Old 12-14-2020, 05:08 PM   #101
biketopia
Re: Doing LS Swap - I have no idea what I'm doing!
Yup! are you setting in for good or are you pulling it back out? I'd get the old broken hardware out of the head before putting in chassis for the final time.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-15-2020, 10:09 AM   #102
EagleChief
EagleChief's Avatar
Hopefully it is going in place and staying. I'd rather not pull the motor back out after I get it in there. But, maybe I need to?
What broken hardware are you talking about?
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 12-15-2020, 10:13 AM   #103
ls1nova71
ls1nova71's Avatar
I think he's talking about the broken exhaust manifold bolts. Those are way easier to do outside the truck.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-15-2020, 11:55 AM   #104
EagleChief
EagleChief's Avatar
Gotcha. I am planning to pull the exhaust manifolds,and the a/c, off before I put the motor in. After reading a lot of threads, neither one seem to fit as it is. So, for the time being, I'll go without a/c, and look for different option on the exhaust.
Old 12-15-2020, 02:32 PM   #105
biketopia
Yup, was referring to the broken manifold bolts still in the head, much easier to work on with it in front of you, not sprawled out in an engine bay. .
Old 12-16-2020, 09:21 AM   #106
EagleChief
EagleChief's Avatar
So, went to measure my frame rails last night. This never even registered that something was different. But, I realized that the frame rail has been "adjusted" to make some clearance. Don't know how they did this, or why, but maybe it'll give me some room to keep the a/c?
Old 12-16-2020, 09:39 AM   #107
Thealien
Thealien's Avatar
That bend in the frame is factory and if the engine is in just the right place. the AC compressor fits nicely there.
Old 12-16-2020, 11:10 AM   #108
ls1nova71
ls1nova71's Avatar
Yep, I'm pretty sure that bend in the frame is for fuel pump access on original engines, they're all that way.
Old 12-16-2020, 11:54 AM   #109
EagleChief
EagleChief's Avatar
OK. Good to know. Thanks, guys.
Old 12-22-2020, 12:02 PM   #110
EagleChief
EagleChief's Avatar
Looking at this oil pan kit from Jegs: https://www.jegs.com/i/GM+Performanc...QAvD_BwE#qaTab
Anyone used it, or know for sure if it will fit in the trucks?
Old 12-22-2020, 01:45 PM   #111
gmc684x4
I would set my engine in place first and see how low the truck pan hangs down then look at pan dimensions to see what will fit better
Placement how far forword or back and how high the engine sits will all play a large factor on which pan you will need
Give two strangers the same c10 and the same ls motor chances are both trucks will have different placement of the engines needing different clearances for the oil pan
gmc684x4 is offline   Reply With Quote
Old 12-22-2020, 02:09 PM   #112
EagleChief
EagleChief's Avatar
Well, by my estimates (took some rough measurements last night), the current pan drops below the crossmember about 2.5"-3". Now, a normal truck height, that might be ok. But, my truck is lowered 3.5" in front, 5" in the rear.
I don't really want to put the motor in to see if it will work, then have to take it back out and order new parts. I want to have it ready to go, install the motor, and be done with it. I'm borrowing an engine hoist that I need to get back to it's owner, and have to have help and/or guidance putting the motor in.
Old 12-22-2020, 03:53 PM   #113
99_Sierra
99_Sierra's Avatar
Originally Posted by jjzepplin View Post
I just bought a 6.0L LQ9 for $375. I cringe when I have to spend that much on a fuel pump or tank. There has to be a cheaper way. I am leaning into using a stock fuel pump but retro fitting into my existing tank.
Here are snapshots from a post I read on facebook. I think I am going to go this route on my swap.
99_Sierra is offline   Reply With Quote
Old 12-22-2020, 07:41 PM   #114
ls1nova71
ls1nova71's Avatar
I've used that pan in a couple of trucks. I make my own engine mounts, so take that into consideration, but it usually hangs down roughly 1/2" below the crossmember. That pan is about an inch to inch and a half or so shallower than the stock truck pan. You also won't be able to get both bottom bellhousing bolts to bolt into it, which is fine, so don't freak out about that.
Old 12-22-2020, 07:42 PM   #115
ls1nova71
ls1nova71's Avatar
Had a friend do this years ago, the noise was terrible! You couldn't put enough insulation on the tank to not hear it even with the truck running. But if you are fine with that, it will work.
Old 12-22-2020, 09:15 PM   #116
kev2809
low n' slo
kev2809's Avatar
from what ive been reading, the Cadillac cts-v pan is the best bet for lowered trucks. thats probably what i will end up using since mine has air suspension
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-22-2020, 11:10 PM   #117
gmc684x4
The other good pan is the holley pan or its fleabay knock off lots simaler to the fbody pan but the sump forward is shorter
The muscle car pan is deeper then the fbody pan
Personally I will set it in place and order from there or just go with the holley pan which is like the fbody pan 2.0
Old 12-23-2020, 09:10 AM   #118
biketopia
The f body or one of the holley (or copy) swap pans is your best bet for fitment. I don't know who said the CTS-V pan was best, it's almost an inch deeper than the F-body. I'm pretty sure I've posted this here before, but here is a great link with all the pan dimensions. https://www.improvedracing.com/gm-ls-oil-pan-dimensions
Old 12-23-2020, 09:51 AM   #119
kev2809
low n' slo
kev2809's Avatar
its not like im making it up. ive personally havent used it, but its all over the board as an option for lowered trucks.
http://67-72chevytrucks.com/vboard/s...hlight=ctv+pan
-_--_--_ _________
Old 12-23-2020, 10:28 AM   #120
ls1nova71
ls1nova71's Avatar
The CTS-V pan is closer in physical shape to an old small block, thats why it fits well. The F body pan, while not deep, has a very long sump which requires the engine to be set back further.
Old 12-23-2020, 10:48 AM   #121
biketopia
I stand corrected.
Old 12-23-2020, 12:31 PM   #122
EagleChief
EagleChief's Avatar
You have shared that link with me. It has given me a lot to think about. Size wise, it looks like the Holley kits are the way to go. Seems like they have the lowest profile out of those options.
I just didn't want to have to shell out any more money. But, I guess that would happen if I bought the wrong kit/setup, then had to change it out for another one due to it not fitting, or hanging down too low.
Old 12-23-2020, 02:28 PM   #123
Joemomma1
Joemomma1's Avatar
Is removing the front end an option? Otherwise I'd say plan on pulling multiple times for clearances. There are some patterns forming here that you should avoid. The truck pan will work, avoid buying parts ahead of time and you're going to spend more money than you wanted. That's just what it is. Set it in as is then identify what you'd like to adjust. GET IT IN AND GET IT RUNNING. This is a really simple swap for these trucks, don't go making it difficult.
Joemomma1 is offline   Reply With Quote
Old 12-23-2020, 03:41 PM   #124
kev2809
low n' slo
kev2809's Avatar
curious, what do u mean by the truck pan will work? as far as clearance?
-_--_--_ _________
Old 12-23-2020, 04:14 PM   #125
biketopia
Yup, after you corrected me on the CTS-V pan I looked at the measurements more than just depth, and the stock truck pan is shorter front to back in the sump area, which should allow it to work in most cases, it's just deep so it hangs low.
