Old 06-19-2014, 07:25 PM   #1426
Rusbuilt
Rusbuilt's Avatar
Re: 68 S/C update.....
Nice bro!
Rusbuilt is offline   Reply With Quote
Old 06-19-2014, 10:11 PM   #1427
raull
raull's Avatar
i like the exhaust set up , im leaning towards magnaflow myself , how about a video?
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 06-19-2014, 10:50 PM   #1428
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Rusbuilt View Post
Nice bro!
Thanks Russ.
Raul - if you look on my Instagram I have several. Glad your back Bro!
Hart_Rod is offline   Reply With Quote
Old 06-19-2014, 10:51 PM   #1429
Houston Ben
Houston Ben's Avatar
Nice, will that bracket work for a square body?
Houston Ben is offline   Reply With Quote
Old 06-19-2014, 10:54 PM   #1430
Houston Ben
Also, let us know on that cruise control! Anything new on the trans front?
Old 06-19-2014, 11:06 PM   #1431
GSFMECH
On the road
GSFMECH's Avatar
I love the exhaust Rod!!
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 06-20-2014, 08:06 AM   #1432
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Houston Ben View Post
Nice, will that bracket work for a square body? Also, let us know on that cruise control! Anything new on the trans front?
Thanks. I'm not sure about the square body. Post a picture of the pedal mount area. Tranny seems to be working fine, but I'm still playing with the tune.
Thanks!
Old 06-21-2014, 05:31 PM   #1433
Westcoastpainter
Talking Re: 68 S/C update.....
Hey Rod,
nice build so far! love the power plant and all the goodies! Now I'm just a little foggy about your oil pans. are you running a sts-v pan on the 6L80 and a Ctsv pan on the motor? Im building a 6.0 lq4 drop member 70 swb with a 6L80e as well, need the most clearance as possible obviously so I'm just trying to confirm.
or are you running a camaro pan on the 6.2? I know it was earlier in the thread its just so many pages to sift through! Nice DD also! those taillights look different to me, maybe just real new camaro?! Thanks Rod in advance. Derek
Westcoastpainter is offline   Reply With Quote
Old 06-21-2014, 06:48 PM   #1434
68Gold/white
Originally Posted by Hart_Rod View Post
No big updates. Just fine tuning a few things. The new tank and filler tube are working great. I have filled it several times and other than having to be careful when it's almost full, I have had zero problems.
Are the filler/cap assy from Boyds, also???
Job well done!!!
68Gold/white is offline   Reply With Quote
Old 06-21-2014, 07:34 PM   #1435
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Westcoastpainter View Post
Hey Rod,
Thanks Derek. If you are running the PB extreme dropmember, you will need to use the Camaro FBody oil pan (98-02), that's what's on my son's truck with the LS1 and PB stuff. Here's the oil pan on my gold 68 (factory front crossmember):
http://www.ebay.com/itm/CTS-V-OIL-PA...93ab02&vxp=mtr
and the tranny pan:
http://www.ebay.com/itm/Auto-Trans-O...ed8365&vxp=mtr
Make sure you get the matching tranny filter to go with it.
Job well done!!!
I made the filler tube from a piece of 2" exhaust pipe and the cap came from West Marine. It's a gas filler for a boat.
Old 06-21-2014, 09:15 PM   #1436
Jon01
Jon01's Avatar
Do you think a truck oil pan would have cleared if you didn't have the extreme DM?
I've got a mild for my truck and would rather not change the pan.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 06-22-2014, 06:38 PM   #1437
Hart_Rod
Hart_Rod's Avatar
The truck pan will probably work for the mild drop member, but I'm not sure how far it will hang below the crossmember.
Old 06-23-2014, 11:09 AM   #1438
Hart_Rod
Hart_Rod's Avatar
This weekend we drove the truck over to Biloxi for Scapin' the Coast. We cruised over there at 75-80 mph with the AC blowing cold and the motor taching around 21-2200 rpm, . I think the fuel milage was around 14 mpg. I think engine is still a little on the rich side, but not to bad considering what it is.... The only thing that would have made it a little better would have been cruise control (that gets installed this week...). I only saw a about 7-10 67-72s at the show but they were all pretty kewl. Made some new friends, Jason and his son from DeadEndGarage. They had a sweet 72 that was slammed to the ground. I also met up with a couple of boardmembers, Track71 and Big Country, who both brought there C10's. It was a cool show with a little bit of everything. I'm pumped for CTC '14!!!
Old 06-23-2014, 11:28 AM   #1439
mcbassin
Still Learning
mcbassin's Avatar
Looks like good times....
mcbassin is offline   Reply With Quote
Old 06-23-2014, 12:01 PM   #1440
superflysteiny
superflysteiny's Avatar
Awesome
superflysteiny is offline   Reply With Quote
Old 06-23-2014, 12:01 PM   #1441
Houston Ben
Jon, look at my build, I have a drop but don't know how much as I bought it that way. I am using the stock truck oil pan and have not had a problem.
Old 06-23-2014, 12:10 PM   #1442
Believe it or not I forgot the show was this weekend. Could have joined you guys and see the ole farm truck.
Old 06-23-2014, 03:44 PM   #1443
Rusbuilt
Rusbuilt's Avatar
Love the pics!
Old 06-23-2014, 10:49 PM   #1444
Bennett68C10
Bennett68C10's Avatar
Nice pics
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-23-2014, 11:16 PM   #1445
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I gotta get my crap together so I don't miss this next year!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 06-23-2014, 11:43 PM   #1446
thelonerife
thelonerife's Avatar
Looks like a good time.
thelonerife is offline   Reply With Quote
Old 08-13-2014, 05:52 PM   #1447
shearjs
shearjs's Avatar
Any updates to the farm truck lately?
shearjs is offline   Reply With Quote
Old 09-15-2014, 09:14 AM   #1448
Hart_Rod
Hart_Rod's Avatar
Should have some by the end of the week...........
Old 09-15-2014, 10:36 AM   #1449
Low Elco
Right on, congrats!
Low Elco is offline   Reply With Quote
Old 09-15-2014, 02:48 PM   #1450
68jewel
On the path to financial ruin!
68jewel's Avatar
Quit slacking on the pics Rob and post them ASAP!! We know you've got some good one's.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
