Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 04-14-2006, 06:30 AM   #126
see ten
WTB this ad
see ten's Avatar
Re: Wheel/Tire Fitment Pictures & Info
Well the rally wheels are gone and have been replaced by 17" Wheel Vintiques Cruzers. The rears are 17x9.5 with 4.75" of backspace with a 275/50. Up front is 17x8 with 4" of backspace and a 255/50. Tires are Nitto NT 450. I bought the wheels and tires from www.newstalgiawheel.com . The guys who actualy built them are in Fresno www.wheelvintiques.com . My drop is still the same. Front is a 2.5" drop spindle with a 1" drop coil. The rear has a 6" drop coil. I also used the Super track bar in the rear and an extreme drop trailing arm crossmember. All the parts came from www.earlyclassic.com .
see ten is offline
Old 04-16-2006, 02:58 PM   #127
Boog
laying low
Boog's Avatar
Well it's still a good looking truck in spite of the new wheels. JK
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 04-17-2006, 08:51 AM   #128
clif1968
Junior Member
clif1968's Avatar
Didn't see this combo so I thought I'd throw it in to. Wheels are 15x10 with 3 1/2" bs. Tires are 295/50/15 on all 4. All stock suspension.
clif1968 is offline
Old 04-27-2006, 12:34 AM   #129
bs25j
bs25j's Avatar
Is 4.75 in of backspacing not gonna be enough for a 9.5 in wheel? I found some wheels i like with zero offset and was wondering if they will work? btw the tires ill be running will be roughly 30 by 10 in.
bs25j is offline
Old 04-27-2006, 02:20 PM   #130
72Short_Cut
72Short_Cut's Avatar
yah i need to order my rims and tires here as soon as i can so i can start driving mine, but im ordering 22's. i need to know what overall hieght i can run, whats the widest tire i can run and what backspacing (+ or-) do i need in order for there to be no rubbing. i got a 3/5 drop kit.
thanks
-Ryan
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline
Old 04-28-2006, 07:03 PM   #131
saxmo
saxmo's Avatar
when checking for the widest tire that'll fit, I saw something real kewl on HorsepowerTV. They tied a weight (bolt or nut,etc.) to a string, and taped the string to the fender... the weight makes the string hang straight down, and you can measure from the string directly to the inner part of the fenderwell (measure to any bumps in the metal that'll be closest to outside ridge of fender). That'll give you a close idea of widest rubber that'll physically fit inside the fender. They ordered the rubber, then used a backspacing tool mounted to the rubber tire to find out what backspacing they would need on the rim. I believe the tool was called a mount mate, but not sure.
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline
Old 04-28-2006, 07:13 PM   #132
saxmo
saxmo's Avatar
here's a link to the info I found on the tool.
http://www.infinitemotorsports.com
saxmo is offline
Old 05-04-2006, 05:22 PM   #133
Film Guy
Junior Member
Film Guy's Avatar
I am also interested in the tire mount mate. Where can I get one? I cannot find much info on this tool.
Film Guy is offline
Old 05-05-2006, 04:37 PM   #134
dylan1970
dylan1970's Avatar
15 X 8 with 235/60/R15 Goodyear Eagle GT II
2.5" spindles Front
C-notch and Air Ride in rear with 2" drop blocks
dylan1970 is offline
Old 05-12-2006, 11:24 PM   #135
bs25j
bs25j's Avatar
I put the truck part way back together to test my new wheels.
There 22 9.5's with 6 in backspacing and 285 35 22 toyo proxes. They fit good. No rubbing yet. You can see pics here.
http://s26.photobucket.com/albums/c1.../My%20project/
bs25j is offline
Old 05-17-2006, 05:11 PM   #136
BigSky71
LAIDOUT
BigSky71's Avatar
Nice work bs25j, you are re-motivating me!
67 2wd Shorty
Build Pictures
BigSky71 is offline
