Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-03-2008, 10:13 AM   #126
19723DR
19723DR's Avatar
Re: 1972 3dr Suburban Build Thread
Thanks for the compliments. I'm still working on refining the attachment to the door. I'm going to order some of that 3M Dual Lock re-closeable tape that Hart_rod suggested. I thought I would give it a shot. I received my registration for the Cache Valley Cruise-in. I've got 4 months to finish my interior. It would be nice to see some of the local board members there if you are in the area.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 03-04-2008, 09:32 AM   #127
19723DR
19723DR's Avatar
Well I got a little work done today. I put the drivers side door panel back together. I also used a 1/4'' bolt threaded inside out to attach the handle. Then I put a 1/4'' inch nut on the outside inside the handle. I will make a cover to hide the 1/4'' nut. I also stretched vinyl over the passenger kick panel. Next I'll make a peace to fit between the two passenger doors.
97 Z71 3 Door
Old 03-18-2008, 12:46 AM   #128
19723DR
19723DR's Avatar
Well I've been waiting for my Dual lock tape to arrive so I made two panels for the tail gate. They will have a pattern like the doors and be attached by the dual lock tape. The tape showed up last night. I bought ten feet by 1''. I'll say the stuff Is pretty strong. I also ordered some new door handles of Ebay. Here the are. Last weekend I bout a Pioneer DEN-P3900MP deck for a little under 100 bucks. I also ran the speaker wires to the front and back. So far sounds good I just need an amp and some subs.
97 Z71 3 Door
Old 03-18-2008, 01:10 AM   #129
19723DR
19723DR's Avatar
I also made a spacers for the window crank and door handle. I used a 2'' hole saw and a step bit for the center. I also made a 1/4'' spacer for the window crank using a 2 1/2'' hole saw and then covered in vinyl. Looking back I wished That I had made the holes smaller on the door panels. I also removed the plastic clips and replaced them with Dual lock tape on the front door. Between the bolt through the handle and the tape, the door panel is not going anywhere.
97 Z71 3 Door
Old 03-22-2008, 03:52 PM   #130
71 burb
what size wheels and tires you have on there while you where painting it very nice job very motivating
71 burb is offline   Reply With Quote
Old 03-22-2008, 07:53 PM   #131
Frizzle Fry
Frizzle Fry's Avatar
Hey just a word of advice: If you haven't already, seal the back sides of your door panels with something; wood/deck seal maybe. If you don't that pressed board will absorb humidity over time and expand/warp.
Frizzle Fry is offline   Reply With Quote
Old 03-23-2008, 09:08 AM   #132
19723DR
19723DR's Avatar
Thanks. Those are 15x8" American Eagle wheels with BF Goodrich 295/50/15 tires.
So many panels to make I am kind of getting bogged down but I will get to it. I need to pick up some more vinyl before I can go any further.
Right now I am in the process of putting a Flow Master muffler on. I want to make a rumble when I drive... right now all I hear is the engine fan.
97 Z71 3 Door
Old 04-01-2008, 08:34 AM   #133
19723DR
19723DR's Avatar
All right we finally got some good weather. I welded up my Flowmaster... sounds so much better. Another small problem, my starter was not engaging. I thought I might need a new one, but after a closer look the bolts were just loose.
I did a little work on the panels. I made a peace to fit in the spare tire hole out of 1/2 plywood. I'm still working on the indent under the window. I'm thinking of either a filler peace or make it part of the panel. I also finished the A pillar piece. More pics.
97 Z71 3 Door
Old 04-01-2008, 06:36 PM   #134
ColoradoK5
ColoradoK5's Avatar
Nice progress. Looks like you will be ready for the show in now time!
ColoradoK5 is offline   Reply With Quote
Old 04-04-2008, 07:08 AM   #135
19723DR
19723DR's Avatar
Thanks a lot. I try to get something done everynight, sometimes it doesn't work out, I'm lucky if I can squeeze in a half hour.
I am really looking forward to the shows this summer, most of my show friends haven't seen what I've done to the burb since last summer. They will be shocked!
