Old 11-29-2013, 01:08 AM   #1226
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 68 S/C update.....
Originally Posted by Hart_Rod View Post
Cruising down the road......!
http://instagram.com/p/hRimAsEnuo/
Huge step Rob!! Stoked for you!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-29-2013, 07:18 AM   #1227
Rusbuilt
Rusbuilt's Avatar
Thats Awesome!
Rusbuilt is offline   Reply With Quote
Old 11-29-2013, 09:01 AM   #1228
Chug
Chug's Avatar
Nice!!!!!
Chug is offline   Reply With Quote
Old 11-29-2013, 11:01 AM   #1229
Number98
Prestige Worldwide
Number98's Avatar
Rob this thing has come so far since I first seen it! You have put together one sweet ride, that's for sure..
I am going to read back through the thread but what track bar did you wind up using? How is the clearance on the differential cover? I was going to use the CPP "bent" one but it's not giving me very much room at all, especially as it moves some with suspension travel range and any side load.
Number98 is offline   Reply With Quote
Old 12-01-2013, 02:55 AM   #1230
C10_ustacould
Crappy picture, but it's proof Rob's Farm Truck is moving under blown LS3 power! We took 'em out for a ride and stopped by the cruise night in P'cola. Even in it's unfinished state Rob's truck was a hit. Sweet ride!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-01-2013, 02:20 PM   #1231
Rusbuilt
Rusbuilt's Avatar
Looks like fun!!
Old 12-01-2013, 11:16 PM   #1232
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Congrats, Rob!
Zoomin is offline   Reply With Quote
Old 12-03-2013, 10:02 AM   #1233
Hart_Rod
Hart_Rod's Avatar
Originally Posted by darkhorse970 View Post
Awesome! One of the coolest trucks on the planet!!
Thanks!
Originally Posted by Hammer68 View Post
Sweet!! Good to see you got the issues worked out and the truck is finally moving!!
Well, not totally worked out, but it is getting closer.....
Originally Posted by track70 View Post
I could wake up with that sound everyday!!
Me too!
Originally Posted by Bennett68C10 View Post
Truck sounds awesome Rob
Thansk!
Thanks for all the help Ernie!
Originally Posted by Rusbuilt View Post
Thats Awesome!
Thanks!
Originally Posted by Chug View Post
Nice!!!!!
Thanks!
Thanks! ECE track bar with Porterbuilt lower trailing arm shock relocator.
Looks like fun!!
Thanks!
Originally Posted by Zoomin View Post
Congrats, Rob!
Thanks!
No real updates. Continuing to drive, data log, work on tune, drive, data log, work on tune,.....you get the picture .
R
Hart_Rod is offline   Reply With Quote
Old 12-03-2013, 04:29 PM   #1234
jae
wow, very cool. Inspiring me to get back to work on mine.
jae is offline   Reply With Quote
Old 12-04-2013, 09:52 PM   #1235
Houston Ben
Houston Ben's Avatar
Hart Rod, if I remember correctly you are running 3.08 gears right? If so, how do you find them on the freeway. I think I am running the same and feel mine bogs a little on the freeway when I give it a touch of gas. If you are running 3.08 did you recalculate the computer for the tire and gear ratio and shift points?? If so, how does it run with the gears? I still need to have my trans computer updated for all this stuff and just wondering how it is working out for you?
Houston Ben is offline   Reply With Quote
Old 12-04-2013, 10:38 PM   #1236
Hart_Rod
Hart_Rod's Avatar
Thanks!
I've got 4.11's with a 31" rear tire and I like the feel so far. It's real easy to change the setup, all you do is update your gear and tire size and the software does most of the work for you. You can then adjust the shift points if you want them higher or lower.
Old 12-07-2013, 11:45 PM   #1237
Houston Ben
Cool, thanks for the reply. Question, does your transmission or possibly engine sound like it is spooling up when you stomp on it? Mine does and just wondering g if it was normal?
Old 12-09-2013, 01:26 AM   #1238
big_al_71
big_al_71's Avatar
Great job rob......
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-12-2013, 10:52 PM   #1239
Rusbuilt
Rusbuilt's Avatar
Rob is there a specific radiator you recommend for an ls swap?
Old 12-13-2013, 12:06 AM   #1240
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Turned out great rob..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 12-13-2013, 09:52 AM   #1241
Hart_Rod
Hart_Rod's Avatar
Ben - I'm still working on the tune and haven't "stomped" on it yet, , so I really couldn't tell you. But, with such a low first gear in the transmission, it winds up pretty quickly....
Originally Posted by big_al_71 View Post
Great job rob......
Thanks Al!
Thanks!
Rus - There's a lot of nice stuff out there, I guess it depends on the look you want and how much you want to spend. I used a factory 4-core in my 68 because I wanted a somewhat stock look. It worked great with my 383, and so far seems to be doing well with my new setup. I purchased an Entropy setup for m Suburban and it is a beautiful piece and fits great! This is probably not the answer you were looking for, but it will give you some perspective, .
Old 12-13-2013, 09:56 AM   #1242
Rusbuilt
Rusbuilt's Avatar
Any info helps Rob! I appreciate it.
Old 12-13-2013, 12:16 PM   #1243
NewType72
NewType72's Avatar
Just can't beat those classic four cores. I've been running mine for four years now on two different motors gen1 sbc 350 and the nicer 96-98 sbc 350 both with a 91 suburban serpentine belt setup. Never overheated once even in car show parades in 110 degree weather.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 12-19-2013, 09:54 AM   #1244
Hart_Rod
Hart_Rod's Avatar
Your welcome!
No problem with mine so far, knock on wood, . I drove it to work for the first time in 10 months! Heater works great and a little quieter in the cab, . Now I just need to tie up some loose ends and keep working on my tune....
Old 12-19-2013, 10:11 AM   #1245
C10_ustacould
Awesome!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-19-2013, 11:26 AM   #1246
mcbassin
Still Learning
mcbassin's Avatar
Can't wait till I get to where you're at on yours. Congrats!
mcbassin is offline   Reply With Quote
Old 12-19-2013, 12:33 PM   #1247
Bennett68C10
Bennett68C10's Avatar
Congrats on getting the bugs worked out and being able to drive it. I'm with Mike, I cant wait to be able to do this with mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-19-2013, 05:46 PM   #1248
lowdownstar
big guy
lowdownstar's Avatar
looking great Rob must be nice to get behind the wheel again.
Ray
lowdownstar is offline   Reply With Quote
Old 12-19-2013, 09:48 PM   #1249
sourkraut
sourkraut's Avatar
Why does it look like a short, stubby little chevy could kick a big tall dodges azz! Looks awesome!
Did you lower the rear a couple inches during the engine swap, you might have said? Stance is perfect!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 12-19-2013, 10:01 PM   #1250
darkhorse970
darkhorse970's Avatar
Outstanding! I'm being lazy here, but can you remind me what your current setup is?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
