Old 02-19-2022, 10:19 AM   #101
57FleetsideC4
Re: 57 Fleetside C4 build
Originally Posted by OKGMC4 View Post
Do you know the cam specs? My 6.0 running flat tops and a 224r TSP cam on 112 lsa got 360 rwhp but I could only get 11mpg. I think the 112 lsa and the 3200 stall converter killed the mileage. My 5.3 got 18mpg in town with stock stall and stock LS1 cam. Small part of the reason I’m going back to the 5.3, adding a turbo, and switching to a 4l80. Hoping to get the power AND the mileage. Also, loved the cam lope but didn’t like the truck shaking at every stoplight.
I do have the cam specs out in the shop and will post them later. This is a cam they use a lot on these engines. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is online now   Reply With Quote
Old 02-19-2022, 10:22 AM   #102
57FleetsideC4
Originally Posted by dsraven View Post
kinda too bad you have that rotisserie, you are missing out on the true experience. you know, eye flushing the sand out of your eyes, laying on your back working overhead till your hands fall alseep from no blood flow, dropping stuff in your face.........jealous......
nice job, keep the pics and progress reports coming.
I have done cars on my back before scraping undercoat with a torch and burning myself then the sandblast in every crevice of my body. I feel like I am cheating now. Will keep posting progress. Thanks Steve
Old 02-19-2022, 07:46 PM   #103
57FleetsideC4
Cam specs for the cam they used are.
Duration at .050 Intake 217 Exhaust 225
Lobe Lift Intake .370 Exhaust .270
Valve Lift @ 1.7 Intake .629 Exhaust .629
Lobe Separation 113
Intake Center Line 110
Steve
Old 09-11-2022, 05:42 PM   #104
57FleetsideC4
Hi All, I am behind on posting about the progress on my project and will update to present. This will start from March till now. The first pictures are of the hood and bedsides being in the first coats of primer. Nor real exciting but all part of the process. Steve
Old 09-11-2022, 05:59 PM   #105
57FleetsideC4
Some More primed parts. Steve
Old 09-11-2022, 06:23 PM   #106
57FleetsideC4
With all the body panels in the first coats of high build primer I moved on to the chassis. These are pics of the disassembly. Steve
Old 09-11-2022, 06:41 PM   #107
57FleetsideC4
After the disassembly of the chassis I began to recondition individual components as needed and paint. Steve
Old 09-13-2022, 09:04 AM   #108
Jason 56
You’ve made great progress this summer. Keep up the good work! I really like your garage.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 09-13-2022, 04:47 PM   #109
57FleetsideC4
Thank You. I am making decent progress now. Right now getting the cab ready to paint the firewall and put truck bedliner on the bottom the cab then will put the cab on the chassis for the last time!! Steve
Old 09-13-2022, 05:03 PM   #110
57FleetsideC4
Some pics from late May early June. I sent the frame out to be sand blasted and some more pieces of the chassis that I cleaned up and painted. Steve
Old 09-13-2022, 05:18 PM   #111
57FleetsideC4
These are pics are from late June early July. Frame came back from sand blast and got it prepped for epoxy primer and gloss black single stage urethane. I only filled some of the pits in the frame and smoothed out some of the welds. I am going for a nice driver that I could show if I wanted not a Kindig build. Steve
Old 09-14-2022, 04:57 AM   #112
OKGMC4
OKGMC4's Avatar
Well I think I kin dig it! Sorry, just had to say it.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 09-14-2022, 10:21 AM   #113
57FleetsideC4
More pics and hope to be caught up soon. These are from late July as I was assembling the chassis. Steve
Old 09-14-2022, 10:30 AM   #114
57FleetsideC4
Still in late July. More chassis assembly pics. Steve
Old 09-14-2022, 06:41 PM   #115
57FleetsideC4
Some more progress pics from July. I have a rolling frame at this time and then turned to getting the 6.0 LS and 4L80E trans cleaned up and painted. Steve
Old 09-14-2022, 06:53 PM   #116
57FleetsideC4
More Engine and trans pics with final paint on them. Steve
Old 09-16-2022, 06:25 PM   #117
57FleetsideC4
Pics from early August. Reinstalled all the accessories back on the engine along with the core support I test fitted the radiator so could figure out the fan situation. Everything fit well put only have .140" of space between the fan and the water pump. Won't know if I will be all right till I hang the sheet metal but am pretty confident. Steve
Old 09-16-2022, 06:42 PM   #118
57FleetsideC4
Pics from late August. Frame and drivetrain pretty well squared away. Back to the body now. Almost caught up with the updates. Steve
Old 09-16-2022, 06:58 PM   #119
57FleetsideC4
Blocked out the cab for the first time. There is a lot of mud from all the panel replacements and 65 years of dents. Here are the pics. Steve
Old 09-17-2022, 09:11 AM   #120
57FleetsideC4
This should get me caught up on my project. I put three coats of 2K primer surfacer on the cab. I will block all this out with 180 put a couple more coats of 2K the block with 400 and paint. Getting closer all the time. I have painted the middle of the firewall with color. The next step is to spray the bottom of the cab with tintable raptor bed liner then put the cab on the chassis for the last time. Steve
Old 09-19-2022, 06:26 PM   #121
57FleetsideC4
Sprayed the raptor bed liner on the lower part of the firewall, Lower plenums and the bottom of the truck. I tinted it per instructions and it came out a little lighter but acceptable. You really don't see much of this once all together. The cab should go back on the chassis this weekend. Steve
Old 09-20-2022, 01:11 AM   #122
dsraven
nice job. looks great. curious, are the lower rear cab corners inner and outer or just the outers? hard to tell in the pics and they are so smooth.
dsraven is online now   Reply With Quote
Old 09-20-2022, 09:17 AM   #123
Jason 56
Looks great! I’m anticipating seeing color. We are both at the same point in our builds. If all goes well for me I hope to paint my cab today. Keep up with the progress pictures.
Old 09-20-2022, 09:18 AM   #124
57FleetsideC4
Thanks for the comment. I did inner and outer cab corners. Steve
Old 09-20-2022, 09:26 AM   #125
youngrodder
youngrodder's Avatar
Great job is all looks very sanitary....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
