Closed Thread
Old 11-03-2012, 08:48 PM   #1426
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
Read thru the TF one piece thread, watched the videos, took notes and modified my doors. I elected to keep the latch piece where it is and compenstated on the other side. So far looking good, tomorrow going to put in the regulator and masonite "glass" to fine tune it.
OrrieG is offline
Old 11-05-2012, 12:19 AM   #1427
mobileortho
mobileortho's Avatar
Wanted to get the rear speakers off the floor, so I cut the box down so that it would fit in the cab corners.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline
Old 11-05-2012, 03:09 PM   #1428
OrrieG
OrrieG's Avatar
Still finetuning the windows, on hold until the channels get here. Made a support for my floor jack to hold the doors during hinge installation.
OrrieG is offline
Old 11-05-2012, 05:35 PM   #1429
crossfire84
crossfire84's Avatar
nice work
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 11-07-2012, 09:19 PM   #1430
mknittle
mknittle's Avatar
Finished up my new transmission cross member. and got a quart of rust bullet.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 11-08-2012, 03:48 PM   #1431
NEWFISHER
NEWFISHER's Avatar
Pulled the seat in the Apache and tore it down to the springs, rebuilding the foam and installing a new fitted cover.
NEWFISHER is offline
Old 11-08-2012, 11:49 PM   #1432
mknittle
mknittle's Avatar
the brown truck brought my front control arm bushings
Mark
My GMC build.
mknittle is offline
Old 11-09-2012, 11:10 AM   #1433
Speedbumpauto
Speedbumpauto's Avatar
FINALLY got the Lokar parking brake the way I wanted it and got the boot to fit without interference from the mounting bolts. I also fabbed up a (I think) pretty sweet shifter for the overdrive unit so I won't have to use that ugly cable and big red knob under the dash.(US Gear V2, not Gearvendors) I'll get the shifter handle chromed to match the other two, but I think it turned out kinda neat. I wanted the E brake handle to stick up some cuz I think it gives a little bit of the "old truck" look.
Speedbumpauto is offline
Old 11-09-2012, 05:58 PM   #1434
renegade8720
Looking good!
Renegade
renegade8720 is offline
Old 11-09-2012, 11:53 PM   #1435
tttuba
Happy Days...got my wheel spacers so I can use the stock wheels with disc brakes. Now to get all the Halloween items that are drying on the truck off so I can install these shiny pieces of metal.
tttuba is offline
Old 11-10-2012, 01:16 PM   #1436
crossfire84
sweet!!!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-10-2012, 03:58 PM   #1437
itstheshu
Finished up the wiring. So I threw the seat back in and took it for a drive.
itstheshu is offline
Old 11-10-2012, 04:23 PM   #1438
waybad
waybad's Avatar
put points plugs cap rotor
waybad is offline
Old 11-10-2012, 04:47 PM   #1439
Dan in Pasadena
Dan in Pasadena's Avatar
How about some more info on that parking brake lever install? Is that stand-off you fabricated necessary for mechanical reasons too or just to make the boot fit right, as you mentioned? Maybe a Lokar part number for it?
Dan in Pasadena is offline
Old 11-10-2012, 07:48 PM   #1440
_Ogre
_Ogre's Avatar
drove mine
good looking parking brake speedbump
i may need to add one to my truck this winter
shop air compressor timer
_Ogre is offline
Old 11-10-2012, 10:28 PM   #1441
OrrieG
OrrieG's Avatar
ac condensate drain line and started fitting doors.
OrrieG is offline
Old 11-10-2012, 10:35 PM   #1442
meter swinger
meter swinger's Avatar
I pulled it out of the garage for first time in about three months. Then it started snow. So i fiqured what the hell, went back into the garage and made a martini and watched some football.
meter swinger is offline
Old 11-10-2012, 11:03 PM   #1443
tttuba
got the adapters and the stock wheels on.
tttuba is offline
Old 11-11-2012, 12:09 AM   #1444
Daze57
Daze57's Avatar
meter swinger
i hope it was very dry where you are ! (i mean the martini)
Daze57 is offline
Old 11-11-2012, 01:23 AM   #1445
meter swinger
Originally Posted by Daze57 View Post
meter swinger
LOL. Dry and Dirty my friend.
Old 11-11-2012, 08:09 AM   #1446
4DSEVEN
4DSEVEN's Avatar
Rear fenders got painted.
4DSEVEN is offline
Old 11-11-2012, 09:55 AM   #1447
Speedbumpauto
That's a pretty fender! Dan, I've grumped about Lokar boot fit before but my limited ability has yet to figure out how to mount that brake(I've used 2) in a way that the mounting bolts or nuts don't interfere with what I consider proper mounting of the boot trim ring. I made the valence or standoff in order to have the trim ring screw down flat with 10-24 nutserts(I hate sheet metal screws) and lay flat with the carpet and still be able to remove the brake assembly if needed. Had to do the same thing with the floor mounted shifter. Maybe I'm just too picky but if they made those boot/ trim rings an inch wider on both, the problem would be solved, IMO. I got the angle I wanted by mounting the front of the brake down to the floor and the rear up through the bottom of the floor. Then I had to fabricate a new link for the cables out of 1x3 tubing since the Lokar link isn't wide enough to clear the bolt the mounting ears attach with. A simple redesign would make that brake infinitely more versitile. Close up pics if you want or need.
Old 11-11-2012, 11:51 AM   #1448
mknittle
mknittle's Avatar
[quote=_Ogre;5695722]drove mine
Show off
Mark
My GMC build.
mknittle is offline
Old 11-11-2012, 10:41 PM   #1449
hsdropout
Set bed on chassis...........still gotta paint the back of cab, 4 fenders and da hood. The backyard booth is too cold now.........
hsdropout is offline
Old 11-11-2012, 11:07 PM   #1450
mknittle
mknittle's Avatar
lookin good!
Mark
My GMC build.
mknittle is offline
Closed Thread
