Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-18-2012, 11:07 AM   #126
fear_nothing
fear_nothing's Avatar
Re: Project Family Hauler
I'll be the late comer to this thread!
Great work on the 4th door, how many times did you measure before you cut? Also noticed its a suicide door, any reason for that? Are you planning on doing that on the passenger side as well?
Again great work, i R impressed!
fear_nothing is offline   Reply With Quote
Old 09-19-2012, 11:45 PM   #127
pickup67man
pickup67man's Avatar
Once the summer is cooling off and wet I will be working on it again. And yes the other rear door will be suicide also.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 09-30-2012, 08:56 PM   #128
pickup67man
Well I've got good news and bad news. The good news is I got some sparks flying off the suburban again.
Now the bad news. Something is wrong with the angle of the hinges. I've been running it through my head for a while. When the doors are closed the tops line up perfectly. As I open both doors it is obvious the rear suicide door starts to drop. After I open it 4 inches it is 1/4" lower than the front door. When both are open a foot and a half it is a full inch lower than the front door. I have moved the pivot point on the upper hinge 3/4" forward and I figured it would affect how the door swings. No change. Since I haven't cut the other side yet I might just make this one swing normal. Not much different on the jamb, just need to make the B pillar hold hinges instead of a latch and brace it. Then latch on the C pillar. Door is still open to work on.
Any ideas on how to make the hinges swing right. They are from a F@$& so the suburban may just be rejecting the donor parts.
Travis
Old 09-30-2012, 09:45 PM   #129
jbclassix
Junk Yartist
jbclassix's Avatar
Need pitchurs to give ower eskpert opineeun
Only things I can think is that the hinges are inverted, or the "C" pillar is "bowed out"
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 09-30-2012, 11:36 PM   #130
pickup67man
Ok you asked for it. Here are some pics
They line up when closed.
But when opened a little bit it becomes obvious.
And when opened more it gets worse.
When I look from the back the front door looks higher.
When I look from the front the back door is barely visible.
When I moved the top hinge forward I thought it would change the pivot point. It is the same. If you adjust a door 3/4" the front moves up and down alot. So when the door is open it would be like that adjustment, but when closed the gaps are still correct since it is spaced away from the jamb an equal amount.
Travis
Old 09-30-2012, 11:57 PM   #131
jbclassix
Junk Yartist
jbclassix's Avatar
I'm not 100 percent, but I don't think front door hinges are square with the front edge of the door... I remember I had to pie-cut a thin section to square the hinge mounts to make it work for the 4th door... so your rear door may track different than the front does. But I have no experience with Ford hinges, so take my advice for what it cost you! Are the pivots inside the pillar? I cant tell. All I can think is that they are just tracking in that path like something in... I have no clue, now I'm just rambling. All I can think is that the hinges are tweaked from straight up and down. Shut up, Jeremy, you are just trying to sound intelligent now.
-Jeremy
Rebuilding an NP205
Old 10-01-2012, 12:08 AM   #132
pickup67man
I never looked at the ford before I cut it up. The doors may swing different or the body lines may allow the hinges to tilt in more at the top. I do know the body is thicker at the top of the door on the ford. I had to trim the hinge box to fit in the body lines of the suburban. If I move the top hinge in it will be past the weather strip. And if I move the lower hinge out it will be past the sheet metal. I've been staring at it for a while.
Travis
Old 10-01-2012, 12:12 AM   #133
pickup67man
And yes they pivot inside the pillar. I chose them because they make the door swing away from the body. Unlike Chevy hinges where the leading edge swings behind the fender.
Travis
Old 10-01-2012, 12:29 AM   #134
jbclassix
Junk Yartist
jbclassix's Avatar
I looked back on page 3 and it looks like the door was doing that originally. I hope you can get it figured out!
-Jeremy
Rebuilding an NP205
Old 10-01-2012, 12:45 AM   #135
pickup67man
If you look at all posts since then you will see there hasn't been much progress. I distracted myself with a garage but haven't figured out the door.
Travis
Old 10-01-2012, 07:52 AM   #136
ThreeQtr
Here is a discussion on suicide doors on a suburban.
http://67-72chevytrucks.com/vboard/s...d.php?t=331633
In the pics Frizzle Fry's is definately down, though I only see one hinge in that particular picture. But even the custom red burb looks like it drops a little. More pics of it here. http://67-72chevytrucks.com/vboard/s...d.php?t=544965
Here is a crew cab project using a 68 suburban with a suicide doors starting on pg 9. http://67-72chevytrucks.com/vboard/s...d.php?t=495438
And pics of others for reference.
