11-11-2022, 12:30 PM | #1451 |
Post Whore
Re: My Dusty 71 GMCe Electruck
a little shipping update on that master cylinder
11-11-2022, 12:39 PM | #1452 |
Post Whore
so lessons learned by doing any project any "build" the devil's in the details and you can get 80% of the big stuff done in 3 weeks and then spend months chasing the small stuff, so here we go, lets get it
I think it's a good idea to have a brake and an emergency brake before taking Electron for a spin around the block just in case things get exciting so the new transmission seems to be longer than the TH350 or at least that's how it sits under the cab, so The Greg needs to extend the parking brake linkage 6" on my '69 the driver side has the adjustable fine threaded rod like so |
11-11-2022, 12:43 PM | #1453 |
Post Whore
the other side the texter's side has a fixed length mushroom double headed rod which I decided to cut off one end and welder on a 6" grade 8 bolt with a standard hex head (this head has to be small enuff to fit through the hole / slot in the frame rail)
I think I used the belt and suspenders method on this, where first I weldered up the bolt to the rod, then ground that flat(ish) then slipped the steel sleeve over it and bugger welded that as well |
11-11-2022, 12:44 PM | #1454 |
Post Whore
The curse of the if I touch it and remove it I better clean it, inspect it, MEDIA BLAST it, and POWDER COAT it continues...
11-12-2022, 05:43 PM | #1455 |
Post Whore
got the new tailgate on, fit great, good quality piece, only trouble was the left (driver side) round hinge thingie had a bit of a slight imperfection in it that we gently persuaded with a punch to get the lower hinge to go smoothly inside it
11-12-2022, 05:46 PM | #1456 |
Post Whore
getting the fiberglass rear rollpan to fit was a bit of a stretch
Note To Self: get new bedsides |
11-12-2022, 09:55 PM | #1457 |
Ebrake setup should work well. Like the tailgate
71 C10 72 K20 72 K10 Super Kirk |
11-13-2022, 11:35 AM | #1458 |
Time to put disc brakes in the rear with Tesla electric parking brakes?
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
11-13-2022, 02:16 PM | #1459 |
Post Whore
11-13-2022, 02:17 PM | #1460 |
Post Whore
11-13-2022, 02:19 PM | #1461 |
Post Whore
managed to perfectly align the brand new fiber glass roll pan to the bad body lines of the bed sides and luv the roll pan look, whacha all think?
11-13-2022, 08:27 PM | #1462 |
I’m a fan of the pan…….
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-13-2022, 10:02 PM | #1463 |
BlahBlahBlah
My son is a commercial electrician, he has this sticker on his hard hat.
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 11-14-2022 at 08:32 AM. Reason: too many words |
11-13-2022, 10:31 PM | #1464 |
Who Changed This?
I laughed at the sticker 'til I cried!
11-15-2022, 12:06 PM | #1465 |
Post Whore
so this could explain the soft 2018 Honda CR-V brake pedal
11-15-2022, 12:08 PM | #1466 |
Post Whore
more detail in this video EV Update Honda CRV Bad Brake Master Cylinder
11-15-2022, 11:11 PM | #1467 |
My understanding is that brake fluid is hygroscopic so perhaps that vehicle had been in a flood or sumpin.
buddy |
11-16-2022, 11:09 AM | #1468 |
BlahBlahBlah
All the blasting and coating you do makes me want to get a cabinet and an old oven. Blasting and powder is something you can do all winter without worrying if your shop is warm enough to paint in. Or maybe move in next door to you =)
11-16-2022, 12:00 PM | #1469 | |
Post Whore
anyway I keep my media blasting cabinet outside so in my case media blasting is not an all year round sport as the media gets moist/wet as far as oven advice see if you can land a larger commercial pizza oven or one of them stackable double deckers that you can start off by using just one half and then join them together to bake longer items as far as moving next door, two words for you: H.O.A. Media Blasting Advice: Replace The Glass |
11-16-2022, 12:26 PM | #1470 |
Post Whore
the good news is the new used $80 dollar Honda CR-V master cylinder showed up last night and appears to be much more better
11-16-2022, 01:17 PM | #1471 |
I'm still curious to see if you'll have enough bore and stroke to operate the C-10 brakes effectively
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-16-2022, 01:31 PM | #1472 |
Post Whore
yeah, me too, my friend Patrick, our friend Patrick inputed all the measurements and lengths of both the Honda CRV and the C10 into his wrist watch calculator and it spit out that the stroke or piston travel is almost identical, it was identical to the thousandths of an inch
11-16-2022, 02:34 PM | #1473 | |
11-16-2022, 08:22 PM | #1474 |
I cried after I saw what a two month bill was!
11-17-2022, 01:34 PM | #1475 | |
Post Whore
SOME HONDA CRV MASTER CYLINDER SPECS the 2018(ish) Honda CRV master brake cylinder piston is 1" in diameter (aka bore) and travels 1.5" (aka stroke) in and out of the tube thingie |
