09-03-2008, 12:03 PM | #126 |
www.73-87chevytrucks.com
Re: No Regrets - The Rebuild post
The 73-80 bushing will want to sit in that hole though...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-10-2008, 09:52 AM | #127 |
It'd be alot cooler if you did
ok, I checked it out the other day... the earlier mounts will work but not very well. Will everything be fine if I just get the new style bushings?
09-10-2008, 03:00 PM | #128 |
Yep.
09-12-2008, 01:57 AM | #129 |
Schlongbed MEMBER (heh)#15
I have learned SO much from this thread alone. Thanks Brother.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
09-12-2008, 10:28 AM | #130 |
cool. and no problem.
09-14-2008, 08:59 PM | #131 |
I had big plans for this weekend, but since Summit decided to ship me an empty box instead of my sway bar, it kinda put me in a foul mood. It didn't take much convincing to get me out of the shop with all the rain out side... so I just said the hell with it and took the week end off.
I did get a chance to snap a few pics of the four link being put back together. None of the bolts are tight yet. And yes, the fresh paint already has dust on it in the crevices from grinding in the shop without covering it up.... I wiped it down but noticed in the pics it showed up in the hard to reach ares. Last edited by smashingchuck; 12-07-2009 at 09:59 PM. |
09-21-2008, 06:01 PM | #132 |
A few updates...
My first attempt at adding a sway bar to the front has failed. I bought one for my application (78 chevy 2wd c10) from summit. It is way to wide and my spindles hit it when turning. I understand that I have a "custom" application, but I don't see how it would even work on a stock truck with the width they sent me. So now I have to send it back to them after I called them and told me they shipped me an empty box the first time. Sounds fishy, but it's the truth! What's even more frustrating is that it's going to set me back at least another two weeks,because I can't do final assembly on the front suspension until I weld the sway bar mounts to the control arms. I can't paint them either, and I prefer to do all my welding on the bench... so it's back to the drawing board on that one. So to keep busy, I started installing the motor and trans today.... in went in easy as pie. Probably because the typical things that hold up an engine install were out of the way. Nothing like sitting on the frame rail to tighten the bell housing bolts! I was also finally able to make sure the drive shaft cleared the new hoop for the first time. Luckily, it does. However, as my projects always go, I did find another problem upon dropping in the motor and trans... The new headers I have muck up the "z" bar for the clutch linkage. Although I think I already have the problem figured out... it's just another one of those things that I have to modify. Last edited by smashingchuck; 09-21-2008 at 06:08 PM. |
10-03-2008, 11:39 AM | #133 |
I'm at the point now where I have been gathering parts (and waiting for the right ones to get here) that I can start moving forward again. I spent the entire week last week planning out the air management and working on some small items. I just today finally got a sway bar that looks like is going to work. Yesterday I got the twin to my air tank that I couldn't find anywhere, and I *think* I've got all the fittings I need to redo all the plumbing. So the objectives for the week end are:
1. Get second tank mounted 2. Get all valves mounted 3. Wrap up entire front end (build sway bar mounts, paint lower control arms, and do final assembly on everything) 4. Start bending air lines. I bought 60' of 3/8 stainless line to do all the plumbing. It may take a little longer to run it, but I'm positive it will look great. I snapped a few pics of the different things this morning... Last edited by smashingchuck; 12-07-2009 at 10:02 PM. |
10-12-2008, 02:03 PM | #134 |
I've got the z bar, shocks, sway bar, and twin tanks mounted in the last few days. Still haiting on my flaring tool to get here from Parker.
Here's some pics got to get back out to the shop. Last edited by smashingchuck; 12-07-2009 at 10:07 PM. |
11-08-2008, 12:38 AM | #135 |
Excellent Thread
I'm very impressed!! quick question about your driveshaft hoop, is it the camera angle or is you hoop not centered? looks like your driveshaft is about to hit. just curious
CHEVY ONLY |
11-08-2008, 03:52 PM | #136 |
The panhard bar isn't adjusted yet.
11-08-2008, 03:59 PM | #137 |
oh
CHEVY ONLY |
11-16-2008, 06:38 PM | #138 |
I'm getting to the point where I am able to start bending my air lines now. It is not the easiest thing to do, but what is? Snapped some pics of it in midstream (ran out of fasteners to tie it to the frame). Also throwing up a pic of how I incorporated my air drier into the set up. Enjoy....
11-17-2008, 02:57 AM | #139 |
>130dB Moderator
I love hard air lines. Rubber just doesn't do it for me...
Can you post a link to where I can get some good line like that?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
11-17-2008, 11:49 AM | #140 | |
here is a link to some I found online, but you should be able to do much better on price. I believe Grainger stocks it as well. http://www1.mscdirect.com/CGI/NNSRIT...90752&PMT4NO=0 Last edited by smashingchuck; 11-17-2008 at 11:50 AM. |
01-02-2009, 01:29 PM | #141 |
Just realized I hadn't updated in almost two months. I've been busy on other projects taking up my time and money (CHRISTMAS, other truck) but I got back on track this week and should have some parts here later today to start moving forward again. I got a good sized Atlas Lathe for Christmas that needs some elbow grease, too.
I spent the Thanksgiving weekend putting the new motor and transmission in the '87 Silverado, so that took up my Money and time for a while, but I've got a dependable 4x4 with new motor and trans in it, 4.56 3/4 ton axles, and 4" lift for under $2500 total cost involved. Here's some pics I snapped the other day... not much has changed. Last edited by smashingchuck; 12-07-2009 at 10:13 PM. |
01-02-2009, 06:12 PM | #142 |
OK, I only got one thing today. Apparently Jegs has slower shipping times because of the New Years Holiday. So here's what I got done. Picked up the soft lines for the front today, and got them put in, bags bolted down top and bottom. Still have to build brackets to capture them but it's a start anyway. I decided to use the soft lines in this particular spot because it just easier.
new 3/8" lines on bench. I super glued and hose clamped 1/2 heater hose to them for where they cross through the cross member. And with the bags installed. Like I said still need to build brackets to hold these in place and finish the hard line run to the front. more to come.... Last edited by smashingchuck; 12-07-2009 at 10:17 PM. |
01-02-2009, 08:43 PM | #143 |
one more for today and I'm done. I've got all the bends done on the passenger side front air line coming from the valve. I still need to build a bracket to hold the lines at the union, clamp it all the way down the frame, and flare the line at the valve.
01-02-2009, 08:50 PM | #144 |
chevy only
nice work looks good
CHEVY ONLY... Nothin Else ! |
01-21-2009, 06:23 PM | #145 |
looking good bro!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
01-21-2009, 06:44 PM | #146 |
Another Day, Another Dollar
please tell me that your running thsoe mud terrains on it when its done! :P
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
01-22-2009, 12:40 AM | #147 |
thanks!
hadn't planned on it. In the past I have run those on the back of my 'burb for snow tires. |
01-22-2009, 09:14 AM | #148 |
Looks awesome.Your motor is so clean it looks fake. Nice detail work.
01-22-2009, 06:03 PM | #149 |
Looks good man. Nice progress.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
01-27-2009, 01:28 PM | #150 |
Looking good chuck. Do you ever go to Fastnal in TR? I think we passed each other as I was leaving the store. I drive a red 2000 Z71 Tahoe. I reconized your mint green burb.
What shop is doing the body work on your truck? Mine is at a body shop in Mendon. When will you have color on the truck? Keep up the good work. Marc |
