#1376 |
Re: What Did You Do With Your Truck Today ?
Ordered more parts
#1377 |
I got most of the welding done on my frame boxing.
![]() What a long week ![]() ![]() There must be a rock in the line. |
#1378 |
Got the front clip most of the way off. Left a few bolts to soak in penetrating oil for a while longer. Broke 2 or 3 of them - oh well. First time it's been off in, well, maybe ever.
Once the clip is off, maybe Monday (truck lives at work) I'll start paint prep for the front frame section and start sizing up the motor mounts. |
#1379 |
Built a dolly for the cab last week. Today the cab comes off the frame, onto the dolly and I start finish welding the frame.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#1380 |
I removed all my hinges from the cab and put all new bushings in
#1381 |
56 - autocross
#1382 |
![]() Join Date: Jul 2012
Opened up the box of the newly arrived AAW harness kit. Looked at the diagrams.
Holy snot, what have I gotten myself into? |
#1383 |
Showed the project to my co-owner & girlfriend, got a lot of blank looks for all my excitement.
#1384 | |
#1385 |
Installed seat belts and took my 3 yr old for his first ride. You should have seen the look on his face. You would have thought he was in a parade. Took a couple hours to get the smile off his face!
#1386 |
I had family in town all weekend. Took them to the airport and then started in on a couple projects. Pulled 3 leaf's from the front packs and 1 from the rear. Pulled the grille, headlamp bezels and painted them along with the grill trim and bumpers front /rear. Painted the wheels satin black and mounted the whitewalls. Changed all the fluids in tithe truck, oil bath and oil filter. I'm beat and headdred to bed early.
#1387 |
arturo7
Sir. just take a package at a time and you will do fine - i was a bit taken aback when i got my harness also - but if you take your time - re- read your directions and follow the schematic you will be ok hope this helps - good luck |
#1388 |
got my axles redrilled off my 8.8 for chevy pattern. Removed the load leafs from my spring packs in prep for the flip. Now recovering from the worst stomach flu I have ever gotten.
My '59 Build Thread |
#1389 |
wheelie
yeah dem old trucks will do that to ya sometimes - gett better and back to it ! |
#1390 |
Finished the under dash ac mount except for minor stuff (kick diffusers and hose cover). Think I will move on to on to hanging the doors...
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#1391 | |
Also, take a look at this guys page, good detailed information on how he did his truck. The link is to his build, also look at his link "electric shop", it has a good check list and general wiring info. http://www.alanhorvath.com/54chevy/ezwire_day1.php
#1392 |
I would be nervous and figuring out a way to get the co-ownership corrected if her level of excitment is low or lacking. She might decide she needs a new pair of shoes and sell her interest to a third party....
#1393 |
Thanks for the advice and encouragement on the wiring, guys.
I took a long look at the garage today and decided it could use some attention. Need to add more lighting, more outlets, more shelving, and give it a good de-clutterization before the chassis arrives. Guess I'll meander over to the garage threads for inspiration, |
#1394 |
Got the I-6 exhaust out, removed the last of the old fuel line, set the front body work on a pallet for later, got 1/3 of the rivets for my shock mounts off / out (prep for power steering kit), got the I6 mounts out of the cross member. Some more de-griming with a putty knife & a dental pick.
Almost ready to pull the steering box & buy some engine mounts, see how this is going to line up. |
#1395 |
started preparing my 55 2nd project for storage for the winter while I go to Arizona where I have a 69 shortbed stepside to tinker with.
#1396 |
Oh, and I bought the engine & trans cross members I'll need from CPP.
Next: pressure washing, priming & painting the frame + maybe do the power steering project. |
#1397 |
Painted the steelies body color
Posted via Mobile Device |
#1398 |
Removed the ridiculous trailer hitch that the PO had installed.
#1399 |
Did some welding practice on my firewall ... Still a long way to go before I can put in new cab corners
#1400 |
looks good iceman
cleans up the firewall
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
