#1326 |
Re: 1967 Chevy CST aka "the loud truck"
Beautiful write up! I need to find out where to buy the correct crush sleeve I cannot find it anywhere here in Merced!
#1327 |
Nice very nice
#1328 |
Yeah Jeremy usually has the answer!
#1329 |
Rick to answer your question on the gas mileage I think we run pretty close in this aspect least same area haha. I get 10 city and 12 highway 350/330hp th350 trans with shift kit 15mph and then 40ish it shifts. 3:73 gears doglegger.
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#1330 |
Lol ok so it's a little less then what I have now lol
And I've been doing some searching and I think if I'm correct a 700r shortbed driveline is 55"-55.5"? Am I correct? |
#1331 |
![]() Join Date: Mar 2011
Rick! 9999 posts? wow!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
#1332 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#1333 |
Junk Yartist
Rick, look into a 200r. It can be built just as strong if not stronger than a 700r and is the same length as a TH350
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#1334 | |
Hahaha! And to think my 10,000 post is on my own build thread! That's scary... There 10,000 times you can find a post from me! I wouldn't rather hav posted on any other site 10,000 times more then here!
All I need for the the 700r/posi/3.73 install is: I need a tilt shift indcator lense for a 700r and a shorter drive line As for the posi/3.73 install I need the correct crush sleeve, posi additive and 80w90 diff lube as well as guidance from a well expeienced individual lol I'm not scared to install the pinnion I'm just worried about how well it's going to be installed or last lol |
#1335 |
Well I messed with the fuel guage situation a little today... When I disconnect the brown wire at the tank it goes all the way to full and then when I reconnect it it just goes to empty.
#1336 |
Well I have bought a new sending unit and now when I disconnect the brown wire my guage reads full and when I reconnect it goes to empty... Took the sending unit out and grounded it, connected the brown wire and moved the floater and the fuel guage would move
#1337 |
I picked up a drive line today that will work with my 700r swap so now I'm down to:
11 quarts of ATF And I need to figure out how the 700r overdrive cable connects to my 1406 eddy since it doesn't use the same cable as the 350 |
#1338 |
Junk Yartist
#1339 |
Junk Yartist
#1340 |
Nice! Ok ill but the one you recommend. And I need to get the right bolt for the cable it needs the one with the ball end I don't think I have that bolt.
#1341 |
C/10 junkie
The bowtie overdrives tv cable is the kit I used and it was nice.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#1342 |
Thanks For the input Shawn I noticed that it has a carb spacer is that needed?
#1343 |
And as for an update I went down to see the general today and you wouldn't believe it... He actually still had 1 last blower motor relay for a 67! So I snatched that up ad also got some diff lube and posi additive, an I have the crush sleeve and shims coming on there way
#1344 |
alright i finally have a computer at my disposal lol. I'm gonna take you guys wayy back to when i stopped posting pics and build up to current day. i have done a bunch of things like replacing the "s" plenum box under the dash and putting metal AC ball vents from a 65 wildcat in then the drop coils in the rear and the rear disc, the posi (currently still trying to make happen), I've installed an even better passenger fender I've installed a new hood since the last one got hit in the hit and run, I've been sanding off all the old nasty paint of the door and shooting them with a coat of primer and paint which made them look soo much better then before, I've had a flat and ended up turning the white lines inside and I've even replaced the thermostat and water pump recently, as well as getting parts together for the 7004r swap i hop you enjoy all the pics of those upgrades and installs as well as the random pics taken around town or at my college.
#1345 |
more
#1346 |
even sandblasted,primed and painted the vacuum pod and linkage for the passenger kick-panel vent
#1347 |
took the hood off na dwas getting ready to install the hood from the 67 i found at pick' n pull ill post a picture of it
#1348 |
more
#1349 |
and i took it to c/10 kings c10 get together with the new hood on
#1350 |
then i went to the turlock swap meet and had some fun there got some cool stuff for the garage and old school craftsman toolbox which i keep in the truck
