08-19-2010, 01:47 PM | #126 |
True Addiction
Re: Getting Started
I was going to order a new front bumper from Brothers, anyone have any comments on fitiment, quality, etc? Any other brand you would suggest?
Thanks,
RCC |
11-29-2010, 06:00 PM | #127 |
True Addiction
Re: Getting Started
Here are a few pictures of where I am at. Pulled the LS1 and basically recouped my money. Ordered a brand new LS376 / 480 last week. Hopefully it'll be here for christmas if I'm lucky. Still got a lot of work to do, but at least it looks like a truck again.
RCC |
11-29-2010, 06:01 PM | #128 |
True Addiction
Re: Getting Started
Couple more....
RCC |
11-29-2010, 06:32 PM | #129 |
Re: Getting Started
^^wow!^^
11-30-2010, 12:44 AM | #130 |
Re: Getting Started
So sick.
11-30-2010, 12:54 AM | #131 |
Junior Member
Re: Getting Started
Nice!
Posted via Mobile Device |
02-04-2011, 12:02 AM | #132 |
True Addiction
Re: Getting Started
Finally got here.....
Sorry the pictures are messed up, I tried way to many times to get them right.
RCC |
02-04-2011, 12:15 AM | #133 |
Re: Getting Started
Sweet man, its looking badass!!!
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-04-2011, 12:20 AM | #134 |
True Addiction
Re: Getting Started
Thanks, hopefully it'll run strong. I figure with 480 HP and being quite lite it will. Might have to hang some lead off the back bumper!
RCC |
02-04-2011, 06:20 AM | #135 |
chevy runs deep
Re: Getting Started
Wow nice lookn truck u have
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
02-04-2011, 07:37 PM | #136 |
GM ONLY BABY!!!
Re: Getting Started
Kewl, now install it this weekend.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-04-2011, 08:57 PM | #137 |
Re: Getting Started
That's gonna be a sick ride. What are your plans for tail lights? My truck also has a shaved rear end with inset bullet style tail lights. It was done by the previous owner, and I'm not a huge fan of them and want to find something different.
I'll definately watch this build with interest as I just commited to a GMPP LS3/480hp as well today.
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. Last edited by Nova_Cobra64; 02-10-2011 at 06:25 AM. |
02-09-2011, 11:55 PM | #138 |
True Addiction
Re: Getting Started
Need to pick up a few more bolts for connecting the converter to the flex plate. Does any recommend using lock washers, or just loctite? Also, any suggestions for converter fluid? Thanks
RCC |
02-13-2011, 08:13 PM | #139 |
True Addiction
Re: Getting Started
Motor fits very well. Installed converter then dropped in the motor. Once all the bolts were nice and snug I went to go bolt up the converter to the flex plate. When I checked it out it had perfect clearance, about a 1/16". Hopefully I can get some headers picked out soon. I will be ordering the Concept One accessory set, and a computer from Speartech very soon.
Any word on the Doug Thorley "big tube" headers. From what I've read I should try to run at least a 1 & 5/8" header.
RCC |
02-13-2011, 10:10 PM | #140 |
Re: Getting Started
looks real nice!
02-13-2011, 10:41 PM | #141 |
Re: Getting Started
that's sick man!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-22-2011, 01:42 AM | #142 |
Re: Getting Started
Dudee... SICK truck! I like everything you've done so far. What are you gonna do for brakes and booster? That firewall looks too clean to mount anything on!
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
04-19-2011, 07:34 AM | #143 |
True Addiction
Re: Getting Started
Skoffice - I'm running an under dash set-up, purchased from Scott's Hotrods. It's a really solid piece and I highly recommend.
I am about to start ordering brake components and was hoping for a little input as to proportioning valve, fittings, etc. I have a 7" booster and CPP master cylinder under the dash, break like bulkhead with -3 inlets, wilwood calipers in rear that have 1/8"-27 NPT inlets, and will be ordering wilwood D52's for up front. I would like to run all hard lines with four braided houses at each corner. Is Stainless pliable? What fitting and flares? Anyone have any suggestions from experience? Thanks!
RCC |
04-22-2011, 11:15 AM | #144 |
PROJECT 7DEUCE
Re: Getting Started
I myself cannot help you with the question but I am also getting ready to order break parts and am interested in what people are gonna recommend??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-21-2011, 05:59 PM | #145 | |
Re: Getting Started
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
06-21-2011, 07:09 PM | #146 |
True Addiction
Re: Getting Started
bruin_d: I have & will try to post a pic in the next few days.
RCC |
07-03-2011, 11:08 AM | #147 |
Kvn1011
Re: Getting Started
awesome build!! subscribed
02-11-2012, 12:30 PM | #148 |
True Addiction
Re: Getting Started
Few pics...
RCC |
02-11-2012, 10:52 PM | #149 |
Re: Getting Started
clean!! very nice
02-11-2012, 11:42 PM | #150 |
Re: Getting Started
Very Nice.
1972 GMC (PROJECT LONG OVERDUE) 1998 SWB 4WD |
