View Poll Results: 13" Brakes: Any Interest?
Yes, interested 195 95.59%
No thanks 9 4.41%
Voters: 204. You may not vote on this poll
Old 01-12-2008, 07:28 PM   #126
SCOTI
SCOTI's Avatar
Re: How Much Interest: 13" Big Brake Upgrade
Pics . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2008, 07:41 PM   #127
smbrouss70
smbrouss70's Avatar
Is that spindle modification something that we will be able to do on our own, or will we have to buy the spindles from them? Can you get some pics of how that bracket bolts to the spindle?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-12-2008, 07:49 PM   #128
SCOTI
SCOTI's Avatar
You do your own spindle mod which cuts the costs for the kit. I don't have further pics @ this time but will be taking some as I install a 'kit'. I'll keep updating.
I will also be supplying them w/the dimensions for the truck rear housing ends by the end of the weekend. The push is on for 13" C5 rears!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2008, 07:55 PM   #129
smbrouss70
smbrouss70's Avatar
So what does this "kit" come with? The hubs and bracket? I assume the rotor and caliper/pads are off the shelf type stuff?
BTW... THANK YOU for doing this for us. Maybe they should be called SCOTI brakes!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-12-2008, 08:10 PM   #130
SCOTI
SCOTI's Avatar
Billet hub & CNC brackets are the main items to make it work. Everything should be available separately so you can build it using the hubs/brackets & used parts if that's your direction. The rotors wouldn't be a direct swap because C5/6 are car pattern vs truck pattern. There's some extra work to make it happen.
I'm just the guy providing feedback & helping w/the details...... The manufacturer will make the appropriate introductions once they're closer to being production ready. Thanks regardless.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-13-2008, 09:20 AM   #131
gringoloco
A guy with a truck
gringoloco's Avatar
Sweet! Any idea about compatibility w/ a drop spindle? Also, why the blacked-out caliper? Hiding the "K word"? Does it use the stock dust shield holes?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-13-2008, 11:18 AM   #132
SCOTI
SCOTI's Avatar
They will move to drop spindles next. The idea was the need to start somewhere & the factory spindle is the easiest (most logical choice).
Yes.... the 'blackout' is to limit exposure until they wish to promote the product line themselves. They are attached to the spindle like most aftermarket kits (no need to reinvent the wheel there).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2008, 04:40 PM   #133
bagged74
its just $$$$$
bagged74's Avatar
looks almost identical to the baer kit I have on my 72
bagged74 is offline   Reply With Quote
Old 01-19-2008, 09:06 AM   #134
revn67
revn67's Avatar
so what is involved with modding the spindle? what do you cut or grind orrr......?
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 01-19-2008, 09:37 AM   #135
SCOTI
SCOTI's Avatar
I will be trial fitting prototype kit #001 to a set of OE spindles, then some 3" BellTechs & 2.5" Western Chassis spindles. McGaughys & DJM's will possibly follow. I don't believe any other brands will be tested (these seem to be the 4 most popular choices).
What did that 'kit' set you back if I might inquire? I would also like to know what was included in their 'kit' (what specs rotors/calipers, hub, etc....?).
PM if you don't wish to announce it to the world.
Cut off the original caliper 'ears' & do some clearance grinding. How much to grind will vary depending on which rotor/caliper set-up is chosen.
I'm waiting for a big brown box for now . . ......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2008, 10:54 AM   #136
class01
class01's Avatar
sign me up
class01 is offline   Reply With Quote
Old 01-19-2008, 05:47 PM   #137
jlaird
jlaird's Avatar
scoti, so you are going to be buying all these aftermarket spindles and cutting off the ears?
What's the deal with the rotors studs? Are those threaded in the pic?
jlaird is offline   Reply With Quote
Old 01-20-2008, 01:40 AM   #138
SCOTI
SCOTI's Avatar
I already have the BT & WC spindles & will determine what to do on the other brands after I play w/these.
Yes on the studs...... They're threaded ARP fasteners.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2008, 04:42 AM   #139
Ackattack
Ackattack's Avatar
I assume that these won't clear a 15" wheel correct?
That just means I'll have to wait until I get my wheels before I get the brakes, cause it's just a roller in the garage now on pos 15" stockers.
Ackattack is offline   Reply With Quote
Old 02-03-2008, 05:57 AM   #140
GKsport67
GKsport67's Avatar
Yes SIR!!! I'm with it,i want to swap out my 6lug anyway!
GKsport67 is offline   Reply With Quote
Old 02-03-2008, 07:20 AM   #141
SCOTI
SCOTI's Avatar
I received e-mail notification this morning w/a tracking number. Kit #0001 is officially on it's way.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2008, 05:04 AM   #142
LMDGUY
LMDGUY's Avatar
very intresting.. keep us posted.
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 02-06-2008, 07:37 AM   #143
revn67
revn67's Avatar
nice.....any guess on the price? can't wait to be able to get this kit!!
Old 02-06-2008, 01:41 PM   #144
SCOTI
SCOTI's Avatar
Here's an idea . . ....
C5/C6 Bracket Kit- GM TRK/Tall Spindle (w/hardware) 85.00
C5/C6 Billet Hub- GM TRK 72-87 (w/bearings, seals, caps, ARP studs) 349.00
C5 PBR Caliper Kit 295.00
C5/C6 A/C Delco Ceramic Pads 69.50
Front Brake Line Kit 60.00
C6-Z51 DBA-4000 Rotors (13.4" x 1.25" w/5.00 x 4.75 + 5.00 pattern) 396.00
Shipping/Handling w/INS 78.00
For a total of $1332 & change. This is w/upgraded rotors. Base C5/C6 rotors aren't as much (and aren't as good). There's also options for drilled/slotted rotors if you're so inclined.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2008, 01:57 PM   #145
pcmcobra
pcmcobra's Avatar
scoti,
how bout some pics of the disassembled kit?
also, would this work on light duty brake equipped trucks?
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 02-06-2008, 02:42 PM   #146
72 Pick Up
Put me down for a sets Front & back
72 Pick Up
72 Pick Up is offline   Reply With Quote
Old 02-06-2008, 11:04 PM   #147
SCOTI
SCOTI's Avatar
Originally Posted by pcmcobra View Post
scoti,
The LT spindles has not been confirmed yet. The only spindle the 'kit' is known to work w/is a stock HD spindle. I will be testing on Bell Tech & Western Chassis drop spindles for HD brakes in the near future.
I'll post up pics once the kit is received.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2008, 04:35 AM   #148
Sir Fisher
Sir Fisher's Avatar
Originally Posted by RED72blazer View Post
I want bigger brakes...but for a 4x4
me too!! i want larger front disks for my 4x4; i'm thinking of going to a machine shop and have them do it for me in my neck of the woods...
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 02-07-2008, 07:04 AM   #149
gringoloco
A guy with a truck
gringoloco's Avatar
This looks to me like the only things you absolutely need from this kit. The other stuff may be able to be sourced elsewhere cheaper. They even give you the option on their website of ordering as many or as few parts as you like...
-Chris
Old 02-07-2008, 08:26 AM   #150
revn67
revn67's Avatar
sick!!! just in time for my tax return to show up......can't wait to see your finished product on your truck scoti!! im waiting for pics to see what it'll look like altogether
