Closed Thread
Old 10-30-2012, 10:02 PM   #1251
nlped
nlped's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
I don't have the CPP kit, but I do have the McGaughy 13" kit (same hub and rotor) and my 1st Gen wheels fit without issue.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 11-17-2012, 04:29 AM   #1252
hardwaa
hardwaa's Avatar
Brandon's Truck.
These wheels are work to make them fit, but it is SO worth it when done correctly!
Here is some motivation for you all.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline
Old 11-17-2012, 12:29 PM   #1253
Z10
Z10's Avatar
Finally got around to taking a pic with my 338
245/40/18 and 275/30/20 Nitto's. I do have 2/4 drop springs to install so that should help, but I think I need a 294/45/20 rears.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 11-17-2012, 12:44 PM   #1254
LEX
LEX's Avatar
Originally Posted by hardwaa View Post
Brandon's Truck.
Beautiful truck!
LEX is offline
Old 11-19-2012, 05:01 PM   #1255
AZChevyland
AZChevyland's Avatar
Wink Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Did this. Ground rotors up front. Spacers in rear. Measure 3 times before ordering spacers if you want it tight. 20" wheels, 10" wide in back with 6.23 bs, 8.5" wide in front with 5.24 bs.
J&S Sideyard Projects......we will be at...... Dino's 3rd annual Pre-ShowGit Down
AZChevyland is offline
Old 11-19-2012, 05:08 PM   #1256
nlped
nlped's Avatar
^^^ Good looking truck!!!
Carter
nlped is offline
Old 11-19-2012, 05:38 PM   #1257
heathbirkendahl
Great looking ride and wheels!!!
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 11-27-2012, 08:21 PM   #1258
bugmasta
bugmasta's Avatar
so without reading through 50+ pages of jibber jabber, can someone confirm or deny if the new wheels do or do not fit '72 front rotors without having to grind the hub?
bugmasta is offline
Old 11-27-2012, 08:35 PM   #1259
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
You will have to grind the hub. Period.
Just like in the picture.
(4 posts before this one).
Keith
Convert to disc brakes.
lolife99 is offline
Old 11-27-2012, 08:47 PM   #1260
bugmasta
bugmasta's Avatar
No.
perfect, thats what i needed to know. also, will 4.5 backspace fit? its actually a 68 c20 with conversion drop spindles to use 72 front components.
bugmasta is offline
Old 11-27-2012, 08:51 PM   #1261
HotRod C/10
HotRod C/10's Avatar
very nice! is that a narrow rearend or the wider 71-72? where did you get the spacers from and what size did you use on it?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 11-27-2012, 08:53 PM   #1262
lolife99
lolife99's Avatar
I personally would rather have the 5.25" BS on a 8.5" wide front wheel.
Keith
lolife99 is offline
Old 12-04-2012, 02:40 PM   #1263
krawler00
Finally scrounged enough cash together to get everything done. Looks pretty good. Now to lower the rear 1-2". I need functionality so no more dropping for me. 20x8.5 front 20x10 rear.
krawler00 is offline
Old 12-04-2012, 04:39 PM   #1264
Z10
Z10's Avatar
What size tires are you running?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 12-05-2012, 12:48 PM   #1265
krawler00
I am running 275 45 20 tires all the way around. I was going to stagger the front width but decided to just get a narrower wheel. I did not want directional either. I like to rotate my tires. At least side to side is better than nothing.
Old 12-16-2012, 08:14 PM   #1266
HotRod C/10
Specs:
Narrow rearend
5 1/2" Backspace Boss 338's (rear)
Toyo Proxes II's 295/40R20
1" hub centric spacer from here. https://www.ezaccessory.com/ProductD...ode=5500-5500P
LS SWAPPED
-1976 SILVERADO
Old 12-17-2012, 06:17 PM   #1267
AZChevyland
this 67 truck has the 71-72 rearend which, like you know, is wider.
Old 12-17-2012, 08:15 PM   #1268
big mike71
big mike71's Avatar
Your truck is sweet, I like it alot.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline
Old 02-24-2013, 05:35 AM   #1269
toddrh1
toddrh1's Avatar
4 years after buying them my 18's are on and my 69 has 5-lug power disc brakes. What a difference.
toddrh1 is offline
Old 02-24-2013, 07:09 AM   #1270
LakeAnna
LakeAnna's Avatar
4 years! I would have gone crazy looking at them that long... Looks good and I guess they fit without issue?
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline
Old 02-24-2013, 02:23 PM   #1271
toddrh1
toddrh1's Avatar
I had the typical issues. Ground the rotor nose and used 1/4" spacers with longer studs. Rear fit perfect.
toddrh1 is offline
Old 02-24-2013, 04:35 PM   #1272
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Ttt
ksbrktracer is offline
Old 03-01-2013, 09:14 PM   #1273
ksbrktracer
TNT-MOTORSPORTS
Ttt
Old 03-01-2013, 09:22 PM   #1274
HotRod C/10
my buddy is looking for 20's in a 338 8.5 up front (5.25 offset) and 10's (5.5 offset) for the back.....chrome
LS SWAPPED
-1976 SILVERADO
Old 03-01-2013, 09:42 PM   #1275
ksbrktracer
TNT-MOTORSPORTS
see vendor section or call 918-845-1935
Closed Thread
