11-09-2009, 10:15 PM | #126 |
Re: Project: Agent Orange
It's showing the plate that gets welded to the hood itself, that the hinge then bolts too.
11-09-2009, 10:36 PM | #127 |
Can't wait to retire!!
Very cool!
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
11-10-2009, 02:55 AM | #128 |
Very cool! But...it looks like it would be very close to the engine harness that lays in that area on the drivers side when closed. I'm sure Nate saw that though, probably not an issue
Nice way to get rid of those ugly factory hinges
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-10-2009, 03:35 AM | #129 |
USMC
Those are very high quality welds on there also. The entire piece looks well made, impressive.
Semper Fi |
11-10-2009, 12:49 PM | #130 |
How much are those?
11-10-2009, 12:55 PM | #131 |
11-11-2009, 01:38 PM | #132 |
I miss this truck.
See, you tried to start a new thread to run and hide from me, knowing I only log on when I see an update from you or Jim, but I caught up to you.
Progress looks good. Can't wait to see more of it.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
11-15-2009, 06:38 PM | #133 | |
Yeah, we were taking bets about when you'd find us again... Engine/tranny mock up cause my compressor busted, so further body work was out. Seems to sit pretty far back...dunno why exactly. The other thing is that the 700r is supposed to be 3"s longer, yet it lands right on the stock cross member. Maybe I have the DIY cross member in the wrong frame holes, doubt it but it's for sure getting moved forward eitherway. |
11-15-2009, 08:23 PM | #135 |
Looks good Kurt and I really like those valve covers!
11-15-2009, 08:59 PM | #136 | |
Surprisingly close...any ideas why? I went with the DIY cross member in the first place to have the ability to move the engine forward "if needed" to accomodate the 700r but never expected it to sit where it is now in being it's in the stock frame location. Last edited by vtblazer; 11-15-2009 at 09:00 PM. |
11-15-2009, 10:19 PM | #137 |
I'm thinking of using that same crossmember in my swap. Seems like a decent piece. Whats your opinion?
Is there a coupler/adapter that would go on the transmission that bolts to the crossmember like the 205? |
11-16-2009, 12:51 AM | #138 |
Looking at your picture and the DIY website would flipping the crossmember 180 degrees move the engine forward a bit without going to the forward holes? Can't really tell if the crossmember favors one side or if it is centered in its mounting blocks?
11-16-2009, 12:55 AM | #139 |
Yeah - Thealien is right I believe -
You need to flip your crossmember 180
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
11-16-2009, 07:43 AM | #140 | |||
Don't believe it's possable to flip it around, it has a taper to it that aligns with the frame rails. I do like the cross member, really glad it cleared my oil pan too. Last edited by vtblazer; 11-16-2009 at 07:47 AM. |
11-16-2009, 09:52 AM | #141 |
Could be the tall valve covers, with factory valve covers, I have about 1 1/2" - 2" of clearance. If and or when you move the engine forward you will have to cut and flange(Jon's idea) the crossmember, since the frame tapers in at the front. If you flange it now, you will be able to drop the pan if needed in the future
Is the trans. at the right height? Looks good
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-16-2009 at 10:00 AM. |
11-16-2009, 10:05 AM | #142 | |
Don't believe I'll need to go to that extent of modification's to move it forward. There's about a 1/2" till the inner mounts tough the frame wall, being I need to drill new holes in the frame anyway, that gives me a couple option's to work with. #1) simply slide everything forward until the frame taper mandates I stop. #2) flip the cross member around (which will net me about 1.5"s) and drill the new holes accordingly, would basically be stagered in the frame rails instead of inline. |
11-16-2009, 12:58 PM | #143 |
241 T-case adaptor clears up the tranny mount issue, looks like it needs to land just about the 3"s further back.
Going from that alone, it seems the engine is in the correct or near to the correct location. Anybody have a measurement from the rad support to the block? Mine is currently sitting approx. 19/20 inches back. Keeping in mind that it's not bolted down. |
11-16-2009, 01:05 PM | #144 |
You'll want to find one of these adapters. 700r4 to 208/241 tall adapter. Cleaner and it puts it right on the factory K5 crossmember.
11-16-2009, 07:20 PM | #145 |
Its lookin' like a Blazer!
[QUOTE=vtblazer;3621818]Surprisingly close...any ideas why?
QUOTE] I don't know. If ya remember I had the same problem. I had the Edelbrock Elite tall valve covers on mine. My tub was a 1/8th" from bolting up because of the valve covers hitting the firewall. |
11-16-2009, 09:01 PM | #146 |
I'm a poor spectator
The engines sit back pretty far in stock 4x4's, it looks pretty correct to me. My HEI sat 1/8 inch from the firewall and my taller than stock Edelbrock valve covers sat pretty close as well to the firewall but as long as you can get the valve covers off without having to move the motor around I would call it good, better weight distribution anyways.
Btw, everything looks great. I'm envious.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
11-16-2009, 10:41 PM | #147 |
Put my new 383 in a few months ago. Stock valve covers were close to the firewall, tall valve covers for the roller rockers have the same clearance yours do. Was still able to get them on and off for the valve adjustments. Didn't like the clearance either, but couldn't bring my self to hitting the stock firewall either.
1972 Blazer CST 4x4 |
11-17-2009, 12:28 AM | #148 |
Blazer Fanatic
Motor looks killer, how well would you say the lizard skin holds up. i know you haven't driven with it yet but has any of it started to Flake or peel. i was thinking of trying it out but figured id get your opinion first.
1970 Chevy blazer |
11-17-2009, 07:33 AM | #149 |
I'm getting this tall adaptor as AJ suggested, hopefully the seller ships asap.
Once I get the part, I'll install the 241, finish the drive train mock up and see where things really are. If the valve covers are to close, I'll move the combo forward, if not, it stays. After all the debate, I'm 99.9% sure the motor is in the correct location, it's just the tall covers making the difference, as has been mentioned. Last edited by vtblazer; 11-17-2009 at 07:35 AM. |
11-17-2009, 12:49 PM | #150 |
"something witty here"
Do ya think using the taller adapter will cause any motor angle problems? I have a 700r4-np208 and dont really like the low adapter either but worry that swapping to the tall adapter might screw with the drive-line angles....
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
