Old 05-21-2020, 10:12 PM   #101
clay68c10
clay68c10's Avatar
Re: ClusterTruck; because that’s what it is
The base of the pillar was fine on the other side, but all the rocker was totally rotten. This side was the opposite. Thankfully I had the whole kit, so that covers it all. I only used what I really needed since the shapes aren't really spot on.
Anyway, here it is.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-21-2020, 10:18 PM   #102
clay68c10
clay68c10's Avatar
At some point, this truck got a de-luxe house carpet install. No glue was used, but about 40 little screws. That was fun.
13 Tahoe LTZ
Old 05-21-2020, 10:23 PM   #103
clay68c10
clay68c10's Avatar
Here's something I've found helpful when cutting out metal in corners. A Dremel with a flex attachment can get in the corners way better than the 4" cut wheel. It takes a while, but you don't have all the extra cut damage from the big blade.
13 Tahoe LTZ
Old 05-21-2020, 10:28 PM   #104
clay68c10
clay68c10's Avatar
And finally, the rot is out. Time for some fresh metal fitting.
I like to creep up on fitment, so I cut the pieces slightly oversize and use a flap wheel to get it really close. I tack when the gaps are looking pretty good. It seems there are always some tight gap spots, and I open them up with the cut off wheel, either the 4" or the Dremel.
Now we'll see if my daughter wants to do some tacks this weekend. There's definitely no shortage of opportunities.
13 Tahoe LTZ
Old 05-21-2020, 11:20 PM   #105
Richard2112
Richard2112's Avatar
Great progress, looking good.
Richard2112 is offline   Reply With Quote
Old 05-22-2020, 12:09 AM   #106
SCOTI
SCOTI's Avatar
Mad props for keeping the young-guns inluded. I sure wish I did more w/my step daughter.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2020, 11:05 AM   #107
MDPotter
MDPotter's Avatar
Rust repair on the cab is a time-consuming process, I didn't particularly enjoy it. But it's satisfying when you're done to know that your cab is rust free and solid.
And great that your daughter wants to get involved. How many girls her age learn to weld? Or even boys her age?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-25-2020, 08:21 PM   #108
Chevys4life
I'm in Scrbd!!!!
Chevys4life is offline   Reply With Quote
Old 06-05-2020, 11:34 AM   #109
clay68c10
clay68c10's Avatar
Thanks all, I keep plugging away at it when time allows.
The kids think it's interesting but in the 11 & 7 year old way. Once it looks more like a truck and/or their driving years are on the horizon it will probably be a different story.
I try to expose them to non-screen activities as much as possible. You can "build" all sorts of cool things in Minecraft, but it's not real. That's a distinction that I think a lot of younger kids don't quite get, mine included sometimes.
13 Tahoe LTZ
Old 06-05-2020, 11:37 AM   #110
clay68c10
clay68c10's Avatar
Here's some of the last couple weeks progress.
In the above floor pics, you can see a thin triangle gap. Yes that is a total screw up on my part. I eyeballed that portion of the floor when I cut it, instead of measuring it. DOH
So I got to reinstall the portion I cut out. I generally keep my cut out pieces just for reference. This time it came in handy.
13 Tahoe LTZ
Old 06-05-2020, 12:10 PM   #111
clay68c10
clay68c10's Avatar
The kids were around and came to check it out. My son preferred to play with some cool sticks he found that look like guns (I remember those days). My daughter decided she wanted to do some tacks for about 20 minutes. That was enough for her at that point. I get it, a zillion tack welds do get old.
13 Tahoe LTZ
Old 06-05-2020, 12:16 PM   #112
clay68c10
clay68c10's Avatar
She did a pretty good job and I finished up the rest.
Next up was the last floor portion. Nice to see it coming together finally.
I started with some scrap and used a hammer and sandbag to get the shape close enough to work. Get the gaps close and then tack tack tack.
13 Tahoe LTZ
Old 06-05-2020, 12:22 PM   #113
clay68c10
clay68c10's Avatar
As a helpful side note, during the fitting and welding the gaps don't always stay consistent. I keep that dremel tool handy and use the cut-off wheel on it to get the gaps opened back up. I prefer to creep up on the dimension of my patch so it doesn't turn out too small. I can always open up the welding gap if I need to. Closing up a too-large gap isn't much fun.
