Old 06-07-2010, 11:49 AM   #126
62ramptruck
Re: 8 lug wheels - what's on YOUR truck?
I have a set of factory H2 Hummer wheels sitting in a corner in the shop. I need to pull these out and check the pattern. Someone might be able to use these on one of their trucks.
1968 C10 SWB "Project Shop Truck"
1964 Impala 2DR Hydraulics
1933 Ford 2DR Sedan
1965 AC Cobra (Long Term Project)
1998 Viper GTS-R
1962 Chevy RampTruck (SOLD)
62ramptruck is offline   Reply With Quote
Old 06-08-2010, 01:11 AM   #127
05crewcab
05crewcab's Avatar
Those H2's will fit any 8-lug chevy from 67ish to 2010...i have them on my 2005, and am thinking about putting them on my 71 (stock 2500HD's on there now) when the rubber is low enough for "dry" traction only.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 06-09-2010, 03:27 AM   #128
Mad Viking
Mad Viking's Avatar
Does anyone make a 17" or 18" steel 8 lug wheel that is, say, about 8" wide? I want to put a larger wheel on my 71 C20 and combine that with low profile tires and a 3/5 drop. I am painting the truck either the original dark green with a satin finish or black with the same finish. I want to paint the wheels the same color and then put chrome beauty rings and baby moons on. Just curious at this point.
Mad Viking is offline   Reply With Quote
Old 06-09-2010, 07:09 AM   #129
prairewolf
Originally Posted by Rupdog View Post
i'm having a hard time finding some vintage style 8 lugs for my C-20 and was wondering what you guys were using. I currently have some vintage US Mags slots, but they're 16.5s and need new tires. Any suggestions? Maybe swap to 5 lug? Please post some pics of your 3/4 ton ride. Thanks!!!!!
these are 94 or so Sub rims, 16 inch, ... they would look more vintage if painted white and the trims rings were removed.
eat,work,spend,sleep,repeat.
prairewolf is offline   Reply With Quote
Old 06-20-2010, 02:55 PM   #130
Mayo
Cool Truck
Mayo's Avatar
From my understanding, if I wanted to run a set of center caps from a 2000s chevy, I would need to use the external thread lug nuts. Do the lugnuts from the new chevys bolt right on to the old trucks, or do I need to get some special aftermarket lugnuts?
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 06-20-2010, 08:37 PM   #131
eagleuh1
eagleuh1's Avatar
After market lugnuts. They have to have SAE standard threads to fit the old studs, and the metric thread on outside for the plastic locknuts that hold center cap on. Newer Chevies have metric studs. Also, are you planning to use these caps on older stock rims or the rims that go with the center caps. I think the lugnuts have different seat angles than old wheels have. Lugnutking on e-bay is where I got my lugs. Good luck.
eagleuh1 is offline   Reply With Quote
Old 06-20-2010, 11:52 PM   #132
steves1967
steves1967's Avatar
I just bolted up a set of the 2500HD wheels, I used the lugnutking lugs. I found out that the rear caps will not fit over the Dana 60, the axel hub sticks out too far. So to use the caps I have to add spacers behing the wheel (about an 1" worth), but then my studs wont be long enough, so I'll have to get long studs from ARP, and 1" thick spacers...the spacers will help to push the wheel out to be even with the body, but I just think I'll look for a different wheel.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'19 Chevy CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 06-21-2010, 12:06 PM   #133
Mayo
Cool Truck
Mayo's Avatar
I was thinking about trying to put a set on some Dodge rims from the 90s
Old 06-26-2010, 12:16 AM   #134
OleBlue79
OleBlue79's Avatar
Stllookin - Where did you score those wheels? I love that look! The little hubcaps just finish them off perfectly!
OleBlue79 is offline   Reply With Quote
Old 09-30-2010, 04:11 AM   #135
kikkegek
kikkegek's Avatar
i got these on mine (see my sig):
dont know what rims these are. But the tires are General Grabbers TA2 265/75/R16:
I dont like the way the centers look in the rear. I am looking for a solution, too make them look like the front centers of the rims (K20 got them locking mechanism in there).
kikkegek is offline   Reply With Quote
Old 10-05-2010, 12:00 AM   #136
Heavy Evy
born to lose
Heavy Evy's Avatar
I had a hard time deciding which rims to use on my pile but i went with these because I have never seen anybody else with them. I know the pic is bad and only shows the front but there 16's. 235-60 up front and 285-60 out back also how are you guys lowering your 3/4's without cutting springs or removing leafs?
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 10-06-2010, 05:03 PM   #137
Mayo
Cool Truck
Mayo's Avatar
Are those the Eagle Ion Alloy 171s?
Old 10-06-2010, 09:37 PM   #138
Heavy Evy
born to lose
Heavy Evy's Avatar
they are ions and i love em! i got a killer deal on them from jegs 2 years ago
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 10-06-2010, 10:06 PM   #139
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
Name:  8 lug web.jpg
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 10-06-2010, 10:52 PM   #140
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I'm running Akuza
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-07-2010, 04:15 PM   #141
eyebuzz
Licensed driver
eyebuzz's Avatar
16.5" original rims with 8.75x16.5 tires. I wouldn't mind a slightly wider tire - but the options were limited to keep the height the same. Firestone Transforce (Goodyear makes the Workhorse...and then a small collection of off brand tires).
eyebuzz is offline   Reply With Quote
Old 10-07-2010, 11:08 PM   #142
Mayo
Cool Truck
Mayo's Avatar
I was just looking at a set the other day for $450. I think I may get some come spring time. You don't happen to have any other and/or clearer pics of those rims on your truck do you?
Old 10-07-2010, 11:38 PM   #143
1stimer
These were on my new truck.
1stimer is offline   Reply With Quote
Old 10-08-2010, 08:43 AM   #144
674x4ton
What year is the hubcap? Very nice.
674x4ton is offline   Reply With Quote
Old 10-08-2010, 02:29 PM   #145
vic1420
do you want to sell your slots ,e-mail me with pics zuki1420@roadrunner.com
vic1420 is offline   Reply With Quote
Old 10-10-2010, 12:45 PM   #146
Heavy Evy
born to lose
Heavy Evy's Avatar
Mr Mayo. I don't have any recent pics but here is a link to the thread I started when I first put them on there is a few pics of them in there so hopefully it helps you out! http://67-72chevytrucks.com/vboard/s...d.php?t=315993
Evan
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 10-10-2010, 05:51 PM   #147
Mayo
Cool Truck
Mayo's Avatar
Evan
Thanks for the link
Old 10-10-2010, 09:59 PM   #148
674x4ton
How wide 8.5?
Old 10-12-2010, 12:41 AM   #149
spyder4560
spyder4560's Avatar
Not really good pics,but I found a set of Outlaw I's for a steal.I like them and that's what matters,right?
Sorry,Boss.There's only two people I trust.One of them is me,and the other one is not you.
spyder4560 is offline   Reply With Quote
Old 10-12-2010, 12:53 AM   #150
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I Like those wheels, wider would be better though.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
