heat shrink the clamp on. If you try to clean it afterwards, the lettering won't come off.
Final result fit perfectly!
~ Dan
Old 05-11-2020, 02:50 AM   #121
Richard
I saw those shrink clamps recently, they look nice. Carl at Vaporworks was using them on his 68 Camaro. Got my PWM fuel pump controller from him for the factory ZL1 fuel pump I am using in my build.
Richard
Old 05-11-2020, 10:16 AM   #122
DWilbur
What are you doing about the steam vent. Some guys are tying it into the upper hose.
Old 05-11-2020, 10:21 AM   #123
derotoreut
derotoreut's Avatar
If you look on the last picture showing the radiator you'll see there are two small open NPT ports. The one above the radiator hose is 1/8" NPT, which is for my overflow tank. The one to the right of the radiator hose (at the same level) is 1/4" NPT steam line connection. I plan to use that port for my steam line.
~ Dan
Old 05-11-2020, 02:52 PM   #124
First c10
First c10's Avatar
Wow I am going to look into those clamps. I am curious how they hold up to the pressure.
Project is looking good.
GO GO!!!
Old 05-11-2020, 03:17 PM   #125
derotoreut
derotoreut's Avatar
They work great and hold up well. They are tough to remove though. Not like just taking off a hose clamp. You have to cut them in order to remove them. They make a special cutter so you don't damage your hose. I never bought the cutter, but might not be a bad idea. Right now I'm only planning on using them in areas that I know I won't have to take back apart. Once I do my start up and get some drive time in, then I'm planning to use them on my upper and lower radiator hoses.
~ Dan