97 Z71 3 Door
Old 04-04-2008, 02:01 PM   #136
Rokcrln
Rokcrln's Avatar
Heck we are shocked and we get to see it all the time. Nice work.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-07-2008, 08:50 AM   #137
19723DR
19723DR's Avatar
Thanks Rokcrin. It's hard not taking on another project and staying focused on my suburban. I don't know you manage as many projects as you do. I've been watching your suburban 4 door build, it's gonna be sweet! l'm keeping mine a 3dr, I think its funny when I tell my kids to go to the driver's side passenger door and they get mad.
I made some progress today, I finished my tailgate panel, but you'll have to wait a bit for the photos, my server is gonna be down, so my pictures will disappear. I'll post pictures on Monday night.
97 Z71 3 Door
Old 04-09-2008, 05:18 AM   #138
19723DR
19723DR's Avatar
Here's the pics of my tailgate panel and the Dual-Lock tape:
97 Z71 3 Door
Old 04-09-2008, 05:23 AM   #139
19723DR
19723DR's Avatar
I sprayed truck bed-liner in the spare well. I also made a couple of panels for the sides of the tailgate and covered the top one in vinyl.
97 Z71 3 Door
Old 04-09-2008, 05:48 AM   #140
Frizzle Fry
Hey maybe we can swap rear panel trim. I need another short one, and it looks like you could use another long one. I'll have to check to be sure that's gonna work, but might be a win-win. I also have the piece that goes between the drivers-side split.
Old 04-09-2008, 05:59 AM   #141
kyull67
kyull67's Avatar
Your interior is looking real sharp! Great work.
kyull67 is offline   Reply With Quote
Old 04-09-2008, 07:18 AM   #142
19723DR
19723DR's Avatar
You just might have something there. Look into it and let me know what you find out. I don't see why you couldn't flip it around and use it on the other side.
97 Z71 3 Door
Old 04-09-2008, 07:25 AM   #143
19723DR
19723DR's Avatar
Thanks kyull. It'll be no time before yours is painted and you'll be doing your interior.
Today I went and looked at a '71 Cheyenne long bed that I would like to convert into a short bed. Just have to convince the wife. She's right next to me now, should I ask her? We all need a project right? I mean, the suburban is almost done and I need something to keep me busy.
97 Z71 3 Door
Old 04-13-2008, 08:39 AM   #144
19723DR
19723DR's Avatar
Well some how she said yes! I picked it up Monday night. It's a 71 Cheyenne long bed with a 350/350, no A/C and power steering. It also came with a short bed frame. Here it is:
97 Z71 3 Door
Old 04-13-2008, 07:02 PM   #145
Hart_Rod
Hart_Rod's Avatar
The Burb's looking great! Have you thought about doing this?
http://www.67-72chevytrucks.com/vboa...d.php?t=220511
Hart_Rod is offline   Reply With Quote
Old 04-14-2008, 06:46 AM   #146
19723DR
19723DR's Avatar
Yeah I've thought about it but it looks to easy. Juusst kidding It's on the list
Thanks, you're the man
97 Z71 3 Door
Old 04-23-2008, 07:21 AM   #147
70short/step
70short/step's Avatar
Great looking panels you have made!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 04-23-2008, 07:30 AM   #148
19723DR
19723DR's Avatar
Thanks a lot. I've been really busy this week--but mostly with the other truck! My wife's uncle was parting out a '70 GMC and I've been picking anything that was salvagable off of it. I have made some progress on the Suburban, I did get some good parts to use on the suburban, like door handles, sun visors, etc. I guess I need to update my pictures.
97 Z71 3 Door
Old 04-23-2008, 08:01 AM   #149
19723DR
19723DR's Avatar
Old door handle:
Home made gasket material (seal for a light fixture):
New/old door handle:
New muffler, welded it in myself:
New outer windows seals:
Fakey door panel:
I've been really busy!
97 Z71 3 Door
Old 04-23-2008, 08:23 AM   #150
Swifty
Swifty's Avatar
This is one beautiful Burb!!!! Makes me want to start building one!!! Great job & amazing Craftsmanship!
Swifty is offline   Reply With Quote
