Old 03-29-2010, 12:01 AM   #126
jojo
printing is my trade
jojo's Avatar
Re: Jojo's '70 Stepper
Got the drivers side inner bolted and welded in.
Check out how much dirt I pulled from between the drivers side rockers:
And yes I'll be replacing the cab corners soon
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 03-29-2010, 12:03 AM   #127
highperf4x4
Yikes!!
Looks like alot of fun though!
highperf4x4 is offline   Reply With Quote
Old 03-29-2010, 12:14 AM   #128
jojo
jojo's Avatar
Originally Posted by highperf4x4 View Post
Yikes!!
Ya man. It keeps me out of trouble.
One thing I've realized is that the thing that takes the longest in all this is removing all the unwanted rusty parts. All the other things seam to go by quickly for me.
Anyways heres a list of parts currently on order and will arrive next week (God willing):
drivers and passenger side cab corners
drivers and passenger side kick panels
front and rear drivers side door pillars
passenger side hinges
gas tank relocation kit
My current plans for the cab after installing all that stuff:
finish the doors (install the window felts and all the hardware)
put POR15 on the floor and firewall in the cab
put bedliner or equal product over the POR15
I can't really think any further beyond that but we'll see what happens!
Old 03-29-2010, 11:42 AM   #129
mcbassin
Still Learning
mcbassin's Avatar
The rust repair is looking really good! Glad to see all the progress! Keep at it!
mcbassin is offline   Reply With Quote
Old 03-29-2010, 12:26 PM   #130
highperf4x4
So the LineX or whatever would be your floor covering instead of carpet or a mat then?
Old 03-29-2010, 11:38 PM   #131
jojo
jojo's Avatar
No, I just wanna have as many layers to reduce noise (and future rust) in there as much as possible. Carpet would go on top of all that.
Do ya'll think that would help?
Old 03-30-2010, 12:09 AM   #132
highperf4x4
It might help with noise some but I would imagine it would make a big difference in heat too if you run it up under that dash as well.
Old 03-30-2010, 12:24 AM   #133
jojo
jojo's Avatar
I never thought of heat. Thats just another benefit! I get all kinds of heat in there.
Old 03-30-2010, 12:40 AM   #134
jojo
jojo's Avatar
I got my LMC gas tank kit in today.
So I figured I'd take a break from the cutting and grinding and install the new tank...
And wouldn't you know it, installing the tank required more cutting and grinding. Everything is preped, I just need the bolts since the kit came with some stupid j-bolt things.
Hopefully tomorrow I'll finish the install and post some pics.
Old 03-30-2010, 07:22 AM   #135
my67chevytruck
Under Construction
my67chevytruck's Avatar
great progress JoJo!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-30-2010, 10:15 AM   #136
highperf4x4
Cool, I'll be looking for the pics then.
Old 03-31-2010, 12:50 AM   #137
jojo
jojo's Avatar
Okay I didn't finish bolting up the tank yet because the bolts I purchased are about 1 inch too short. But I have some pics and thoughts about this already.
As you can see the tank is the LMC blazer conversion.
I had to cut off some of the cross sill on the old step bed. Doing so allows me to flush that tank up against the frame rails.
Then I decided to move the cross sill back some. I did that to allow me to center the tank in between the cross members and use 4 holes that already existed there in the frame rails. This also gives a little more clearance for the filler neck. As you can see in the 4th pic, positioning the tank in the center of the cross members puts the filler neck in a most unfortunate place. 5th pic shows fitment and easier access to the filler neck after moving the cross sill back.
Only 3 complaints so far:
1. Slight damage during shipping, I simply bent that thing back.
2. The tank has these under sized mounting holes (probably for the j-hooks but they only provided 2 hooks and no other hardware) so I drilled out those holes which allowed 3/8 bolts with washers to fit properly.
3. There is no turnkey "kit" for the filler/hose/gas cap available (that I know of). There's all kinds of custom set-ups but we're all sort of on our own for that.
Old 03-31-2010, 12:52 AM   #138
jojo
jojo's Avatar
One last pic for now to show another view of the tank fully raised into place and cross sill moved back (which also needs to be bolted in):
Old 03-31-2010, 12:58 AM   #139
jojo
jojo's Avatar
By the way, I've been considering what to do with the bed and this is what I've come up with:
Installing a stock style metal bed, but I don't recall seeing one for these steppers. So I'll have to probably snag a bed floor from a later model and make it fit.
This ain't gonna be a show truck (just a really cool daily driver) so I'm not concerned with having a beautiful wood floor.
Old 03-31-2010, 09:27 AM   #140
highperf4x4
Cool, the tank looks great in there but it seems like it hangs down awful far. How many gallons is it?
You can't just add something to the top of your cross sills to elevate the wood bed a little bit?
Old 03-31-2010, 10:34 AM   #141
jojo
jojo's Avatar
Its 21 gallons. and it does hang a little low but I don't have a bumper on there so its sort of an optical illusion.
Old 04-01-2010, 10:43 PM   #142
jojo
jojo's Avatar
Here's some pics of the tank fully bolted up. It probably raised up a few inches from earlier pics. It's only about an inch or two below the exaust.
Old 04-01-2010, 10:44 PM   #143
jojo
jojo's Avatar
and in case ya'll are wondering how I stay so organized...
Old 04-01-2010, 11:20 PM   #144
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
that looks pretty good. how about a low pic like that from the rear?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-02-2010, 12:52 AM   #145
highperf4x4
1" below the exhaust huh? That should be good enough!
I wish I was as organized as you.
Old 04-02-2010, 04:06 AM   #146
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Looks good! I've got that same tank setup in my truck!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 04-04-2010, 12:50 AM   #147
jojo
jojo's Avatar
Thanks! I'll put up that pic from the rear tomorrow
LOL you should see my office at work!
Thanks Mathew, I sometimes check out your project thread for inspiration. You got a fine looking stepside mister!
Old 04-07-2010, 09:50 AM   #148
SATownChevy
SATownChevy's Avatar
just checking in on another san anto build. read the whole thread, makes it look like im working at work.
working on mine right now. but unlike yours, i cant drive mine. it sucks big time
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 04-07-2010, 09:56 AM   #149
jojo
jojo's Avatar
I hear you bud. I've tried to follow what I call the "K.I.D." rule:
"Keeping it drivable"
I never have more than a weekend's worth of work to get it on the road.
Old 04-07-2010, 09:58 AM   #150
jojo
jojo's Avatar
I should say, I'm surprised that I don't see more satown folk up on this forum.
I see our trucks are all over this city.
