Closed Thread
Old 04-20-2010, 11:12 PM   #1226
menace121978
menace121978's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
thank you! it is Red Jewel w/ bigger pearl flakes found on the 2010 Camaro. here's a few pics from tonight... new stainless pin head allen bolts (big pain in the @ss too) also mounted the hood release...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 04-20-2010, 11:26 PM   #1227
54Caddy
GM Addicted
54Caddy's Avatar
looks good man ima have to go by and look at it. why you say those allen heads where a pain?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 04-21-2010, 12:51 AM   #1228
americanmuscle
Looking good man.
I saw the new read paint and thought I clicked on a different thread for a minute...
I know you have probably said this a dozen times, but could you give me some info on those headers. Whare you got them how they fit ect?
Project "Abby"
84 swb 6.0 swap and rebuild.
http://67-72chevytrucks.com/vboard/s...d.php?t=395121
americanmuscle is offline
Old 04-21-2010, 05:23 AM   #1229
menace121978
thanks Brandon. there were 2 that seemed to be cross threaded from the factory and the new bolts i got didnt have that tapered tip so getting them started with the new paint was a rough way to goalong with retapping them.
Originally Posted by americanmuscle View Post
Looking good man.
thanks man... the headers are from street & performance. they fit great with the exception of having to grind off the driverside ear on the 80e. i love them so far. well worth the $600
"Dennis the Menace"
Old 04-21-2010, 07:12 PM   #1230
54Caddy
GM Addicted
54Caddy's Avatar
haha yea mine are all changed out to standard bolts to without the tapered end couldn't find any like that. What i did is after i painted the core support i re-taped all the holes and put new j clips on everything that took them. Looks good though man if the weather clears up this week maybe ill go by and check it all out
..Mac’s Garage..
IG:MacsGarage
54Caddy is offline
Old 04-21-2010, 07:27 PM   #1231
68 TT
Still plays with trucks
68 TT's Avatar
You can always grind a point onto the tip of the bolt. Just thread a nut onto it past where you want the taper to stop first. After you grind the taper into it threading the nut off will clean up the threads so it works right without having to mess around with running it through a threading die.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline
Old 04-21-2010, 09:27 PM   #1232
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Dennis: I know I have already said this but that color is SICK! Looks good dude keep it up!
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline
Old 04-21-2010, 09:35 PM   #1233
LiveAnimals
LiveAnimals's Avatar
Damn You, jk. Looks great man.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline
Old 04-22-2010, 07:40 AM   #1234
silvereagle07
silvereagle07's Avatar
Looks great! You could try a thread chaser to clean up the paint in the threads before putting your bolts in. I know its more work but it helps getting them started.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline
Old 04-22-2010, 11:25 AM   #1235
68 TT
68 TT's Avatar
Looks great, keep it up.
When I painted aircraft parts that had captive fasteners we always put a fastener in the hole with just enough threaded in to engage all the threads of the captive fastener. This way you could get paint all the way up to the threaded area on the panel since the head of the fastener was not touching the panel surface.
We also put a tapered rubber plug in a tight tolerance fit areas (like hinge pin areas) to keep the paint out.
Pull the fasteners / plugs out before the paint flashes over so you don't peel away any paint.
68 TT is offline
Old 04-22-2010, 11:32 AM   #1236
menace121978
man, thanks for all the tips guys! i apprieciate all the nice compliments too!
"Dennis the Menace"
Old 04-23-2010, 12:31 PM   #1237
BaggedC10
Under construction!
BaggedC10's Avatar
Nice work, Dennis.
Is Will in the kitchen now making breakfast for you and Billy?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline
Old 04-24-2010, 01:51 AM   #1238
menace121978
he's best at bbq'ing tri tips! that's a good idea though!
"Dennis the Menace"
Old 04-25-2010, 01:47 AM   #1239
menace121978
Progress!!! Billy and i pulled the cab out and pressure washed it for the painter. we also did a bit of sanding and prep work too. today the rubber mounts for the radiator were waiting at the door after our(Amy's side) family reunion gtg. (found out we have relatives in fort collins/greely and littleton colorado!)
anyways got the radiator all mounted and it fits perfect. nice and snug and also welded up the seam on the back of the cab...
"Dennis the Menace"
Old 04-25-2010, 01:54 AM   #1240
menace121978
few more...
i forgot my buddy Will and i got the goat all washed, clayed, washed again, waxed, and sealed w/ meguires 21 today also!
"Dennis the Menace"
Old 04-25-2010, 03:08 AM   #1241
draggin86
draggin86's Avatar
the radiator looks ****ing nice mounted dude! the cab seem is looking good also!
draggin86 is offline
Old 04-25-2010, 09:21 AM   #1242
LiveAnimals
Go Niners
Kameron
Old 04-25-2010, 10:37 AM   #1243
nlped
nlped's Avatar
Your makin' great progress!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 04-25-2010, 10:56 AM   #1244
3r!c84
Badass
3r!c84's Avatar
lookin good keep up the good work
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 04-25-2010, 11:04 AM   #1245
flamingbig10
6.0 powered square
flamingbig10's Avatar
looks real good Dennis
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline
Old 04-25-2010, 11:45 AM   #1246
JohnC
JohnC's Avatar
Looking great Dennis. Like stated above that radiator and fan setup looks . Can't wait to see the cab painted and on the frame!
JohnC is offline
Old 04-25-2010, 12:06 PM   #1247
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Now you have NO excuse to get out here!
Silver is looking awesome man!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 04-25-2010, 10:04 PM   #1248
Jonboy
Slots go on anything!
Looking good, Dennis!
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline
Old 04-25-2010, 10:43 PM   #1249
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Looks good man. I wonder if I know any of them...That would be weird huh? Well, you should be able to save on hotels then too.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 04-26-2010, 09:03 AM   #1250
Jonboy
Wouldn't it be a little weird going to visit family and never getting around to seeing them? They might think something's up.
Jonboy is offline
Closed Thread
