#126 |
69' Chevy Stepside
![]() Join Date: Mar 2008
Re: 1969 Chevy Stepside Restoration/Build up
Got the drivers door hung today, it closes but it sticks out to much at the bottom by the cab corner and I can't seem to adjust it in. You also have to slam it because of the weather stripping I put on hopefully that will break in. Here's some pics of me installing it:
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#127 |
69' Chevy Stepside
Amazing got the bed sides, the rear stepside fenders and the cowl panel painted!
![]() Here's some pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#128 |
looks great man, is the motor up and running?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
#129 |
69' Chevy Stepside
Ya, basically the gas tank shipped last Monday so it should be getting here soon, and I'm going to get an inline fuel pump soon. On page 5 of this I have a video of it starting and running for a couple seconds with a fuel pump in a bucket didn't work so good but it ran. Also I need to build the exaust which I have a Flowmaster muffler and some mandrel bent u bends to make it. Also I have to fix the front brake lines and get some lines to go from the proportioning valve to the master cylinder. Otherwise its good to go!
#130 |
69' Chevy Stepside
I spent most of the day hanging the passenger side door and aligning it. What a pain, but I finally got it aligned and closing good. Then I hung the passenger side fender and that's where the problems started for some reason the fender stuck out about a 1/4 inch from the door. So after a ton of messing with it I finally put washers on the hinges of the door to space the front of the door out. Lines up perfect now, or well as perfect as these trucks are...Also put in the vent windows, door windows and all new weather stripping/felt. Here's some pics:
![]() ![]() ![]() ![]() ![]() ![]() Heres the bed strips ![]() ![]() Bed crossmembers
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 05-05-2009 at 02:17 AM. |
#131 |
69' Chevy Stepside
Started the process of building the bed today!
Here's what I got done: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#132 |
looking good coming togeteher
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#133 |
69' Chevy Stepside
HUGE PROGRESS UPDATE!!!!!!!!!!
![]() Over the last week I've been working on it like non stop! Here the list: 1.Both doors aligned and closing good. 2. Front Fenders and inner fenders installed. 3.Installed door panels 4.Got a parts order in with lots of various things 5.Installed blazer gas tank and new fuel lines 6.Installed inline electric fuel pump 7.New trans cooler lines 8.New trans filter and pan gasket 9.Changed oil 10.Made new brake lines from master cylinder to proportioning valve, and to front brakes and connected proportioning valve to rear brakes 11.Made new power steering line 12.Made a shift linkage 13.Installed grill 14.Installed front bumper 15.Wired fuel guage and pump 16.Put bed on truck 17.Bolted bed to truck and installed side wood strips 18. Installed rear fenders 19.Installed steps 20.Installed rear bumper 21.Bought chrome rear diff cover since mine was all warped and bent so it leaked like crazy. 22.Installed front coter pins and wheel dust covers or whatever there called. 23.Bled brakes 24.Test ran!!!! I'm sure I've missed some stuff but its gone from nothing to almost done in a week so I haven't had time to put updates on here. Heres pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#134 |
69' Chevy Stepside
![]() Photobucket stopped working, I'll upload more tomorrow....
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 05-14-2009 at 03:50 AM. |
#135 |
Your truck looks AMAZING, sure wish i lived closer to take a look at it. nnot much longer and you will be driving that thing. just totally awesome!!!!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#136 |
Under Construction
looking good.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#137 |
looks great man, mine just started, you gave me faith lol
#138 | |
69' Chevy Stepside
Anyway here the rest of the pics from yesterday... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 05-15-2009 at 02:50 AM. |
#139 |
69' Chevy Stepside
#140 |
That looks really good
#141 |
On the fast track to nowhere..
Been a while since I checked this one out. Made a lot of progress
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#142 |
69' Chevy Stepside
Thanks!
I'm amazed at how far its come in such a short amount of time!
#143 |
69' Chevy Stepside
Pulled an all nighter last Friday-Saturday on the exhaust system and just about anything else that was left to do...
#144 |
69' Chevy Stepside
#145 |
69' Chevy Stepside
Here's a video of the exhaust and start up! We bought mandrel bent U bends and used a flowmaster muffler for the exhaust. It comes off the headers and Y's together into a 3" pipe that goes though the rear cross member and into the 3" in on the muffler. Then it comes out as two 2 1/4'' pipes that run out to that back tucked up under the bumper.
#146 |
69' Chevy Stepside
First time its moved under it's own power since the restoration! I couldn't figure out why it was running so bad for a long time until I realized that I connected the left oxygen sensor to the right wiring harness and vica vera. Here's a video of me moving it out of the garage right after we got the exhaust done.
#147 |
69' Chevy Stepside
Here's the pictures of installing the hood and exhaust system.... I also installed the corvette engine covers!!!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 05-22-2009 at 12:35 AM. |
#148 |
Awsome man, did it pass the burnout test? haha
#149 |
69' Chevy Stepside
Haha, haven't tried yet because I can only get the rear brakes to work I'm having a heck of a time getting the fronts to work.
#150 |
69' Chevy Stepside
First test drive video!
Today I got the proportioning valve reset and bled the front brakes again to see if they would start working and now I only have front brakes for some reason so not sure if the shuttle valve moved back and shut off the rear brakes or what but now it will easily burn the rear tires!! ![]()
