02-27-2010, 04:28 PM | #126 |
Re: 70 gmc
That looks like you'll have piston to combustion-chamber interfereance ! Are those pistons correct ? Was the block line-honed. It sure sets high, that's hardly any quench at all..
02-27-2010, 04:33 PM | #127 |
Re: 70 gmc
block has been line honed. like i said in a previous post the machinist straight edge is level with the deck and piston at the pistons highest point.
02-27-2010, 04:38 PM | #128 |
Re: 70 gmc
Part of proper engine set-up (I'm a little rusty), is the space between the piston top and the flat part of the combustion chamber. They call it the quench area. If it's just right (something like .045" to .070") then the piston comes up and swooshes the exhaust gasses out of that area fast and the gas-velocity cools the head down preventing detonation. Just something to be careful of, I don't know of any head-gaskets that thick is all...
I just figured this was the time to ask, vice later... |
02-27-2010, 04:41 PM | #129 |
Re: 70 gmc
thanks for the specs. once i get the bottom end done im gonna put the heads and and adjust valves and turn it over a few times and check how close everything is. what is that playdoo looking stuff you use for that?
02-27-2010, 04:50 PM | #130 |
Re: 70 gmc
I think modeling clay. But that is a different spec. With that you're measuring piston to valve clearance with the cam installed and hooked up.
The piston to head (flat part of the chamber) is what I was worried about with that piston setting so high... Keith Black says .040" is okay, with .035" minimum. You'll need a thick gasket I'm thinking... http://www.kb-silvolite.com/test/art...n=read&A_id=35 Last edited by barthmonster; 02-27-2010 at 04:50 PM. |
02-27-2010, 04:57 PM | #131 |
Re: 70 gmc
ya im going out in the shop in a bit to put the other 4 pistons and rods in.
ill measure it with a mic to see how much its sticking out. Im pretty sure the gasket i bought isnt going to work its compressed thickness it .041 so there is no chance. I found this copper one with .072 so i think it might work depending on the measurements i get later today. http://www.summitracing.com/parts/SCE-013387/ I have always been recommened to run MLS gaskets with a blower, Any idea on how copper would hold up? |
02-27-2010, 09:57 PM | #132 |
Re: 70 gmc
.041 compressed should be thick enough
02-28-2010, 10:07 PM | #133 |
Re: 70 gmc
Got the firewall pretty much done this weekend along with my gauges.
02-28-2010, 10:46 PM | #134 |
VA72C10
Re: 70 gmc
Looks good!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-28-2010, 11:31 PM | #135 |
Re: 70 gmc
Cool. What are you going to put in the center hole on the cluster?
02-28-2010, 11:56 PM | #136 |
Re: 70 gmc
I have a line on a 3 3/8 fuel pressure gauge... we will see if that works out
03-17-2010, 11:34 PM | #137 |
Re: 70 gmc
wow had to dig this off of the 5th page.... thats not good.
anyway heres a few pics. You can see here the headers were rubbing the frame just a little bit i had to trim the frame maybe a 1/4 inch. Heres the main reason i spent the kind of money i did on the headers. No more ground clearence problems.. SWEET Last edited by 70stroker; 03-18-2010 at 12:05 AM. |
03-17-2010, 11:41 PM | #138 |
Re: 70 gmc
That is awesome! I wish had your bank account!
03-18-2010, 06:52 PM | #139 |
Re: 70 gmc
Maybe a few months ago you would of wished that, Not after i bought all these parts. But you would have some cool parts layin in your garage.
03-18-2010, 07:08 PM | #140 |
Re: 70 gmc
Looking good. Keep plugging away at that thing.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser 71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished 93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's 98 Chevy short bed DD 97 Z71 3 Door 51 Suburban-S-10 swap "What other hot rod can you carry 7 of your friends in" |
03-29-2010, 11:36 PM | #141 |
Re: 70 gmc
did cam break in tonight. ran awesome, went without problems. Heres a few videos they were taken with a crappy cell phone so they are not the best. Now on to the wiring and driving.
idleing after the break in Cam break in here Last edited by 70stroker; 03-29-2010 at 11:37 PM. |
03-29-2010, 11:41 PM | #142 |
Re: 70 gmc
Im pumped for you man, i know the feeling. congrats
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-03-2010, 12:18 PM | #143 |
Re: 70 gmc
In the process of installing the painless wiring, Its alot of work but im enjoyin it.
ripdog pm sent |
04-03-2010, 11:06 PM | #144 |
Re: 70 gmc
Awesome.
Watch out for that ripdog fella. He will have you whipping out some "light touches of the throttle" before the engine is broke in! Last edited by highperf4x4; 04-04-2010 at 12:28 PM. |
04-04-2010, 02:17 AM | #145 |
Re: 70 gmc
Hey, i have about an hour of run time, LOL. Just gives me a reason for the wife to allow a 500+ CI or a blown stroker build if it blows in a year or sooner
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 04-04-2010 at 02:17 AM. |
04-04-2010, 12:29 PM | #146 |
Re: 70 gmc
04-24-2010, 11:41 AM | #147 |
Re: 70 gmc
Well a little progress the whole cab and back half of the truck is wired and working. just put the front end on last night. now i got to get my carb rebuilt, install aluminum radiator notch the shroud for the blower and hook up the head lights.
I am very glad to see that front end back on. |
04-24-2010, 02:16 PM | #148 |
Re: 70 gmc
4 lighters rule!!!!
Say did you paint the bottom of that grille black? And when did you put on a bed cover? Last edited by highperf4x4; 04-24-2010 at 02:16 PM. |
04-24-2010, 03:07 PM | #149 |
Re: 70 gmc
yes the bottom of the grill is black. when i bought the truck the previous owner had a roll pan and had that part of the grill painted red to match the body. When i painted it orange i thought it would look better black then orange so thats what i did.
If you go back to when it just got painted and i had it all back together there was a bed cover on it. I have had the bed cover way before the bbc. |
04-24-2010, 03:08 PM | #150 |
Re: 70 gmc
I see! How much longer to rubber burn?
