Closed Thread
Old 08-29-2013, 07:24 PM   #1251
RyanAK
Re: How about some pics of 67-72 Burbans!
Here's an update on Earl. New 15x8 rallyes, 255/70R15 radials, Bilsteins, and sway bars. After the 1800 mile drive from Hobbs, NM to central PA I'll cut a front coil and add a 2" block out back and call the suspension 'temporarily' done. Then some engine and driveline upgrades, fix the rust, and paint. Gotta decide on satin black/white, or medium olive/white (original). Hmmm...
R
RyanAK is offline
Old 08-29-2013, 11:42 PM   #1252
Cumminpwr11
Southern Nevada Coal Roller
1969 suburban man
How did you do your third row seats? I need to add a third row and get my burb running. Cramming into a exra cab truck with 4 kids is no fun.
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline
Old 08-29-2013, 11:55 PM   #1253
jorgensensc
jorgensensc's Avatar
I took my stock third row on the suburban and flipped it around backwards so I had more cargo room. The kids just climb in from the tailgate and ride backwards. They seem to like it.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 08-30-2013, 12:21 AM   #1254
5150
C10 Club Tennessee
5150's Avatar
Do you have some pics of that?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline
Old 08-30-2013, 02:09 PM   #1255
1969 Suburban Man
1969 Suburban Man's Avatar
CumminprwII --My third seat is out of a early 90's Burb and mounts in the factory floor clips. The second row has a split 70/40 seat that folds forward to get to the third seat. Real nice clean setup to install the seat.
1969 Suburban Man is offline
Old 08-30-2013, 03:07 PM   #1256
Cumminpwr11
Nice 1969 Suburban man.
Very clean. did you mount the third row into the wood or did you cut out the back area of a 90's suburban? I have the same set up in mine but 80's seats front buckets and middle bench. I just want to make sure how ever I mount a third row it will be safe for my kids.
I been thinking about getting new middle bench and 3rd row. I just not sure about mounting yet.
Thanks for the pictures and the help
Chris
Chris
Old 08-30-2013, 03:11 PM   #1257
bruin_d
bruin_d's Avatar
The top one and bottom one are my 2 favorite pictures I have of my Suburban. The middle one I took last night while out cruisin'.
bruin_d is offline
Old 08-30-2013, 05:33 PM   #1258
1969 Suburban Man
Chris, I did not install the seats, they were in the car when I purchased it so I can not say for sure if they are mounted in wood or the metal section.
I will say this, the guy I got the car from was very safety minded as he would not let his grandkids ride in the car until he had all the seat belts installed and working properly. I have a bad back so I can not look under the car, but the factory clips are very solid and if not in metal I am sure they are backed up with metal from the bottom. When the seat is in place it is very secure and seat has no play. He put a lot of work and time in making it right.
Good luck with your's, Tom
Old 09-03-2013, 10:30 AM   #1259
puppyluppy
Thank you all for this very enjoyable post. Puppyluppy
puppyluppy is offline
Old 09-03-2013, 10:51 AM   #1260
zammer
Addicted user
zammer's Avatar
Bruin D just amazing ride! Your kid loks pretty happy up front, my son is around the same age and loves the "garage truck"
1972 2wd Blazer - 95% completed
2015 Silverado 1500 4wd -z
2008 AERO 9-7X (TBSS cousin) LS2
1970 Jimmy 4wd - future project
zammer is offline
Old 09-06-2013, 01:30 PM   #1261
AMERICAN PICK-UP
I sold this one today 1970 2wd.
AMERICAN PICK-UP is offline
Old 09-06-2013, 05:36 PM   #1262
DWilbur
This is a picture of my donor suburban. lots of rust and rot. Building quad cab truck.
DWilbur is offline
Old 09-10-2013, 06:20 PM   #1263
1968vetL-71
Junior Member
1968vetL-71's Avatar
Stopped by "Little shop of horrors" today in Lawrenceburg, Tn and seen if Eric had anything new in the shop. He does some really nice work and his fab skills are off the charts. He said this sub was getting ready to go home to its owner. I seen this thing under construction a couple times. Dope!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline
Old 09-30-2013, 01:18 PM   #1264
rtaylor60io
So how do i locate a headliner for a 72 suburban,mine has none?
RT
rtaylor60io is offline
Old 09-30-2013, 02:51 PM   #1265
1971BB427
1971BB427's Avatar
RT
They're not a complicated piece. Easily made from thin sheet plastic or various other materials. Mine is homemade and covered with material. Uses upholstery clips, and a few screws to hold it up in place.
Start with construction paper or cardboard and make templates by taping it to the bows and cutting it to size. Once you've got patterns you can chose your material for the backer, and covering, and copy the patterns.
Then drill holes through the backer and mount it with screws to the bows. After that, pull it down and use upholstery clips to fit the holes and push them through the backer before gluing the material on. Then just snap it in place, and if needed add a few strategic screws if the backer doesn't conform well enough to hold.
1969 C10 Suburban 350
1963 Falcon gasser 464 BBC
1946 Austin 327 SBC gasser
1971BB427 is offline
Old 10-13-2013, 02:50 PM   #1266
hookedonchevys
hookedonchevys's Avatar
This is my 71 burb,Originally came from Great Falls montana.The previous owner brought it to canada from the states but it sat for about nine years before i bought it this past summer.When i pulled out onto the road for a test drive and the factory installed underdash air conditioning still worked,it was sold!I put 2 1/2" drop spindles on the front, bagged the rear about 2 days after i got it home,and 18" rims i had kickin around.Then 2 days of buffing later,that original paint came back gleaming!
hookedonchevys is offline
Old 10-13-2013, 03:07 PM   #1267
GuyO
GuyO's Avatar
Very nice, is that upper door molding? I hadn't seen that before!
GuyO is offline
Old 10-13-2013, 04:57 PM   #1268
rod1701
rod1701's Avatar
I have same upper door moulding on my 1970
1979 C-10 LWB
rod1701 is offline
Old 10-13-2013, 07:44 PM   #1269
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Another nice Burb! In Alberta too!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline
Old 10-13-2013, 09:20 PM   #1270
67 Burb
67 Burb's Avatar
Hey, hookedonchevys, very nice burb. Am I the only Canuck outside of Alberta with a 3-door Burb? HAHA
Bob
67 Burb is offline
Old 10-15-2013, 04:28 PM   #1271
aerloompanel
hey guys, here are some pics of the family panel it was my dads old work truck. Then grandpa, now mine
changes are coming
67' Chevy C10 Panel
06' Mini Cooper S
aerloompanel is offline
Old 10-15-2013, 04:29 PM   #1272
aerloompanel
here are a few more
67' Chevy C10 Panel
06' Mini Cooper S
Old 10-15-2013, 04:33 PM   #1273
aerloompanel
Sorry guys wrong thread!
67' Chevy C10 Panel
06' Mini Cooper S
Old 10-15-2013, 08:23 PM   #1274
YBNORML
YBNORML's Avatar
Originally Posted by aerloompanel View Post
here are a few more
Perfect thread!!!
Sweet panel. Very 80's. I love it.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
YBNORML is offline
Old 10-15-2013, 08:34 PM   #1275
rod1701
rod1701's Avatar
80's?!? Looks like a 70s Shaggin' Wagon!
1979 C-10 LWB
rod1701 is offline
Closed Thread
