#126 |
![]() Join Date: Nov 2009
Re: Structures 65 Chevy C10
Still patchin'
![]() ![]() ![]() ![]() I went a little different on the left side. I cut the kick panel out high because it was so hard to smooth the welds from cutting it low where the piece has the joggles stamped in. I also cut it out so that I could drill out the spot welds and slide it out from the outer pillar wall and inner rocker wall. When I removed the floor panel the rust was minimal. I wire brushed and vacuumed the best I could, then used my under coating gun to por-15 everything. ![]() I went with the universal pan on the left side. I wish I would have paid the extra money and got the OEM stamped panel. The panel was really off so I had to cut my patch in two to get it to fit. ![]() ![]() ![]() ![]()
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
#127 |
Nice work man!!
gotta love rust, NOT!! ![]()
#128 |
1 thing at a time is progress.
Nice progress!!
Alan
Philippians 2:14-16 |
#129 |
looking good man, I cant wait to get all my patching done. Im ready to do something differant.
#130 |
Still Learning
Looking good. I feel your pain with the aftermarket panels. they are usually way off. Keep hammering away.....no pun intended.
#131 |
guys thanks for the encouragement. I'll keep at it slowly but surely.
#132 |
Very nice work!
In Canada and starting to same thing on a 66 SWB Step. Now one question I have is since you're in this full swing. If you take a straight edge across the back of your cab under the window, is it flat or caved in a bit at about the same line as where the top of the rear bed panel would line up? Either my imagination or mine is bent in a bit unless they came that way from factory. Thanx...Mike |
#133 |
I'd say it's flat. I snapped a pic this morning on my way out the door but it's not a very good pic.
#134 |
Thanks Rob,
Looks like I'm pulling the inside panel to start straightening out the rear now. Oh well...at least there's near "0" rust on this TX Army Truck. When I get some shots together, I'll start my post too. Good work on yours.....keep it up. Thanks man! mike |
#135 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Wow! You really have gone through thoroughly.
Subscribed..
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#136 |
Still Learning
I thought there was an update. Oops
#137 |
No, no updates. Sorry. I was hoping to have the cab on this spring but didn't get finished with the eyebrow and lower support rust. I've spent all summer working house projects. Had to replace windows, build a back deck. And also put a little work in the side garage. Hopefully here in a month I'll get back on it!
#138 |
Honestly,
I waver sometimes when I look at what I still have ahead of me in patch work, but your thread motivates me to keep plugging forward.
#139 |
hey structures, Havent seen any undates in a while? Been getting anything done on your truck?
#140 |
Unfortunately not. I've actually been rehabbing the garage and working on the house. I do need to post up some more pics though. I just haven't touched the truck since last April. I've been wanting to get a rotisserie set up for the cab to help with some of the body work.
#141 |
Well ya'll drug it up and now I've read it, so I'll be waiting
#142 |
Cab Support Brackets
I'll spare you all my sob story of working on other stuff and just get into it.
Not much since the last post. ![]() I flipped the cab over on it's back to get better access to the lower and top sides. I ordered replacement cab support brackets for each corner, however they won't be here for a week or so. In the mean time I took the support off the front RHS. It might look like the bracket isn't in that bad of shape, but I put a lot of weld into it at the outer end. I just decided to pull it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#143 |
UCA63
I was scratching my head on how I was going to get that piece out without destroying
the brace,Great pics and stepxstep thank you once again ,,looking good. BTW been at my GMC about as long as you .....and your still ahead of me! LOL T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#144 |
I did my right side also on my 62. I didn't remove my cab because I didn't have but the right rocker and front cab mount to repair. Looking back I wish I would have. I just didn't have the room. I lifted the cab and cut out all the spot welds. At that time I didn't have a spot weld cutter and it was a B*&#$to remove with a regular drill bit. Lucky enough I have a good air hammer. I had a hard time removing the front wedged in the front brace. Being on my back I couldn't get enough space to remove the support. So it took me a little longer with the air hammer but I got it done. I replaced the cab mounts a week later when they came in. Your welds look good and you are coming along great! Here is how I did it.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#145 |
Hey Structures, Nice to see you back on the truck! Nice job on the cab braces. I done mine the same way with the cab sitting on its back. The front braces were pretty easy. when started on the rear ones, that took some time and were so aggervating. The ones I bought were not made no where near like the origionals. I had to cut them up and change the angle of them just to get them to fit. If your replacing the rear cab braces ill just say good luck. keep up the good work!!
#146 |
thanks guys. Chevelle, I broke the cardinal rule of cutting before I had the part in my hand! As you pointed out the fronts look pretty straight forward, the backs... I'm still thinking if i should splice. I'm not touching the backs until I get the parts. Should be next week though.
#147 |
Very nice progress and pics.
Alan
#148 |
Still Learning
Glad to see you're back at it. Nice documentation on the cab repairs.
#149 |
Thats what I did on the rear supports on mine. They were in good shape except near the inner rockers, I only cut about 4 inchs and spiced them together, I had my cab corner cut off so it was a little easier to weld them. Good Luck, I have some pics in my thread if you want to check how I did mine.
http://67-72chevytrucks.com/vboard/s...=439559&page=3
#150 |
Re: Cab Support Brackets
Got a little time in the garage.
