Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-07-2009, 11:18 PM   #126
AJs72K5
AJs72K5's Avatar
Re: AJs 72 Pavement Pounder build
UPDATE 06/07/09: Getting back in the game.
I've been quietly searching for an engine to build to replace the purple 454. I found a smokin deal on racingjunk for everything to build the engine except the heads. Picked it all up today.
Here's the basics:
BBC 454 bored 30 over
Flat top pistons
Erson Cam (288 duration, 492 lift)
I've decided on a set of Edelbrock Performer or Performer RPM aluminum heads. 110cc chamber. This will put the compression right at 9.5:1. Now I just need to find a good set.
Time to start building...
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-08-2009, 09:27 AM   #127
Yukon Jack
Post Whore
Yukon Jack's Avatar
Nice new parts!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-08-2009, 09:29 AM   #128
Burt4x4
Burt4x4's Avatar
Yummy! Now you're REALLY gonna love your rig!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-28-2009, 05:35 PM   #129
AJs72K5
AJs72K5's Avatar
UPDATE 8/28/09: Time to get to work. Works been keeping me super busy lately and the K5 has been neglected. I made a slight direction change on the engine after finally unloading all of the old engine and miscellaneous parts I had laying around. I just placed the "big order" with Summit today. Here's the final specs I'm going with:
Block: GM 2 bolt BBC 454 bore .030 over
Rotating assembly: GM cast crank, Speedpro flat top pistons (3cc eyebrows)
Cam: Comp Hydraulic Roller... yes a roller! (CL11-412-8.... advertised duration 266 In/276 Ex, lift 485 In/485 Ex, lobe sep 112*), Comp roller lifters (included in the comp kit), Comp adjustable timing chain (cam timing adjustable to 1/4*)
Heads: Edelbrock Performer High Compression aluminum cylinder heads...100cc semi-open combustion chamber
Induction: Edelbrock Proflo MPFI fuel injection kit
With the flattops and the heads, compression should work out to just about 10:1. I bumped up compression a bit since I'll be running aluminum heads. If CamQuest 6 is at all accurate, I should end up with this:
Big pic can be seen --> here
Already made a date with my engine builder friend to start on the bottom end of the engine next weekend....FINALLY!
- AJ
Old 08-31-2009, 10:03 AM   #130
Burt4x4
Burt4x4's Avatar
Aw man yer gonna love that 454 power
Mine is about 450HP 550tq @ 9:2 comp
Sooo much fun!!!!
Old 08-31-2009, 10:24 AM   #131
AJs72K5
AJs72K5's Avatar
Thanks Burt. I'll have a ton of questions for you when it's time to run everything for the fuel injection.
- AJ
Old 08-31-2009, 05:32 PM   #132
Burt4x4
Burt4x4's Avatar
I hope I can help, once you get it running take your rig to a Dyno. They can tune your air/fuel mix so NOT to burn up your investment. The Lean & Rich gauge is just a Green & Red LED and I had mine way too lean and the dyno guy said if ran like that in time it would burn up..
So thats my advice on getting the FI tuned.
I have all my Pro-Flo settings writen down so if you eveer need um I got um
Old 08-31-2009, 05:39 PM   #133
AJs72K5
AJs72K5's Avatar
Your settings may be a good starting point, but yeah, was gonna have the smart guys help tune it. I was talking more along the lines of where/how to run the fuel return line, etc.
- AJ
Old 09-01-2009, 10:06 AM   #134
Burt4x4
Burt4x4's Avatar
Cool man, I'll be here
Old 09-01-2009, 04:37 PM   #135
AJs72K5
AJs72K5's Avatar
Stayed home from work today because I wasn't feeling good....until Mr. Brown showed up with my new heads, a few sets of ARP bolts, and the new brake prop valve.
My wife told me to "get my Christmas morning on". So, I had to open one of them up.
- AJ
Old 09-01-2009, 04:56 PM   #136
Burt4x4
Burt4x4's Avatar
SEX-E!!!!!!!!!!
Old 09-01-2009, 08:27 PM   #137
vtblazer
vtblazer's Avatar
Re: AJ's '72 Cruiser Crawler Build
Hey the title changed or sumthin'
Sweet new parts brother!
vtblazer is offline   Reply With Quote
Old 09-01-2009, 09:20 PM   #138
AJs72K5
AJs72K5's Avatar
Yeah, I had the title changed. The more I thought about it lately, the more that "pavement pounder" implied mall crawler to me. Can't have that now, can we?
