Closed Thread
Old 10-24-2012, 07:54 PM   #1401
rollenhard
rollenhard's Avatar
Re: What Did You Do With Your Truck Today ?
looking sharp Iceman_70
practice practice practice
rollenhard is offline
Old 10-24-2012, 08:57 PM   #1402
la hi
Finished adding turn signal's project==they work now.
la hi is offline
Old 10-25-2012, 07:41 PM   #1403
Speedbumpauto
Speedbumpauto's Avatar
Finished exhaust system complete with electronic cutouts. Now to pull it out, weld between the tack welds, clean it up and get it coated.
Speedbumpauto is offline
Old 10-25-2012, 07:50 PM   #1404
hotrod1
56 - autocross
hotrod1's Avatar
Hey Speedbump. Do u have a build on that truck? I want to see more pictures.
hotrod1 is offline
Old 10-25-2012, 08:07 PM   #1405
Chevette
Chevette's Avatar
Speedbump: Your truck is looking very nice. Looks like your putting some big meat on the rear. What size you using? Exhaust looks great and so do the tail lights. Lookin' good.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline
Old 10-25-2012, 10:49 PM   #1406
yossarian19
Pressure washed the frame from cab forward & got the nut off of the original pitman arm. Managed not to break anything. Still have to remove the arm & the rest of the box then pull the lower shock mounts. Will at that point be ready for the engine & trans cross members + power steering kit that are on the way.
yossarian19 is offline
Old 10-26-2012, 10:32 AM   #1407
Speedbumpauto
I'm not very digital, so I haven't figured out how the build thing works, but I did get a digital camera and kept a pictorial log of everything I did on my home computer. The tires are 31x16.5x 17 Hoosiers on 13.5 x 17 Welds. Thanks for the compliments, I'm starting to feel pretty good about this as it's the most extensive(expensive?) build I've ever attempted and sometimes it seems like there's never going to be an end.
Old 10-26-2012, 12:39 PM   #1408
renegade8720
Great looking truck!
Renegade
renegade8720 is offline
Old 10-26-2012, 01:28 PM   #1409
Daze57
Daze57's Avatar
x2 ^
Daze57 is offline
Old 10-26-2012, 02:48 PM   #1410
NEWFISHER
NEWFISHER's Avatar
Tossed some stainless 3/4 trim rings on it, unbolted the front seat and ordered a pleated seat cover and matching headliner. It seems to never stop!
NEWFISHER is offline
Old 10-26-2012, 08:40 PM   #1411
agnes the dog
agnes the dog's Avatar
The starter was making a horrible sound. Crawled underneath and found that my starter housing is cracked from the PO torquing it too tight. At least I know what that sound is now! Off to the parts store again...
agnes the dog is offline
Old 10-26-2012, 10:54 PM   #1412
jrdecat
watched the snow melt off of it...
jrdecat is offline
Old 10-27-2012, 02:27 AM   #1413
yossarian19
Got the pitman arm, steering box & column removed. Still need to separate column from box, or source a 60s / 70s column to use. Not really sure how to separate column... hammer hasn't worked yet.
Old 10-28-2012, 07:15 PM   #1414
Docs fitty6
Most all of Saturday was spent re-working fenderwell headers. I hope to gain enough clearance to replace the 195-45/15 tires for something BIGGER
I hope to get some good video of the initial break in at the Vette shop this next week!
By the way. I cleaned up the frame/suspension of all loose stuff and then used and hand brushed coat of POR-15.
Has anyone else used this product? A bit spendy at close to $150/gal. But damn does this stuff work. And lasts a long time too. I first started using it in the mid nineties before it was available retail.
later
Docs fitty6 is offline
Old 10-29-2012, 02:15 AM   #1415
NEWFISHER
NEWFISHER's Avatar
Masked and resprayed the interior.
Then painted the hub caps and emblems, tossed on some buffed/ground whites and drove it to the Drive Inn for a shake. Found an engine for my Burb, so the Apache is now for sale
Old 10-30-2012, 09:31 PM   #1416
Daze57
Daze57's Avatar
hey guys -
For any of you 55- 59 chevy guys who are still utilizing your lower side cowl vent - i have a great tip for ya - for the doors i was trying a bunch of different materials to replace the worn cracked rubber . After buying the ''so-called'' replacment foam stuff for these vents - 3 times ( they tear v v easily - pure junk ) i tried other stuff and it all did not work . what is ''the'' best stuff is a old car or truck inner tube - get a busted one -make a template and a shot of wd-40 and there ya go - seals great !!!!!
hope this helps out anyone.
i am a guessin that the 47 -54 - guys may find a use for that tube rubber also '
Daze57 is offline
Old 11-01-2012, 06:56 PM   #1417
meter swinger
meter swinger's Avatar
My rear fleetside bumper just showed up today. It will be the first time iv'e had one on the the truck. I'm so excited i'll probably sleep with it tonight.
meter swinger is offline
Old 11-01-2012, 09:37 PM   #1418
meter swinger
Looks good. Ordered it from brothers on friday and its already here. Now to find some brackets.
Old 11-01-2012, 10:10 PM   #1419
Chevette
Chevette's Avatar
If I put my bumper on the kitchen table, I'd probably end up sleeping with it too (out on the lawn). I'm sure she'd eventually cool down and let me back in the house though, as long as I didn't try to sneak the bumper back in. Looks good Meter. Make sure you put lots of polish on it.
56 Chevy PU
Chevette is offline
Old 11-01-2012, 10:14 PM   #1420
vwjohnny
vwjohnny's Avatar
Wow! Bumper envy! I worked on my firewall and frame. More scrubbing to remove 50+ years of grease and yuck. Sprayed my new posies drop springs. Hope to be ready for paint in a few weeks. Ready to have my truck back.
vwjohnny is offline
Old 11-01-2012, 11:01 PM   #1421
meter swinger
I have five boys. You outta see the crap they drag in the house
Old 11-01-2012, 11:30 PM   #1422
agnes the dog
Drove it.... :-) 180 mile round trip to buy a Camaro T-5 5 speed. I was really surprised that I got 17mpg!!! Just gotta find an s-10 tail housing now.
Old 11-02-2012, 12:21 AM   #1423
OrrieG
OrrieG's Avatar
Yall do not want to find out what happens when you rebuild your engine during the winter in a two bedroom apt. That was in my second year of marriage, I am pretty sure it took me another 5 or so and a new house before she forgot.
OrrieG is offline
Old 11-02-2012, 09:34 PM   #1424
tttuba
Here is what I did with my truck on the 31st.......
tttuba is offline
Old 11-03-2012, 12:15 AM   #1425
meter swinger
GRAVEDIGGER
Closed Thread