ThreeQtr is offline   Reply With Quote
Old 10-01-2012, 10:04 PM   #137
pickup67man
Well after talking and looking at more pics I have an idea. I opened the door and adjusted the top hinge until the doors were at the same level. 3/8" adjustment raised the door an inch on the latch side. Now the work. I got ahead of myself and welded a lot of the hinge box from the donor Ford. Now I have to cut those welds to move it. There is enough room on the body and door to tilt the angle of the hinges. I think the door will open correct then. I was just afraid this was the answer.
Travis
Old 10-01-2012, 10:26 PM   #138
jbclassix
Junk Yartist
jbclassix's Avatar
Originally Posted by ThreeQtr View Post
Here is a discussion on suicide doors on a suburban...
...And pics of others for reference.
What's up with the dually?! What's it look like with the doors closed?
That green one looks like the door drops too
As frustrating as it may be, I hope that solves your problem
-Jeremy
Rebuilding an NP205
Old 10-01-2012, 11:06 PM   #139
pickup67man
The only frustrating part is my welding too much too soon. Some welds may be hard to reach to cut out. But if I tilt the pivot angle of the hinge the door should open better. Maybe I'm just picky.
Travis
Old 10-02-2012, 05:05 AM   #140
ThreeQtr
Yes, the rear door of the green burb does look like it tilts down when open. Kind of like the rear barn doors on these open at an angle only the reverse direction (up).Keep up the good work and maybe you can make a kit for this.
More pics of the dually suburban here: http://67-72chevytrucks.com/vboard/s...98#post5605998
Old 10-07-2012, 10:30 PM   #141
pickup67man
Ok I bit the bullet and started to cut out all my welds. I had to cut the "hinge box" out of the suburban and tilt it. Then I had to cut the door apart to adjust that side an equal amount. I was able to move the top hinge in 1/2" and forward 3/8". This changes the pivot angle of the hinges.
Before Pic.
After Pic.
I think it looks better.
Here is what the "hinge box" looks like in the suburban.
This is the door side of the Ford hinges.
Lots of welds on the door. Looked a lot better before I cut the door apart.
The "hinge box" is actually part of the cab of the Ford. I have it welded to the floor below and next to the lower hinge, just above the lower hinge where the suburban floor meets the body and at the top right below the window. Then there is a 2" square tube that runs up to the header. No flex, which is good since the door hangs from it.
Looks better. I plan to have the doors open at shows so it will be easy to see if they are off.
Now to finish the jamb. Cut lots of holes for the hinges and now need to make it look good.
Travis
Old 10-09-2012, 12:40 AM   #142
Frizzle Fry
Frizzle Fry's Avatar
It's the lateral relationship between the upper/lower that affects that swing. Imagine a single line between the two. If it angles out your swing will not be level.
Frizzle Fry is offline   Reply With Quote
Old 10-09-2012, 01:13 AM   #143
pickup67man
In my head I could picture the angles but it took a while to start cutting. I had to admit I got ahead of myself. Haven't done much on it for almost 2 years. Starting to move forward.
Travis
Old 10-09-2012, 10:07 AM   #144
Frizzle Fry
It's quite a coincidence that the donor for your rear door opening was the same color as mine...
-and-
Old 10-09-2012, 09:58 PM   #145
pickup67man
-and-
That means I am on the right track. I noticed yours was a GMC according to the vin plate. Mine was a 1972 GMC cab I got for free. Going to use the A/C dash also. Now everyone will think you need a green GMC cab to make a 4th door.
Travis
Old 10-09-2012, 10:36 PM   #146
Frizzle Fry
good eye man! Mine was the same price. Just had to winch it out of the blackberries
Old 10-09-2012, 10:57 PM   #147
pickup67man
My second extra cab cost more. A special 10 pack of beer is all that it cost. It was a 12 pack but the guy offered me a couple while we loaded it and Bs'd. The green one the guy offered to help me unload it when I got home and I sold him an old engine analyzer so it was less the free.
Travis
Old 10-14-2012, 11:41 PM   #148
pickup67man
I did get something accomplished this weekend. Lots of grinding. With all the new and old welds I had lots of grinding to do. Not my favorite thing but it has to be done.
I know
Travis
Old 10-18-2012, 02:26 AM   #149
68 TT
Still plays with trucks
68 TT's Avatar
Glad you got the hinge tilt problem figured out. Now get back to work
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-18-2012, 08:00 PM   #150
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man oh man you are getting this unit done. I'm debating making a crew cab again, so keep up the work to motivate me. Haha
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
