01-16-2009, 08:00 PM | #126 |
On the road
Re: The GSFMech Build
It's an old Edelbrock Torker, they quit making them years ago and I know I could use a better more modern intake. I always thought they were cool and wanted to run it. They make real good low end and mid range power for a single plane manifold.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 01-16-2009 at 08:22 PM. Reason: spelling |
01-16-2009, 08:03 PM | #127 |
On the road
Then I got on the master cylinder. I tore everything apart, stripped and repainted and used all new rubber grommets and seals and installed it. Then I bled the brakes
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
01-16-2009, 08:05 PM | #128 |
On the road
Then I installed the headliner and got back assembling the dash. I finished up the dash and then got the side glass in. I used all new weather strip, fuzzies etc. and a new set of GM door rubbers I got from Wynne (HuggerCST). This thing is tight.
01-16-2009, 08:08 PM | #129 |
A guy with a truck
Wow! Great attention to detail
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-16-2009, 08:09 PM | #130 |
On the road
Then I got the insulation and carpet, seats etc. back in, its wild how the color flops out in the sun in that first photo. I'm going to change the carpet after the Pate swap meet, it's stained and worn worse than I remember
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 01-16-2009 at 08:11 PM. |
01-16-2009, 08:11 PM | #131 |
Looks great!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-16-2009, 08:12 PM | #132 |
On the road
Thanks Guys
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 01-16-2009 at 08:12 PM. |
01-16-2009, 08:13 PM | #133 |
On the road
I then got back up front and installed the condenser, filter drier etc. I still need to charge the AC. I had bought a o-ring kit from Chevy duty so hopefully there will be no leaks.
01-16-2009, 08:16 PM | #134 |
On the road
A few shots out in the sun
01-16-2009, 08:20 PM | #135 |
On the road
Of course I had to take it for a spin. Yee haw, it's been a long time.
When I get back home (I'm at work now) I'll get the trim back on, bumpers hood etc. and we have a little more polishing to do on the paint. I'm getting real excited about getting it back on the road. You never really finish a project like this. I still have a lot of plans for it down the road.
01-16-2009, 08:44 PM | #136 |
I'm proud for ya...i know ya excited!
R.I.P. Killer 71 10/26/07 |
01-16-2009, 09:04 PM | #137 |
On the road
Thanks Kaleb, you bet I am
01-16-2009, 09:42 PM | #138 |
beautiful
01-16-2009, 10:20 PM | #139 |
Looking great! I like the torker intake and the detail in the engine bay. The all medium blue look is nice too.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-17-2009, 04:11 PM | #140 |
how do you like that lizard skin sound deadener now that you have driven the truck?
01-17-2009, 06:17 PM | #141 |
Very Nice!!
Can't wait for Cruising the Coast so I can see and hear it!!!!
01-17-2009, 08:38 PM | #142 |
On the road
Well I'm not sure about the lizard skin yet, I don't have the door panels in yet and I had the windows down. I should be able to give a good report when I get done and get it out on the road.
Bill I'm ready to go to CTC with it as well. Unless the sky falls I will have it there for sure.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 01-17-2009 at 08:40 PM. Reason: spelling |
01-18-2009, 09:35 PM | #143 |
Wow, you didn't waste any time on reassembly, I enjoy seeing your attention to detail. It all looks great. Let me know when you get your new carpet in, I'd be interested in buying your old one to get me by until I get mine done.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 01-18-2009 at 09:36 PM. |
01-19-2009, 06:51 AM | #144 |
On the road
Thanks Chris. I sent you a PM about the carpet.
Hey how much longer before we see your trucks in print? I guess they don't tell you that. I don't want to miss it, I have a hard time keeping up being gone half the time.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 01-19-2009 at 06:52 AM. Reason: spelling |
01-19-2009, 03:52 PM | #145 |
He told me six months to a year and a half is the average time frame after the shoot, that was the beginning of June, so some time this year??? I hope soon, I'm not a very patient person anyways and this wait is killing me!
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
01-27-2009, 04:52 PM | #146 |
On the road
Well Chris, congrats dude, your wait is over. I'm looking forward to seeing it when I get home, my copy should be waiting on me.
03-14-2009, 12:44 PM | #147 |
On the road
Time for another update. A lot has went on since I posted and I did not have a chance to take any photos of my own. A buddy of mine captured me riding around one evening and took these. I want to clean it up and get it out in the sun and take some photos when I get a chance. Anyway until then these will have to do. I have it on the road but still have lots I want to do to it and will update as I progress.
03-14-2009, 12:48 PM | #148 |
On the road
A few more
03-14-2009, 12:50 PM | #149 |
On the road
Last for now.
Oh yeah, for those that asked the Lizard skin makes a BIG difference. You can't feel any engine heat at all and it's much quieter. I can't wait for warm weather and try the AC.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 03-14-2009 at 12:54 PM. |
03-14-2009, 12:59 PM | #150 |
That truck looks great
70 SWB STEPSIDE 70 BLAZER 09 challenger |
