Old 10-28-2011, 09:33 PM   #126
renegade6
Re: New 1957 Project
I'm finally back and have had some time to put some work into the truck. In the last few weeks, I fixed the transmission leak, transfer case adapter leak as well as installed the sound system (-) the front speakers.
Very happy with how it sounds, even with the front speakers just sitting in. Now, for those of you contemplating something like this, I would highly recommend putting the stereo in before the interior. Not my preferred method but, I had a deployment.
On to the pictures...
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 10-28-2011, 09:35 PM   #127
renegade6
More pictures. Also, there are no crimp on connectors anywhere. All connections are soldered and covered all wires with wire cover where possible.
Brandon
Old 10-29-2011, 02:30 AM   #128
Kim57
Kim57's Avatar
looks like a real clean install.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-19-2011, 08:24 PM   #129
renegade6
Finally have the pictures of the front speakers. I'm not really thrilled about how the vinyl came out on them but, may do it again at another time or build some different pods.
Also had time to put in my steering wheel.
Next step is do put the new alternator and PS brackets on and I'm getting close to being done.
Brandon
Old 11-19-2011, 09:18 PM   #130
Kim57
Kim57's Avatar
Looking good. I like the wheel.
Kim
My build thread
Old 11-19-2011, 09:37 PM   #131
Rude Dude
Rude Dude's Avatar
If you are not using the vents why didn't you sink them in flush with perforated holes in vinly
Rude Dude is offline   Reply With Quote
Old 11-19-2011, 09:49 PM   #132
Rude Dude
Rude Dude's Avatar
Oh by the way your truck is Killer and thank you for service to our country!!
Old 11-19-2011, 09:52 PM   #133
renegade6
I don't think there is enough room in there for the depth of the speakers and I have my AC vents in the same place that you have your speakers.
If I would do this again, I would have built a panel below the dash to put the AC vents on.
Thanks, it's a pleasure to serve.
Brandon
Old 11-19-2011, 10:01 PM   #134
Rude Dude
Rude Dude's Avatar
The pic I posted was one that I saved as an example not mine. Didn't notice your AC Vents. I am going to flush mount my speakers and going to cut the metal and build a box out of steel with speaker composite inside to deflect sound out. It will be a pain but hey whats a welder for anyway. Good job none the less.
Rudy (MSGT. Ret.)
Old 11-19-2011, 10:46 PM   #135
renegade6
If you don't put your e-brake pedal where you put mine, you will have more room to build some pods without having to cut into the body any.
Brandon
Old 11-19-2011, 11:09 PM   #136
Rude Dude
Rude Dude's Avatar
Look at my build I forgot which page I modified my hand brake.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442
Old 11-19-2011, 11:17 PM   #137
Rude Dude
Rude Dude's Avatar
The handle is on page two, I am still going to build speaker enclosure in vent area only cause I hate this sticking out, just my prefence. That is why I cut the brake handle down and made brakets to make it more flush instead of stock sticking down and out. I also cut my seat brackets an inch pie cut
cause I hate to see seats out the back window plus nicer angle gives a comfortable seating for cruizin!
Old 11-30-2011, 10:11 PM   #138
renegade6
When I did the camshaft a couple of years ago, I noticed that the original crank sprocket had shifted and the original key was impossible to get out. So, thinking I would get after it later, today was the day. Yes, would have been much easier to do with the body off of the frame but, had to get everything back together before I deployed.
So, today everything is going smooth, pulled off all of the engine accessories and because the oil pan had a dent, decided to replace it as well.
Took a look inside the oil pan and what do I find...A piece of a piston skirt from the #7 piston. Really didn't want to pull the engine but, now I have no choice
Brandon
Old 12-03-2011, 06:34 PM   #139
renegade6
Big sad face for me.
Pulled the engine and tore it down. Broken piston skirt on the #8 cylinder and it scored the walls. From the looks of it, the skirt struck the crank counterweight and it probably happened after the first start when it was rebuilt (prior to me owning it). When I pulled the plugs, the plug on that cylinder had some oil on it. Even worse news that it is already bored .60 over so, looks like I need to purchase a new engine with the money I saved up for my wheels and tires.
Looking at a Pace Performance 350 with 300 HP. Anyone had any experiences with these?
Brandon
Old 12-03-2011, 07:37 PM   #140
Kim57
Kim57's Avatar
That sucks.
Kim
My build thread
Old 12-11-2011, 07:24 PM   #141
renegade6
Yes, it did suck very much.
Ended up going with a standard 350 crate engine and I put my old cam in it, which only had about 500 miles. A lot cheaper than the 300hp option.
Received the engine on Wednesday and didn't have time to mess with it until this weekend. So far it is painted and in and two of the accessory brackets are in. Hopefully get it close to starting next weekend.
Brandon
Old 12-11-2011, 07:25 PM   #142
renegade6
Oh, in case you are wondering about the valve covers. Those are going away as soon as my new ones come in. Didn't feel like wasting the paint on them.
Brandon
Old 12-21-2011, 08:59 PM   #143
renegade6
So close to finally starting it.
After installing the Sanderson manifolds, figured out that the original dipstick won't work and most folks have to put in a Lokar flexible dipstick. So, another order from Jegs and it's in. Also found the right size belts, hooked up a few other odds and ends and when I finish my exhaust tomorrow, it will be ready to start.
Brandon
Old 12-21-2011, 10:56 PM   #144
Kim57
Kim57's Avatar
Very cool. Everything looks nice and clean.
Kim
My build thread
Old 12-23-2011, 06:39 PM   #145
renegade6
Kim--Thanks, wish I had half of the skills that you do.
Finally finished with the engine (almost). Put on my new valve covers, breathers, wire holders and air cleaner. Now, will need to get a better set of plug wires but, that will have to wait a bit until more funds are available.
Now, on to the pictures. BTW, the exhaust is my temporary fix until I get a system put on it. Amazing what you can get from a scrap pile...
Brandon
Old 12-23-2011, 09:20 PM   #146
OrrieG
OrrieG's Avatar
Nice covers and air cleaner, love the retro styling.
OrrieG is offline   Reply With Quote
Old 12-23-2011, 11:29 PM   #147
Kim57
Kim57's Avatar
Looks great with the new engine covers.
Kim
My build thread
Old 03-03-2012, 11:18 PM   #148
renegade6
Finally got my tax money back so that I could buy my wheels and tires. Now, on to the pictures.
Brandon
Old 03-04-2012, 01:13 AM   #149
Kim57
Kim57's Avatar
Sharp looking truck.
Kim
My build thread
Old 03-04-2012, 11:04 AM   #150
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Well done!
ChuckDriver is offline   Reply With Quote
