05-24-2020, 02:57 PM | #1226 |
Re: What did you do to your truck today.The 3rd chapter
Today I FINALLY got my new Edelbrock AVS2 650cfm carb running correctly on my new 350 engine.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
05-24-2020, 03:48 PM | #1227 |
Proprietor of Dale's Corner
I drove mine to the store. The girlfriend wanted Tri Tip for her birthday dinner.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-24-2020, 05:59 PM | #1228 |
Today I started the process of fixing the weep hole leak (when parking uphill) from my transmission. The vent tube up above is clear so I pulled the drive shaft And tail housing. From photos I’ve seen I expected to see some sort of inner seal or o ring but nothing present or much of a groove for one where the splines Start. I’m not even sure if mechanically that would seal the driveshaft yoke.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-24-2020, 10:10 PM | #1229 |
Spent the day at the media blaster. Of course no rain in the forecast yet I was dodging drops on the way back to the shop.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 05-24-2020 at 10:22 PM. |
05-24-2020, 11:20 PM | #1230 |
After finally massaging in new break lines, installing the new booster, master cylinder and shiny new stuff.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
05-26-2020, 03:43 PM | #1231 |
Got the bearing surfaces cleaned up on my driveshaft and yoke. Installed the tailhousing back on and waiting for new Spicer joints to arrive today. Should have a non leaking yoke now.
05-30-2020, 10:00 PM | #1232 |
Thursday evening and today started sanding. Don't think I'll find any bondo.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
05-31-2020, 12:34 AM | #1233 |
Today I am closing the door on my gear change project. Went from 3.07 to 4.11. Granny first gear used to have some value with my small travel trailer, but I'm afraid it is now rendered useless and starts in second gear will work fine. I will go from about 1700 rpm in fourth to a more reasonable 2400 rpm at 55 mph with my 33 inch tires.
05-31-2020, 04:18 PM | #1234 |
i installed new matching door locks and ignition lock so id have 1 key since i couldn't find my door keys which got lost over the last 8 years if ti being tore apart.. of course i found the door keys last night after the new locks showed up...
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-31-2020, 04:35 PM | #1235 |
Don't feel bad, I have the same kind of luck......basic Murphys Law......
06-01-2020, 12:07 PM | #1236 |
Added some CPP disc brake calipers .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-01-2020, 12:51 PM | #1237 |
Just stared at mine over the weekend to get an idea of what to tackle next. Wife got me a new set of body mounts for anniversary so that's on the list. Want to knock the front end out but waiting to order and get parts here first.
Did paint my old 5x12 utility trailer though. Not a great job but it is one color now.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
06-02-2020, 08:02 AM | #1238 |
Finally posed in front of the old Chevy sign.
06-02-2020, 10:16 AM | #1239 |
I installed my new DUI distributor Sat. Put in new plugs gaped at .050 and readjusted the timing to 14*BTDC . Total advance is 34* at 2500rpm. Also changed the vacuum advance to ported and reset the idle mixture with my vacuum gage. Truck is more responsive now and just seems to run better.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
06-03-2020, 01:14 PM | #1240 |
I went and pulled the wheels off of my great grandfather's 70 stepside we have had in storage for years. Figured with being furloughed from work right now it gives me something to do. Had the tires removed and since 50 years is hard on the wheels I'm sandblasting and painting to freshen up. I've got some extra tires that hold air and will have them put on the put on the truck and load on a trailer to bring home. Fun project I've been looking forward to for a while and putting off almost as long.
03 s-10: daily driver 94 s-10: late model toy 70 c10: starting frame off resto 80 c10: for sale just collecting dust 94 c1500: hauler to and from 55 chevy: hot rod project jus reborn |
06-03-2020, 02:08 PM | #1241 |
More pics please....
06-03-2020, 02:25 PM | #1242 |
Hoping to get the tires mounted by the weekend and bring the truck home. Truck is going to need a good bit of bodywork. It was the last vehicle my great grandfather ever bought and he left it to my sister upon his passing. She wasnt old enough to drive so dad bought it from her. He drove it until about 92 and parked it from a flat and needing carb rebuild.
06-03-2020, 02:54 PM | #1243 |
Giving my granddaughter a tour of mine
06-03-2020, 06:18 PM | #1244 |
your Blessed Grandpa.....
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-03-2020, 06:28 PM | #1245 |
It's hers now!
06-03-2020, 06:35 PM | #1246 |
No pictures, but I installed front disc conversion with power booster. New tie rods, upper and lower ball joints and stainless front brake lines.
Still need to adjust the alignment and get the leaks stopped! Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
06-03-2020, 06:39 PM | #1247 |
No pics?.....didn't happen......
06-03-2020, 07:06 PM | #1248 |
laying low
I've been up to my arm pits in the heater/ac parts lately. Cleaning and more cleaning. I made a trip to a jy today scouring parts trucks for things left I might could use. They're picked pretty clean and they haven't added any more 67-72 trucks in several years. It's getting harder to find used parts.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-04-2020, 10:58 PM | #1249 |
Replaced the grill emblem. The original was missing the center blue portion which I had a piece of cardboard with painters tape. It didn’t look bad but always kinda bothered me.
06-05-2020, 12:52 AM | #1250 |
Painted my front inner fenders a couple days ago and mounted the driver's side and fender today. Worked on the right side wiring some and the starter heat shield. I would have been surprised if I bought one I didn't have to modify.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
