08-31-2014, 06:40 PM | #126 |
Re: Good 70 SWB
Been doing a lot of work on the engine compartment. Wirelooms are in and I have the Willwood Master cylinder mocked up and lines connected. I used a 4 core HD radiator from Champion. Still need to come up with a cover for it. Also installed Sanderson CC11 headers. The drivers side had plenty of room from the frame rail. However on the passenger I had to notch the frame rail about 3/8 of an inch.
08-31-2014, 06:49 PM | #127 |
Re: Good 70 SWB
I installed 72 VAN tilt steering column, I am using original dash cluster. I did cut the dash to install a double din radio. And I have my AC mocked up under the dash. Been working on wiring and getting vents installed. Will being working on fabricating a frame for my bucket seats so I can use the original mounting holes. Also using Original AC controller.
08-31-2014, 09:02 PM | #128 |
Re: Good 70 SWB
Brake and trans line look good. Sorry we spent more time working on my seat frame and not getting to yours. Something to do another day.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
08-31-2014, 10:59 PM | #129 |
Re: Good 70 SWB
Jeebus...great color...fantastic work...
2007 VW GTI - SOLD, 2013 Ram 1500 Crew Cab Hemi 4x4 - TRADED (POS), 2006 Silverado 2500 Dirtymax, 2010 Kawasaki ZX-10R (wrecked), 2006 SV650, 2015 ZX-6R 1968 C10 CST LWB "..... Long beds are like the slightly chubbier sisters to the hot chick, still cute with a lot more to like. hahahaha!" - OrtegaMotor |
09-02-2014, 09:05 AM | #130 |
Project collector
Re: Good 70 SWB
Looking great bro. Keep it up you will get there!
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
01-12-2015, 01:11 PM | #131 |
Re: Good 70 SWB
So I know it's been awhile since last update but I have made progress and have pictures that I know everyone likes to see.. I had to scrap the idea of using the Vintage AIR surefit kit that I had and the Original AC control head. Since I was going with custom bulk head the Surefit Kit was just too close to my bulk head under the dash I could not get the hoses to route correctly. So I purchased a Vintage Air GenII compact unit and mounted it up under the Dash. This provided the clearance I needed to to route the AC and Heater Hoses. Also had to redo Dash and put in new Slimline electronic control unit.
01-12-2015, 01:25 PM | #132 |
Re: Good 70 SWB
Here are some pictures of the Dash modification for new AC Controller... Sorry for the bad quality picts.. Got new phone and looks like I need to adjust settings.
01-12-2015, 01:29 PM | #133 |
Re: Good 70 SWB
Was able to get Rear window installed, Had a local company come out and install the Windshield. I also rebuilt vent Windows and got them installed and doors built.
01-12-2015, 01:42 PM | #134 |
Re: Good 70 SWB
I have began mocking up the bed getting wood bed installed and all holes drilled. Then I will take back apart paint the bed and finish the wood and then reassemble. The 4 boards you see in the pick that are not stained Black I ended up having to have re-make as I lost the originals over the 3 year span I waited to get to the point of installing.... Thanks to SilverBear on this forum for helping in making those.
01-12-2015, 02:05 PM | #135 |
Roto Reuter thats the name...
Re: Good 70 SWB
Just read through your build thread. I'm just getting ready to get started on mine. I am planning on many of the same ideas for my 71 swb. Good work so far and keep it up. Subscribed.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-27-2015, 01:51 PM | #136 |
Re: Good 70 SWB
Finally decided how I am going to approach my bed fill. I got a billet door from Speedway motors and installed it. I probably should have went with larger sized one as it is bit tight to get my hand in to open the fuel tank. But I was worried the larger size I would not have enough board for it. It mounts with threaded studs so not screws are visible.
All in all I think it is going to look good and work well for access to the filler. Sorry for blurry picts. |
01-27-2015, 03:26 PM | #137 |
Still Learning
Re: Good 70 SWB
Very nice progress. I really like the wood floor. Looks great.
01-27-2015, 03:32 PM | #138 |
Re: Good 70 SWB
Looks good! How thick is the wood?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-27-2015, 03:43 PM | #139 |
Re: Good 70 SWB
Thanks for the comment... It is 3/4" you basic 1x material.
01-27-2015, 03:44 PM | #140 |
Re: Good 70 SWB
Appreciate it Mike
01-27-2015, 03:59 PM | #141 |
Re: Good 70 SWB
Sweet lookin ride. I really like sod of your ideas. May use them on my Cheyenne. When I rebuild it.
01-27-2015, 10:09 PM | #142 |
Re: Good 70 SWB
All that work on the grill to get it looking good and all you post is a side angle pic and no mention of it.
Just harrasing you my friend. Looking forward to reassembling that bed after the paint work is done
01-30-2015, 11:27 AM | #143 |
Re: Good 70 SWB
Hey Sliverbear I am working on the Bed and hope to have it done soon...
02-12-2015, 05:35 PM | #144 |
Re: Good 70 SWB
Making good progress
03-04-2015, 08:25 AM | #145 |
Re: Good 70 SWB
Finnished painting the bed. Trying to stay on schedule to finish in April. I will begin assembly this weekend
03-04-2015, 08:31 AM | #146 |
Re: Good 70 SWB
Completed doors. Got door panels done and on. Painted them Black and put Matt clear over it. Painted arm rests with vinyl paint. Installed billet handels.
03-04-2015, 08:42 AM | #147 |
Re: Good 70 SWB
installed radio and glove box door to complete dash. Put down some hush Matt down for sound deadner. Installed precut carpet I got from NPD. Fit nice. Mounted my custom frame thwe made for the bucket seats that are going in. Should have those back next week from upolstry shop.
03-04-2015, 06:32 PM | #148 |
6>8 Plugless........
Re: Good 70 SWB
It is looking awesome! Did you use single stage or base/clear for your paint? I'm jealous as it's way too cold to primer and paint here.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-04-2015, 08:20 PM | #149 |
Re: Good 70 SWB
Look'n Good Billy Ray!!!
03-05-2015, 10:15 AM | #150 |
Re: Good 70 SWB
Thanks for the comments. I am using Base/Clear.
