Closed Thread
Old 04-27-2010, 12:03 PM   #1276
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
Is it painted yet??
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 04-27-2010, 12:09 PM   #1277
menace121978
menace121978's Avatar
you would be the 1st to ask!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 04-27-2010, 12:14 PM   #1278
nlped
nlped's Avatar
Go ask him about his trailing arm suspension I did notice that he took it off his Sig
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 04-27-2010, 12:20 PM   #1279
glock35ipsc
busted.......
Bob
Old 04-27-2010, 12:28 PM   #1280
glock35ipsc
BTW.... you will probably want to use these instead (the gold one on the right):
http://www.purechoicemotorsports.com...rod/prd255.htm
I found this on LS1tech.com when I was planning mine and bookmarked it:
If yours is 1997-up, you won't be able to use the AN fitting for the rear cooler unless you can find someone who installs the lube extension in the fitting. This fitting intersects through a seal in the center support for the lube circuit.
http://www.ls1tech.com/forums/automa...ngs-seals.html
Sounds like if you remove the OEM rear fitting and just replace it with a 1/4 pipe fitting, it might not get the fluid to the circuit correctly. That would be bad! I would at least call someone like TCI or a reputable local shop to verify this.
Bob
Old 04-27-2010, 12:38 PM   #1281
glock35ipsc
Oops, actually these instead. This is for the pair:
http://www.purechoicemotorsports.com...rod/prd177.htm
Bob
Old 04-27-2010, 12:43 PM   #1282
menace121978
just in the nic of time!!! i got him to change my order!!
"Dennis the Menace"
Old 04-27-2010, 12:45 PM   #1283
glock35ipsc
Phew!!!
Bob
Old 04-27-2010, 12:51 PM   #1284
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
From what I've found no-one makes the fitting with the extension in the rear fitting. I am just going to use the factory quick connect lines and cut them off about 6 inches from where they go in the trans. Then break out my handy flaring tool and flare the lines and use high psi. rubber hose to run the lines to the cooler.
--Josh
STOCKISH is offline
Old 04-27-2010, 12:58 PM   #1285
glock35ipsc
The ones I posted lets you use -6 AN fittings/hose with the OEM fittings. I totally forgot about them until I saw this thread and Dennis's other thread asking about fittings. I wish I had remembered them now, it would have made things easier without that extra step to remove the hard lines and flare them.
Bob
Old 04-27-2010, 01:07 PM   #1286
STOCKISH
STOCKISH's Avatar
O- I see now. Those will be pretty handy then. But, since I already cut mine and bought all the 3/8 high psi. hose I guess I'll just stick with it. Story of my life, always behind the ball...
--Josh
STOCKISH is offline
Old 04-27-2010, 01:24 PM   #1287
glock35ipsc
LOL, I just found out I was behind the ball too, even though it seems as though I was in front of it at one point. Must of got run over by it!
Bob
Old 04-27-2010, 01:54 PM   #1288
menace121978
you guys are too much! i hope it works out this way... ive been measuring and i think the exhaust is going to be too close to the lines if i go straight to the frame rail. i might need 2 90*'s... there's another $30
"Dennis the Menace"
Old 04-27-2010, 11:02 PM   #1289
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Well that should only be about 1/1000 of your total truck budget huh?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 05-04-2010, 08:21 PM   #1290
menace121978
almost ready to fire!!
so today i replaced all the zip-tied fuel lines with actual clamps, installed new knock sensors, knock sensor harness, tranny filter, oil filter and new tranny pan. i also plugged off the throttle body steam ports and that extra port on the power steering pump. my harness was finally shipped today and the steel braided line and -an fittings will be here tomorrow for the tranny cooler lines.
all i need to do is install the harness, cooler lines, and fill everything with fluid!!!
"Dennis the Menace"
Old 05-04-2010, 08:24 PM   #1291
draggin86
draggin86's Avatar
looks gay start over Dennis!
draggin86 is offline
Old 05-04-2010, 08:31 PM   #1292
menace121978
the clamps on the fuel lines?!
"Dennis the Menace"
Old 05-04-2010, 08:55 PM   #1293
STOCKISH
STOCKISH's Avatar
Much better than zip ties my friend. I think that looks really nice. Going to be over the top nice when finished. Keep it up.
--Josh
STOCKISH is offline
Old 05-04-2010, 09:07 PM   #1294
menace121978
thanks Josh!
"Dennis the Menace"
Old 05-04-2010, 09:27 PM   #1295
lownfast
Gettinlow & Goinfast
silver its beautiful bro, i wish i could stay focused on my blazer like you have on this truck!
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline
Old 05-04-2010, 09:38 PM   #1296
draggin86
draggin86's Avatar
im messing with you dude look at you getting all paranoid!
Old 05-05-2010, 12:09 AM   #1297
menace121978
Thanks lownfast! i dont do much else buddy... just gotta get her done!
Billy... you know i'm right on the verge of changing those damn clamps again!
"Dennis the Menace"
Old 05-05-2010, 01:02 AM   #1298
54Caddy
GM Addicted
54Caddy's Avatar
haha. looking good man ill text you i want to roll by one last time before i leave. ( Looks like your letting the frame get dirty best wipe it down ahahah)
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 05-05-2010, 08:52 AM   #1299
JohnC
JohnC's Avatar
Looks good Dennis!
JohnC is offline
Old 05-05-2010, 03:15 PM   #1300
menace121978
DONT FEED THE ANIMALS!
"Dennis the Menace"
Closed Thread