- AJ
Old 09-01-2009, 11:26 PM   #139
BLUE THUNDER
BLUE THUNDER's Avatar
dude, love the parts and the direction of the build. good luck.
BLUE THUNDER is offline   Reply With Quote
Old 09-02-2009, 12:06 AM   #140
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Great build man. Looking forward to seeing the finished product.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-07-2009, 11:10 PM   #141
AJs72K5
AJs72K5's Avatar
UPDATE 09/07/09 - Engine building: Labor day, and man, I labored. I learned a ton from my engine builder buddy....he made sure to point out all the different ways things can get jacked up as we went. My brain definately feels heavier now. We completed the long block today.
The first hour or so of the day was cleaning and prepping parts. Here's the rotating assembly all laid out on the bench.
Clean block with the main studs installed
Main caps, main bearings, and crank installed
Fitting rings and putting in rod bearings
Pistons installed. Rotating assembly and short block complete. Tightening down the oil pump.
Edelbrock heads installed and torqued down....long block complete. The intake is just sitting there to keep the engine closed up. Same applies to the pan and timing cover
Wrapped up until next weekend
I'm definately happy with what we got done today. Once the cam and lifter set comes in, we'll put the cam in and degree it. Then put on the intake, and button up the timing cover and oil pan.
- AJ
Old 09-08-2009, 05:34 AM   #142
vtblazer
vtblazer's Avatar
Drool!
There's absolutely nothing like building your own motor!
How much more HP do you think you'll have over the last one?
Old 09-08-2009, 09:04 AM   #143
AJs72K5
AJs72K5's Avatar
The last one couldn't even chirp the tires. It had too many internal issues. According to CamQuest, this one should make 520HP @ 5000 and 580TQ @ 4000. It's obviously gonna be a much better built motor....cuz I did it
- AJ
Old 09-08-2009, 09:58 AM   #144
Burt4x4
Burt4x4's Avatar
Hold on Hold on! Drapes in a man space window?? Man o man, I know your wife made you doit right!
heheheh Just messin
Thanks for sharing! I'm lovin it!
Old 09-08-2009, 10:19 AM   #145
AJs72K5
AJs72K5's Avatar
Time out!!!! That's my buddy's man space. In pic #2, those are all motorcycle engines on the shelf....and under the table...that's what's left of the blown nitro engine for his top fuel drag bike.
- AJ
Old 09-08-2009, 02:13 PM   #146
Burt4x4
Burt4x4's Avatar
hahaha well tell him they look nice
Coffee drivin harrasment I suppose
Keep us posted
Old 09-20-2009, 05:42 PM   #147
AJs72K5
AJs72K5's Avatar
No progress these past two weeks. Work had me traveling the past week. Pretty much as soon as I got back, I left for the weekend to go dove hunting...Dad and I did pretty well considering the drought in South Texas this summer.
Cam and hydraulic roller lifters arrived this week. I'm hoping to get them in the engine and button up the engine next weekend.
I still need headers and am on the fence as to what to do about my gas tank....more to come.
- AJ
Old 09-21-2009, 09:58 AM   #148
Burt4x4
Burt4x4's Avatar
Yummy! very close to the Comp cam I used, I didn't go roller though. Sometimes I wonder what the difference would be on that? I drove my K5 around the 'hood' this weekend. Fun stuff thease 454s
Good Times even if I am just picking up dinner hahaha
Old 09-21-2009, 01:38 PM   #149
AJs72K5
AJs72K5's Avatar
Roller equals more power due to less friction on the tappets. And with less friction, it'll be far less likely to go flat on me. I also have a better chance of reusing the rollers if I ever change cams. Getting closer....
- AJ
Old 09-21-2009, 02:23 PM   #150
Arizonak5
Arizonak5's Avatar
one day when i have $$ i will build the same thing :::::::::::::::sigh:::::::::::::: being broke sucks!
1937 Pontiac 2dr
1970 K5 CST
1972 Jimmy
1973 Hickey ent. equipped Blazer
1977 Blazer Chalet #1193
Arizonak5 is offline   Reply With Quote
