11-22-2016, 08:16 PM | #1251 | |
Re: My 52 GMC Build
Thanks joe I never expected them to print it.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-22-2016, 11:17 PM | #1252 |
Re: My 52 GMC Build
very cool, congrats. much deserved. funny I know the feeling of that first mag (though not for trucks) My first every skating photo came out in jan 06' two page spread, it was years of hard work paying off. years later and countless major publications, I could prolly say I'd still get excited to have a publication of my new passion (trucks). but man oh man all the media, industry hype etc with the skate industry, has taught me alot. You're are great candidate for the publication, you didn't build this to grace mag pages, you're humble and appreciative and the world needs more builders like you!.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-23-2016, 09:05 PM | #1253 | |
Re: My 52 GMC Build
11-25-2016, 04:53 PM | #1254 |
Re: My 52 GMC Build
Well I finally am getting to build my new welding cart. It will hold my mig and gas also get my tig off the floor and gas for it.
Got the steel cut 1.5" 3/16" angle. Also found a pic from our NC trip at 5820ft.
11-25-2016, 06:07 PM | #1255 |
Re: My 52 GMC Build
I really enjoy seeing pics of your truck traveling.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
11-27-2016, 10:45 PM | #1256 |
Re: My 52 GMC Build
Hey 50's--I've been looking for a discussion of the differences in the front sheetmetal on the 1 ton-and-down versus the 1.5 ton-and-up. Have you run across a thread that gets into it?
I know the fenders and hood are different, but in what ways? Other questions I have, if you or anyone else wants to weigh in, are: I know the grille bars are spaced wider up-and-down, but is the grille width the same? It appears the fenders drop lower below the cowl, but is that and the size of the wheel opening the only difference? Are the inner fenders longer? Is the "web" of frame itself taller--from top to bottom of the frame rail? I mean, are normal aftermarket front IFS crossmembers out of the question for 6400 front rails? When you use the big-truck front sheetmetal, and space the rear axle to center the fenders of a 3100 bed (with a back-half, or complete frame swap) does the wheelbase still end up 116-117"? I like what you've done with your truck! I have a decent 2-ton available and am thinking seriously about jumping in. John |
11-28-2016, 09:09 AM | #1257 | |
Re: My 52 GMC Build
Thanks rusty
Here is what I have found out. When I was at 99's place he brought out a normal chev fender. They where very close to same length, mine was about 2" wider from cab forward. Also my fenders are taller even tho I cut mine down by 3" also the wheel opening is for a 20" truck wheel. As for wheel base mine is 120" with a 80" long box the s-10 rear suspension would have worked. The frame web was about 10" and about 1/4" thick steel. I will start a thread on this I have been wondering this as well. I would build it, if I were you. http://67-72chevytrucks.com/vboard/s...63#post7780963
11-28-2016, 02:26 PM | #1258 |
Re: My 52 GMC Build
So it could handle about 4" more track width, I guess? That opens up more frame options.
12-01-2016, 05:25 PM | #1259 |
Re: My 52 GMC Build
cool truck subscribed to keep watching!!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
12-01-2016, 07:12 PM | #1260 |
Re: My 52 GMC Build
Hey Lower, thanks for posting the details of your trip, looks like a good time. As it turns out you where in my neck of the woods, I'm in the NE part of SC. Charlotte: 3 hours, done the tail a few times, all good stuff. What would be cool is if we put together a big AD get together next year at some major park. I hope to have my camper done by April so that would be cool. Congrats on the magazine, that's a big deal!
Rob
My '47 C.O.E build |
12-02-2016, 01:03 PM | #1261 | ||
Re: My 52 GMC Build
Thanks Quote:
12-06-2016, 02:30 AM | #1262 |
Re: My 52 GMC Build
Well I got my new welding cart made and my tig welder is finally off the floor after 2 years. The foot print of the new cart is the same as my old one that only held my mig and one tank. I moved the main wheels forward to get better maneuverability in my small shop. The mig is hard wired into the plug that the tig gets plugged into, then I have a 25' cord that I plug in.
12-06-2016, 03:00 AM | #1263 |
Re: My 52 GMC Build
Lowered
Great tk, great magazine score! Your welding cart is cool, just one questions do you use the same shielding gas for tig and mig?Two tanks? Keep on keepin on NC
Been there, wrecked that |
12-06-2016, 10:55 PM | #1264 |
Re: My 52 GMC Build
looks great, I know that feeling. life and truck keeps you so busy the easiest things get pushed back. I went all these years without a bench grinder. Finally bought 3 of them, hooked one up and still don't have it mounted, so it moves all around!!!!! ahhhh the dumb lazy things I do vs all the hard labor and time crunching things I do. nice ground clamp too!!!
12-06-2016, 11:31 PM | #1265 |
Re: My 52 GMC Build
Nice welding cart! Sometimes it takes time to get to all those other projects. I could use some minions around here myself.
12-07-2016, 12:13 AM | #1266 | ||
Re: My 52 GMC Build
Thanks Doug Ya a whole bunch of minions.
12-14-2016, 10:15 PM | #1267 |
Re: My 52 GMC Build
Ok so my plywood bed was always temporary. Now I am trying to figure out what will go with the truck. I crudely used paint and made some options. What do you guys think?
1 would be same aluminum as running boards with black steel strips. I kind of like #5 #1 #2 #3 #4 #5
12-14-2016, 10:39 PM | #1268 |
Re: My 52 GMC Build
Hey Bob...
I really like #5..... Something about that wood grain and color that blends well with your truck.
Keith |
12-14-2016, 10:55 PM | #1269 |
Re: My 52 GMC Build
I vote number five, yet less shiny...like your truck.
12-14-2016, 11:28 PM | #1270 |
SAVING ONE TRUCK AT A TIME
Re: My 52 GMC Build
Looking good. #5
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
12-14-2016, 11:48 PM | #1271 |
Re: My 52 GMC Build
if I had to pick it would be #4, it doesnt look like a bowling lane or "newtique" furniture like the others. keep in mind the shinier it is the harder it will be to take care of, even polyurethane has a hard time taking 12 hours of hot sun and weather changes and torrential rain. but dont listen to me, get what you like!
I saw a bed floor made from aluminum bleachers once, THAT would be perfectly in line with your truck, in my dim opinion. I have made new bed floors for two trucks and stained them pretty, one cedar tint and one redwood tint, and neither of those got the attention and compliments that my reclaimed flatbed weathered cedar on the 49 gets. people love it! the crustiness, the silvering, the rusty strips. Maybe it just fits the look better.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-15-2016, 12:10 AM | #1272 |
Re: My 52 GMC Build
To me number 3 compliments the truck the best
12-15-2016, 01:49 AM | #1273 |
Re: My 52 GMC Build
I like the knotty #5, but I've seen one (maybe 60-66 forum) that they burned the wood with a torch and then cleared it. It looked sweet. Might be a good rustic look in your truck.
12-15-2016, 11:33 AM | #1274 |
Re: My 52 GMC Build
I like #3 with a tad darker tint. I like that bleacher bed idea, I think it would really only work with certain color trucks and def more 60-66 trucks rather than and AD.
12-15-2016, 01:26 PM | #1275 |
Re: My 52 GMC Build
I would go with number 5, only a bit more grey-ish so that it looks older.
Suits the truck better when it has an older look to it. I think......
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
Tags |
bagged, build, diesel, gmc, hot rod |
