Old 05-07-2022, 12:44 AM   #101
bwl101
bwl101's Avatar
Re: Bringing my Grandfather's 1972 Longbed Stepside C10 back to life
While waiting for the motor to be delivered, I addressed some transmission leak issues. Changed out the shift shaft seal and dropped the pan to clean it out and to change the trans filter. Pic of the trans pan because it looked so nice after cleaning it up! After about 5 hours worth of work in the new motor, it is basically ready to drop in the truck. Hopefully I'll be able to work on it in the afternoon and maybe get it cranked,n
'72 C10 Long Bed Stepside
Putting my Grandfather's truck back on the road:
http://www.67-72chevytrucks.com/vboa...d.php?t=829659
bwl101 is offline   Reply With Quote
Old 05-07-2022, 08:59 AM   #102
Jiggers72-GMC
Jiggers72-GMC's Avatar
Wow, well done on the trans and the new engine, I see the oil dipstick is on the passenger side of the new engine, I wonder why GM changed sides ........
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 05-12-2022, 11:39 PM   #103
bwl101
bwl101's Avatar
Got the new crate 350 running today! Finished installing it earlier this week and finally got it cranked after having a tough time getting the distributor set in the correct spot. Got the 3 30 minute break in runs completed today to break in the cam. Hopefully I'll have some time to go ride around in it tomorrow!
I was also having an issue with the cluster lights not coming on and the dome light being intermittent. Replaced the headlight switch and all those issues were fixed!
Old 05-13-2022, 08:12 AM   #104
Jiggers72-GMC
Congrats BW, glad to hear it's running again, looks great man
Old 05-13-2022, 09:33 AM   #105
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Congratulations, good to hear. Go enjoy it!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-16-2022, 11:37 PM   #106
bwl101
bwl101's Avatar
Well it's running good, other than the fact that when the crate motor was assembled they didn't do the oil pan gasket correctly and I have two leaks from the oil pan gasket. Waiting for a call from an assigned tech to my issue to see how they will handle the warranty claim... ugh!
Old 05-17-2022, 07:59 AM   #107
Jiggers72-GMC
That sux, maybe the filter is loose ???
Old 05-17-2022, 08:23 AM   #108
KyleSeal
KyleSeal's Avatar
Im in for the ride! Looks like a sweet build. Hopefully you can get that leak resolved with their warranty company.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 05-17-2022, 09:57 AM   #109
bwl101
bwl101's Avatar
I wish! Wasn't that, then I noticed oil was making it's way around that bolt. Looks to be an issue with either the gasket, the pan or the way it was installed. Just sucks to have a problem with a fresh crate engine!
Old 05-18-2022, 11:28 PM   #110
bwl101
bwl101's Avatar
Moved it's first furniture since the new motor, even if it was only two rocking chairs! Had to get a night pic now that I got the tag light working as well. Today I swapped the door seals and the sill plates. The other side was much worse to start off with due to rust, but I forgot to get a before pic. Looks much better without the cracking rubber with over spray.
Old 05-19-2022, 07:52 AM   #111
Jiggers72-GMC
Right on BW, what about the oil leak???
Old 05-19-2022, 08:36 AM   #112
Ol Blue K20
Originally Posted by jiggers72-gmc View Post
right on bw, what about the oil leak???
x2
Dale
Old 05-19-2022, 10:48 PM   #113
bwl101
bwl101's Avatar
Got a call from the engine company and they will work with a shop. They will oat $95 per labor hour and they follow the Mitchel guide so they will oat the number of hours it calls for. They will also cover the cost of a new gasket and maybe oil. So hopefully it won't be hardly any out of pocket for me and I don't have to do it myself. After the two motor swaps, I just don't really want to fool with that crap anymore!
Old 05-19-2022, 10:49 PM   #114
bwl101
bwl101's Avatar
Tonight I was able to swap out the ignition part, glove box lock and door locks. So now I have a nice GM key that works in the ignition and all the locks! Was a very easy process!
Old 05-20-2022, 08:04 AM   #115
Jiggers72-GMC
Glad to hear warranty will cover the oil leak repair, that's a blessing,
do you have a local shop you trust to make the repairs ????
well done on the key n locks ...... I really like your truck!!!
Old 05-21-2022, 07:44 AM   #116
Ol Blue K20
I agree with Jiggers72-GMC.
Dale
Old 05-25-2022, 01:58 PM   #117
bwl101
bwl101's Avatar
Got a new windshield in today! Amazing how much easier it is to see without all the milkiness around the edges and all the scratches in the old one. Windshield guys think it was probably the original glass. Also fortunately, there was only surface rust on portions of the pinch weld. The windshield guys were glad that the pinch weld didn't come off with the gasket haha!
Old 05-25-2022, 02:49 PM   #118
Phillip Owings
Phillip Owings's Avatar
That is a nice truck. If you want you can bring that trucks back mostly you will be really surprised I bet assuming it hasn't been clear coated and peeling. Anyway this is all you need and its not that much. Slow and easy little at a time in the shade. that's what I used on my truck. I like the polisher because its random Orbit and doesn't leave swirl marks.
Phillip Owings is offline   Reply With Quote
Old 05-25-2022, 06:10 PM   #119
Jiggers72-GMC
Congrats on the new windshield. enjoy the view
Old 05-26-2022, 07:19 AM   #120
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on Grandpa's truck. Sorry to hear about the bum 305 and now the oil leak. At least the warranty is going to cover it though. Nice new glass sure makes them nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-26-2022, 08:18 AM   #121
Jiggers72-GMC
I feel like we're doing the same on our trucks, mine is going for a windshield June 1st, they want 300 installed, is that about what you paid??
Old 05-26-2022, 10:08 AM   #122
bwl101
bwl101's Avatar
Was quoted $320 with new glass and new gasket, but they ended up only charging $250. Which is funny because if I ordered the glass through Brother's or LMC just the glass itself would cost that much shipped to me. I'm just glad I didn't have to do it!
Old 05-26-2022, 11:54 AM   #123
Jiggers72-GMC
Ok thanks, I was quoted 300 bucks installed, so I guess that's fair
Old 05-26-2022, 03:20 PM   #124
kev2809
low n' slo
kev2809's Avatar
came out nice I desperately need to put one in mine.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 06-05-2022, 09:49 PM   #125
bwl101
bwl101's Avatar
I needed to replace the old exhaust as was really rusted with leaks and holes all over. I ordered the dual exhaust from LMC as it allowed for use of the factory manifolds. Also all of the local places wanted over $600 to build a replacement single pipe system. The LMC one was $430 to the door so not too bad. Only issue is when I opened it today it was missing one of the mufflers lol! So I have it all installed except for the muffler back on the passenger side. Will be calling the supplier tomorrow for LMC to get them to send me another muffler. Sounds good, will probably sound more tame when one side isn't a straight pipe lol.