13 Tahoe LTZ
Old 06-05-2020, 12:24 PM   #114
cornerstone
cornerstone's Avatar
I did the same exact thing. Gave myself a stiff slap to the forehead upon realization.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-05-2020, 12:29 PM   #115
clay68c10
clay68c10's Avatar
^^I hate it when I do that. I created at least an hour more work for myself.
Here's an example of my fitment technique with the floor support. I kept the old one I cut out and used it for a template. I cut the new one a little big and flap-wheeled it to the right size. As it got closer to the right size, each time I fitted it I bolted it in. It shifts around a fair bit when you tighten up the fasteners and that can give you the too-big gap problem. This is what I wanted to avoid.
13 Tahoe LTZ
Old 06-05-2020, 12:35 PM   #116
clay68c10
clay68c10's Avatar
And here it is done. I drilled the little hole in it for my wax application afterwards.
Speaking of drilling, you have to drill the bolt holes. I'm ok with that since it's a re-pop and I doubt they would be in the right place.
13 Tahoe LTZ
Old 06-05-2020, 12:44 PM   #117
clay68c10
clay68c10's Avatar
At this point, all that's left underneath is the fender tab, rear floor brace, and some misc. tacs in the couple of thin spots here and there along the long floor seam. There is a light at the end of the tunnel.
I got this far last night and called it beer:30. The rear brace was a little harder to fit but the gaps are decent. Nothing I can't work with.
13 Tahoe LTZ
Old 06-10-2020, 07:53 PM   #118
mongocanfly
Post Whore
mongocanfly's Avatar
I don't go thru the 67-72 section much because theres so much going on here that I cant keep up with it all...but your doing some good work,,,and kudos for having the kids involved...I vividly remember as a kid helping my Dad work on his trucks, tractors and cars
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-23-2020, 10:04 PM   #119
clay68c10
clay68c10's Avatar
Thanks Mongo, it's a long process but fun and challenging.
I got a little more done here and there. The floor is pretty much done!
13 Tahoe LTZ
Old 06-23-2020, 10:08 PM   #120
clay68c10
clay68c10's Avatar
It's sitting back right side up on the casters!
Of course, the motivational shot of the panels just set on it.
And a back side shot of the corner. I chose to cut it here so I could get to the back side of the weld and make sure it doesn't have any pinholes. It wasn't real crusty up this high, but I'd rather be able to get to both sides of the weld seam.
13 Tahoe LTZ
Old 06-28-2020, 09:56 PM   #121
clay68c10
clay68c10's Avatar
The corner is cut and fitted. I got some welding done on it. I’ll need to open up my gap for the rounded edge area. Maybe this week. Or after the 4th. We’re going to Wyoming for the holiday, so camping, hiking, and shooting will be the plan!!
13 Tahoe LTZ
Old 07-05-2020, 12:32 AM   #122
doowoppwer
subbed
doowoppwer is offline   Reply With Quote
Old 07-10-2020, 05:59 PM   #123
clay68c10
clay68c10's Avatar
Back from Wyo, had a great long weekend.
Had some more progress this past couple of days. The cab corner is pretty much in and done.
The usual zillion tac welds.
13 Tahoe LTZ
Old 07-10-2020, 06:08 PM   #124
clay68c10
clay68c10's Avatar
At this point, I like to start grinding the welds down and look for pin holes.
I'm a fair welder, but very realistic about how this goes. The gap isn't always perfect, the metal isn't always spotless, my welder is a decent one but not some hi-zoot machine. And my technique/work angle/eyesight isn't perfect every single tac either.
That said, get the brightest light you have and start shining it thru from the rear. I usually find a couple of pin-points to fix.
When I do this, I make sure to trim the "ball" off the end of the welding wire EVERY time I tac. This is the time to get those pin holes filled, and that pointy wire will get the heat in there better.
Definitely use a sharpie to mark them, you can't see em without the light, so I can't find them again unless I mark them. Then grind and repeat. Maybe you missed one and now is the time to get it done.
13 Tahoe LTZ
Old 07-10-2020, 06:16 PM   #125
clay68c10
clay68c10's Avatar
The bottom curve of the corner was a little off on this side, same as the other. I got it shaped up and put in a tiny tac underneath just so it wouldn't move around. Prior to this little tac, it did shift a little. I wanted it to stay put while I was putting heat into my upper seam. I'll put a couple more on the bottom when I tip the cab up for (hopefully) the last time and do my undercoat/wax.
13 Tahoe LTZ
