Old 04-20-2014, 09:23 AM   #1376
Hart_Rod
Hart_Rod's Avatar
Re: 68 S/C update.....
New tank is installed!! Very high quality piece from Boyd's tanks. Craftsmanship is top notch. My only quibble was with the placement of the vent/rollover valve - it's right under one of the bed braces making it very difficult to get to. 3" more to the front and it would have been perfect. Oh well, I just put the hose on before I put the tank up in the hole. Other than than that, I would highly recommend it.
While I had the tank out I also redid my fuel filler neck with a bigger pipe (2"). When I had originally put the filler neck together, I used an 1.75" pipe and then flared the end that connects to the tank which was a 2". It worked most of the time, but if I got a gas pump the flowed really fast, it would burp fuel. So this time, I used 2" pipe for the entire piece. I know that's not a lot bigger, but that's all the room I have up in the bedside. Hopefully it let everything flow a little better than the other one. I also welded a bracket to the pipe to mount it to the bed floor. The tie wrap I've had on there for the last 4 years needed to go
Hart_Rod is offline   Reply With Quote
Old 04-20-2014, 10:46 AM   #1377
Hart_Rod
Hart_Rod's Avatar
More pics
Old 04-20-2014, 11:02 AM   #1378
Rusbuilt
Rusbuilt's Avatar
That looks real good Rob!
Rusbuilt is offline   Reply With Quote
Old 04-20-2014, 11:04 AM   #1379
likaroc13
Rollin' Old Skool
That looks nice Rob! Dig the slight stance alteration as well.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-22-2014, 01:17 PM   #1380
mcbassin
Still Learning
mcbassin's Avatar
Rob,
Do you have any more info about the fuel door/lamp housing install? Do you know what donor vehicle the hinge came from? How is it fastened? I am planning to do the same install for my filler. One more question, how did it fill at the station? plenty of flow? thanks
mcbassin is offline   Reply With Quote
Old 04-22-2014, 01:41 PM   #1381
jmedero
jmedero's Avatar
It's just for show. This truck does not run on gas... It runs on plutonium. He has one of these in the buddy console
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 04-22-2014, 03:26 PM   #1382
Hart_Rod
Hart_Rod's Avatar
Thanks Rus!
Thanks! Its suprising how much difference one inch can make, .
I've been found out!!!!!
Originally Posted by mcbassin View Post
Rob,
Mike - The flow with the smaller pipe was adequate at best. The flow with the new pipe seems to be a lot better, but I've only filled it once. I'll get back to you on future results. I got the hinge at Home Depot. It is attached to the marker light with a 2-part super glue. Here's a thread I started showing how I put it together:
http://67-72chevytrucks.com/vboard/s...d.php?t=380571
If you have any other questions. Let me know.
Old 04-22-2014, 04:09 PM   #1383
AJohn6
Knuckle head
AJohn6's Avatar
This thing is looking amazing. Are you still working on the tranny program? I got my '09 dialed in pretty good but I am still not happy with my power downshift.
This truck has a lot of parts that I am interested in. The Dakota Digital gauges you have how did you work the OBDII interface? Also, did you get the boost referance gauge from DD? I may have missed it, but how did you hook the paddle shifter up to the trans and is it the only thing used to shift the trans?
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 04-22-2014, 08:30 PM   #1384
Hart_Rod
Hart_Rod's Avatar
Originally Posted by boynton View Post
I am using the auxiliary cooler from a 3/4 ton truck that will hopefully sit right in front of the ac condenser and get fresh air through the grill in combination with the trans cooler that is built into the radiator. Speedway also has a few nice coolers that can be mounted in the fuel rail. I think I have a nib extra 18" aluminum if you are interested.
Do you have pictures of this?
Still playing with the tranny. I used this software program to help withe tuning the shift points and the TCC lock up:
http://www.hptuners.com/forum/showth...Table-Software
I used the Dakota digital BIM -01-1 OBDII interface. I have a NGK wideband that has a display and plugs into my HPTuners interface so I can also datalog it. The paddle shifters have a wireless interface that connects to the Tap up Tap down (TUTD)wire the Speartech pulled when he build my harness. The only way an A6 can be shifted "manually" is with a TUTD switch.
Old 05-13-2014, 11:41 AM   #1385
Hart_Rod
Hart_Rod's Avatar
No big updates. Just fine tuning a few things. The new tank and filler tube are working great. I have filled it several times and other than having to be careful when it's almost full, I have had zero problems.
Old 05-13-2014, 05:38 PM   #1386
thelonerife
thelonerife's Avatar
Those gauges would look good in my truck lol.
thelonerife is offline   Reply With Quote
Old 05-18-2014, 10:52 AM   #1387
Hart_Rod
Hart_Rod's Avatar
, yes they would, .
Picked up some bling bling for the truck yesterday. Do you guys think it will look out of place?
Old 05-18-2014, 02:10 PM   #1388
Hatzman
Hatzman's Avatar
I wouldn't do it Rob, looks too... Country? Even for the "farm" truck.
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 05-18-2014, 02:23 PM   #1389
likaroc13
Rollin' Old Skool
Originally Posted by Hart_Rod View Post
, yes they would, .
That'd be great for the sleeper look, but you gotta think they'd know something is up when they see those huge meats you're rolling in the rear. Oh, & I'm sure it doesn't sound too sleeper-ish either?
Phillip
My Build threads:
Pics:
Previous Rides:
Old 05-18-2014, 02:59 PM   #1390
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I'm waiting for pics with the topper on the truck!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-18-2014, 03:39 PM   #1391
Rusbuilt
Rusbuilt's Avatar
^^^^me too!!
Old 05-18-2014, 05:16 PM   #1392
Hart_Rod
Hart_Rod's Avatar
^^^^me too!!
Here you go......
Old 05-18-2014, 06:09 PM   #1393
BigMike
BigMike's Avatar
I say roll with it. It looks old school country cool.
Can you give us a full side shot of the whole truck with the topper?
Mike
BigMike is offline   Reply With Quote
Old 05-18-2014, 11:16 PM   #1394
C10_ustacould
Mike
X2... but so far I think it looks cool. Some big (20") truck ralleys would look cool with the topper.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 05-18-2014, 11:56 PM   #1395
mcbassin
Still Learning
mcbassin's Avatar
Heck yeah Rob! you're ready to go camping at the lake now
Old 05-19-2014, 12:53 AM   #1396
Hatzman
Hatzman's Avatar
Exclamation Re: 68 S/C update.....
Guess I'm the odd ball here! Heck no! Pull that thing off.
Steve
Old 05-19-2014, 07:17 AM   #1397
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
chevyguy_72 is offline   Reply With Quote
Old 05-19-2014, 07:58 AM   #1398
Hart_Rod
Hart_Rod's Avatar
Mike
Thanks,
Same here on the ralleys....:9
Thanks!
Originally Posted by chevyguy_72 View Post
Different strokes I guess. Cool thing is, I can pull it off in 5 minutes,
Here are some better pictures.
Old 05-19-2014, 09:51 AM   #1399
SeTx67
SeTx67's Avatar
Lose the camper IMO
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 05-19-2014, 09:53 AM   #1400
smbrouss70
smbrouss70's Avatar
I LOVE it!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
