Old 01-25-2010, 03:52 PM   #126
68jewel
On the path to financial ruin!
68jewel's Avatar
Re: 69 cst-10
I like the 9" rear end bro........sweet!!!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 01-25-2010, 10:28 PM   #127
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Thanks 68,
Today, seeing as i had the fans done, i let the engine run for about 15 min. Had to shut it off after about 10 from a blown fuse shutting off the fans. had a 20 amp but with a 17amp and 8 amp in line, was a little to much. Replaced it with a 25 amp and no problems. The engine idles high but it would sit between 180-200. Big fan kicks on at about 210 and drops like a rock after that. At 200 just touching the throttle would shake the whole truck. No hesitation as of yet and it hasnt even been timed. just set by hand. Needless to say, im pretty happy with this as the first long run.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-25-2010, 11:41 PM   #128
highperf4x4
Re: 69 cst-10
That's awesome! Drop a video next time.
The shake isn't from a vibration is it?
highperf4x4 is offline   Reply With Quote
Old 01-26-2010, 12:14 AM   #129
ripdog28
ripdog28's Avatar
Re: 69 cst-10
The shaking when the throttle is hit is from the TQ twisting the engine inside the mounts.
69 c-10 BBC
Old 01-26-2010, 12:16 AM   #130
highperf4x4
Re: 69 cst-10
now I really want a vid!!
Old 01-26-2010, 10:55 PM   #131
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I turned the idle down a little after the long run and now you can tell it is a few degrees off on timing. Sitting inside it when i hit the throttle you can feel and see the whole truck twist. The video does not show it much but believe me. The video is from my cell so the sound cuts out because its to loud for the cell.
69 c-10 BBC
Old 01-27-2010, 12:10 AM   #132
highperf4x4
Re: 69 cst-10
Awesome!
Is it just open header right now?
Old 01-27-2010, 02:14 AM   #133
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I have the 3in Pypes Violators on the end of the headers. Ill only have about 3ft of pipe added once i have it done so will still be loud.
69 c-10 BBC
Old 01-27-2010, 08:18 AM   #134
romit1
Re: 69 cst-10
Originally Posted by ripdog28 View Post
88F*** i like the painless. It is east to install, good directions, and has lots of extra circuits/wires for whatever you need, pwr windows/locks..ECT.... I am slacking on it atm due to the holiday and a few things that i am going back over to fix/reroute but i like it. A few more parts (fittings/gauges) and it will be running shortly.
Just picked a kit up on ebay for $250. The guy lived near by me so shipping was a breeze. About to start it this weekend. Will take lots of pick to post for future installers
romit1 is offline   Reply With Quote
Old 01-27-2010, 08:34 AM   #135
nuke1
nuke1's Avatar
Re: 69 cst-10
that is saawweeeeet!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-28-2010, 12:04 AM   #136
drag_72
Ready to go fast!!
drag_72's Avatar
Re: 69 cst-10
timing is definately slow!! lol that must be why the throttle responce is a little slow? sound pretty good all in all man
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 01-28-2010, 01:27 AM   #137
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Timing is not to far off, maby a few dregrees and i dont see much of a slow throttle response.
69 c-10 BBC
Old 01-28-2010, 02:49 AM   #138
highperf4x4
Re: 69 cst-10
Did you post a run down of what you have in that engine and what machine work you did?
Old 01-28-2010, 08:53 AM   #139
ripdog28
ripdog28's Avatar
Re: 69 cst-10
No, between my signature and the HP link i cover most of it. I dont have any work to the heads and just a .30 over, decking to the block. It was stock bore in excellent shape when i got it. The dart heads have the same combustion Hart shape as their Alum heads do.
69 c-10 BBC
Old 01-28-2010, 09:57 AM   #140
mcbassin
Still Learning
mcbassin's Avatar
Re: 69 cst-10
Yo! that engine is sounding MEAN! I bet you can spin the tires at will
mcbassin is offline   Reply With Quote
Old 01-28-2010, 12:38 PM   #141
highperf4x4
Re: 69 cst-10
For some reason I thought you were running a roller cam. I'm starting to get my threads crossed.
I have a couple of questions in addition to your sig. Do you know what size domes your pistons have? And are you running a timing chain or a gear drive setup?
Old 01-28-2010, 12:49 PM   #142
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I dont have the part # on me but the pistons are Keith Black forged. Will have to find the # for the specs. I do have 119CC chambers and with the pistons it is about 10.25:1 compression. It is a single roller timing chain.
69 c-10 BBC
Old 01-28-2010, 02:12 PM   #143
70stroker
70stroker's Avatar
Re: 69 cst-10
dude it sounds sweet. Cant wait till i get my big block back in mine. keep us updated
70stroker is offline   Reply With Quote
Old 01-28-2010, 07:59 PM   #144
highperf4x4
Re: 69 cst-10
Holy crap! That's some big domes! You gonna have to run some methanol in it?
Old 01-28-2010, 08:39 PM   #145
ripdog28
ripdog28's Avatar
Re: 69 cst-10
119CC is the Cylinder head combustion chamber not the piston. Piston is about 12-18cc
69 c-10 BBC
Old 01-28-2010, 09:46 PM   #146
highperf4x4
Re: 69 cst-10
Yeah I got the size of the combustion chambers.
But if you have 119cc chambers, a bored 454 and still 10.25:1 then you've got some BIG domes. By my calculations, that's roughly a 25cc dome!!! Yeah I know, 25 isn't necessarily huge.
Old 01-28-2010, 09:55 PM   #147
highperf4x4
Re: 69 cst-10
This is with a stock bore and making a couple of assumptions too though like 0 deck clearance.
Old 01-28-2010, 11:07 PM   #148
ripdog28
ripdog28's Avatar
Re: 69 cst-10
It is a zero deck but has a 4.280 bore.
69 c-10 BBC
Old 01-28-2010, 11:08 PM   #149
highperf4x4
Re: 69 cst-10
Are the head gaskets .028 compressed?
Probably closer to .043 huh?
Old 01-28-2010, 11:20 PM   #150
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: 69 cst-10
i used the kb silvolite one and it came to 10.371
with zero deck 4.3 gasket bore 4.28 bore and .028 compressed thickness
hey travis how do you post the picture like that
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
