Old 01-13-2011, 07:23 PM   #126
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: Project: "Full Metal Yellow Jacket" Build Thread
Originally Posted by 1Bad62Pro/Street View Post
Here are the Plans:
http://www.jegs.com/
Jegster Ladder Bar Crossmembers
Jegster Ladder Bar Crossmembers #550-40010
Jegster ladder bar crossmembers are stronger per pound, because the included
braces allow the main crossmember to be made of lighter material and allow increasing
the weld area to the frame rails. Made from 1.5'' x .134'' wall mild steel tubing.
56'' Extra Wide
Kit includes:
(1) 56'' crossmember with 2-1/2'' center drop.
(4) .188'' thick, 3-hole brackets with 3/4'' holes.
(2) bracket webs.
(2) 1-1/4'' x 18'' steel tube braces.
(2) bolts and lock nuts.
Competition Engineering Ladder Bar
Competition Engineering #247-2006
Increase traction by eliminating wheelhop
Ladder Bar Features
33" long
Best for 100"-115" wheelbases
Made of 1" O.D./.156" wall tubing
3/4" forged rodends threaded directly into tubing
Front end braces prevent rodends from bending & breaking
Double 360° housing brackets withstand brutal loads
Competition Engineering Floating Axle Housing Mount
Competition Engineering #247-2030
The use of ladder bars with a leaf spring rear suspension requires that the rear
end housing not be rigidly attached to the leaf spring. This is because the
ladder bars and the front half of the leaf spring establish two different and competing
centers of rotation for the axle housing. A floating housing mount eliminates the binding and
allows the housing to rotate properly.
Changed my mind again:
Getting this now!
Competition Engineering 2051K7 -
Competition Engineering Rear Coil-Over Shock Kits
Competition Engineering introduces coil-over rear suspensions.
With or without springs, these kits include:
3-way adjustable shocks
Upper mounts
Adjustable lower mounts (with 6" of ride height adjustment)
Vehicle weight is critical to suspension performance so choosing
the correct spring rate based on rear end weight maximizes the suspension's ability
to transfer weight and improve traction.
http://www.jegs.com/i/Competition+En...051K7/10002/-1
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-13-2011, 07:24 PM   #127
1Bad62Pro/Street
Gonna order Heidt's Chrome Steel Coil-Over Shocks and Springs for my truck soon. Fits stock Mustang II lower arms and Heidt's Tubular Coil-Over Lower Arms, provides the ultimate in hi-tech appearance for the Mustang II IFS. Provides adjustable ride height as well as spring rates. Show chrome plated (steel) shocks, with aluminum ride height adjusters, spherical lower ends and show chrome springs included.
http://www.rjays.com/Front_End/MII-frt-end-01.htm
http://www.heidts.com/
Got to get these too!
Taxes!
Old 02-02-2011, 07:25 PM   #128
1Bad62Pro/Street
Thumbs up Re: Project: "Full Metal Yellow Jacket" Build Thread
Current Rear Setup:
Old 02-02-2011, 07:32 PM   #129
1Bad62Pro/Street
Current Rear Setup:
Still need to get the Competition Engineering Rear Coil-Over Shock Supension Kit
Old 02-02-2011, 07:49 PM   #130
1Bad62Pro/Street
New Fuel Rail and Fuel Pressure Gauge..
Yes I am getting new valve covers.. ha ha
Old 02-02-2011, 08:24 PM   #131
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Looks good
I need the same setup for my truck. Hope to sell some of my junk this weekend at the local swap meet and these are first on my list.
The truck is coming along nicely. Looks fun to drive
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 02-02-2011, 08:40 PM   #132
1Bad62Pro/Street
Thanks Bud!
Yea hope to be cruising pretty soon.
Have the urge to chirp some hides. . .
Old 02-12-2011, 09:02 PM   #133
1Bad62Pro/Street
Just completed my order from JEGS - Shipping was free.
Got one heck of a deal on the Valve Cover Kit!!!!!!
(2) 555-50145 JEGS Performance Products 50145 - JEGS Valve Cover T-Bar Wing Nuts - Chrome Steel
(1) 350-4207K Edelbrock 4207K - JEGS/Edelbrock/ARP Elite Series Dress-up Kit - SB-Chevy Elite Series Dress-Up Kit
(1) 247-2051K7 Competition Engineering 2051K7 - Competition Engineering Rear Coil Over Shock Kit - 250lb springs included
Next on the shopping list is:
HEIDTS SUPERIDE FRONT COIL-OVER SHOCKS FOR MUSTANG II SUSPENSION
http://www.heidts.com/heidts_superid...er_shocks.html
Heidts MP-040 - HEIDTS Coil-Over Shocks
Heidts MP-042 - 500# Chrome Coil Springs, Pair
Old 02-14-2011, 06:06 PM   #134
1Bad62Pro/Street
Starting on the bed now.
It's been sitting out in the weather to long.
Old 02-14-2011, 06:09 PM   #135
1Bad62Pro/Street
Old 02-14-2011, 06:17 PM   #136
1Bad62Pro/Street
More
Old 02-14-2011, 06:20 PM   #137
1Bad62Pro/Street
Few more.
Going to re-do the bed again.
It looks terrible!
Old 02-14-2011, 08:03 PM   #138
1Bad62Pro/Street
I will work on my bed on my spare time.
Waiting on my goodies to come tomorrow so I can start puttin stuff together.
I'll have my truck on the road soon.
Old 02-14-2011, 08:09 PM   #139
1Bad62Pro/Street
More pics.
Old 02-14-2011, 08:15 PM   #140
1Bad62Pro/Street
The rear...
Getting ready for the Rear Coil Over Shock Kit.
Old 02-14-2011, 08:36 PM   #141
1Bad62Pro/Street
Note to self....Stuff I need to get.:
Need Fuel Pump & Regulator Install Kit.
JEGS Performance Products 100804 - JEGS Fuel Pump & Regulator Install Kit
JEGS Performance Products #555-100804
130 GPH Fuel Pump (555-15915)
Fuel Pressure Regulator (555-15912)
Filter, Fittings, Line, Line Clamps & Pressure Gauge
http://www.jegs.com/i/JEGS+Performan...00804/10002/-1
Optima Battery Dry Cell Battery:
Need a Heavy Duty Battery Box - (In Cab Storage) (Behind the Seat) (Vented)
Finned aluminum battery box:
Old 02-17-2011, 05:37 PM   #142
1Bad62Pro/Street
Old 02-17-2011, 05:42 PM   #143
1Bad62Pro/Street
Old 02-17-2011, 05:47 PM   #144
1Bad62Pro/Street
Old 02-17-2011, 05:50 PM   #145
1Bad62Pro/Street
Old 02-17-2011, 05:52 PM   #146
1Bad62Pro/Street
Old 02-17-2011, 05:57 PM   #147
1Bad62Pro/Street
Old 02-17-2011, 05:59 PM   #148
1Bad62Pro/Street
Old 02-17-2011, 06:02 PM   #149
1Bad62Pro/Street
Old 02-17-2011, 06:04 PM   #150
1Bad62Pro/Street
