Old 05-20-2007, 03:34 PM   #126
BigTruckDriver
BigTruckDriver's Avatar
Re: Xmas In March, Thanks To Porterbuilt.
Originally Posted by MEANGREEN70 View Post
I'm with jlaird, I think they should be in the tank out port to the bags, just like your normal tool comp. I maybe wrong, but as long as you have air stored in the tanks is going to build moisture when you use it. Even if you put the trap between the comp and the tanks. Right.
If the air is dry to begin with when it goes into the tank how could it make any moisture?
BigTruckDriver is offline   Reply With Quote
Old 05-20-2007, 06:25 PM   #127
SCOTI
SCOTI's Avatar
How do you dry it effectively? I know you need to have a length of line long enough to allow the air to cool before it goes through the trap/filter & then into the tank. I also know that copper is typically whats used because of it's ability to dissapate heat.
W/o the length of line, the air is warm/hot. Once it cools in the tank, there will be moisture.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2007, 09:03 PM   #128
MEANGREEN70
MEANGREEN70's Avatar
Wire bags today, but not working right. The rear airs up on the blink of an eye, the front barely moves. Do you guys have any ideal as to whats going on?
MEANGREEN70 is offline   Reply With Quote
Old 05-22-2007, 01:17 AM   #129
watahyahknow
watahyahknow's Avatar
thats a weight issue the engine weighs heaviewr on the bags you might want to restrict the flow to the rearbags a bit
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-22-2007, 08:22 AM   #130
MEANGREEN70
Thats what i was thinking, do you know of a way to restrict the air to the rear?
Old 05-22-2007, 10:17 AM   #131
jimmydean
jimmydean's Avatar
Depending on how you have it plumped, you can use flow restrictors like I had to do to slow the fill and dump rates of my 1/2 system.
I used these from SD for fill control.
[IMG]http://*****************/images/products/mid_1-2_PTC_Valve_Fill_Controls.jpg[/IMG]
<edit> They just go inline with the fill line. If you don't have a line to run it, they have one with NPT holes for a nipple or fitting.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-22-2007, 12:21 PM   #132
MEANGREEN70
Below is pics of how I plum my system, so I guess I need to get 2 of control valve. one per side.
Old 05-22-2007, 12:23 PM   #133
MEANGREEN70
one pic.
Old 05-22-2007, 08:18 PM   #134
MEANGREEN70
I installed two on and off valve for the rear, so the rear works fine now, I can regulate the air so it goes up and down really good. The front I still cant get no lift, I don't know if is the valve or bags. you can See the front trying to lift, but it doesn't. Does anybody have an idea as to why . maybe I need different valve or bags.
Old 05-22-2007, 08:32 PM   #135
bedsled71
bedsled71's Avatar
plug the line from the front to one of the rear valves to see if it still does it
bedsled71 is offline   Reply With Quote
Old 05-22-2007, 08:47 PM   #136
PBFAB.COM
PBFAB.COM's Avatar
How much pressure is in the tanks? Sounds like there isn't quite enough to get it up.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-22-2007, 10:56 PM   #137
MEANGREEN70
Are taking about moving the front line to the rear, and see if it act the same way?
Old 05-22-2007, 11:03 PM   #138
MEANGREEN70
I dont know how much pressure is in the tanks, I dont have a gauge hook on yet, I was just trying to get the system plym to see how it would work. I guess I do need to get some kind of gauge. Nathan do you know what the pressure should be at the tanks? I'm useing two 3 gal tanks. Can you tell I'm new to all this, but I'm learnig as I go.
ps. I still love my dropmenber. thanks
Old 05-22-2007, 11:59 PM   #139
bedsled71
bedsled71's Avatar
it takes alot more to psi to lift the front..so thats probably the deal
Old 05-23-2007, 12:12 AM   #140
BigTruckDriver
maybe a smaller valve in your rear will force more air to supply the front?
Old 05-23-2007, 12:22 AM   #141
PBFAB.COM
PBFAB.COM's Avatar
150psi. is the minimum pressure switch I would run. It is going to take all of it to pop that front end up with that BBC hunkered in there. What is your pressure switch rated at? 150psi. should do fine, but you can get an adjustable one for fine tuning.
I think it's just a pressure issue.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-23-2007, 07:38 PM   #142
MEANGREEN70
You guys were right, it was a pressure issue, I finally got the front end to lift.
The comp that came with the kit I bought maybe a 1or2, are not that great. It takes to long to fill the tanks, so I'm going to have to look for a different comp.
Old 05-23-2007, 08:47 PM   #143
SCOTI
SCOTI's Avatar
.... The comp that came with the kit I bought maybe a 1or2, are not that great. It takes to long to fill the tanks, so I'm going to have to look for a different comp.
Errrr. . . ..... make that 2 compressors.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2007, 08:53 PM   #144
MEANGREEN70
I finally found a front clip, so is time to go back to work.
Old 06-16-2007, 09:37 PM   #145
SCOTI
SCOTI's Avatar
Ohoooo, looks very straight. Where did you find it?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2007, 09:47 PM   #146
babyblueoval
babyblueoval's Avatar
Nice!
I just happened picked up a '68 front end last weekend. I'm not sure mines quite as nice as yours but it's close.
I can't wait to start on my Blazer.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 06-19-2007, 08:07 AM   #147
MEANGREEN70
I took a road trip down to Austin.
Old 06-19-2007, 01:57 PM   #148
randomhero472
randomhero472's Avatar
go w/the viar 380's for compressors, you can get 2 on ebay for under 300 shipped
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-19-2007, 03:38 PM   #149
MEANGREEN70
I was thinging 2 480 viar, are they pretty good?
Old 06-19-2007, 03:46 PM   #150
SCOTI
SCOTI's Avatar
Since most are using the 380's I would say the 480's would work just as well. Got that front clip in place yet?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
